Do a longer higher speed run so we can better evaluate timing advance under load.
I'm not too close to Mexico, so it's a bit tricky to do a decent run. Here's 0-130ish (km/h) WOT.
I also got a 101F01 Throttle valve opening angle pressure --ignore, tuner code on my way home. I did WOT in Map 2 up to 110ish km/h. No log from that event. Is this a tune flag for the dealer or something, or an actual fault?
