(#651)
marsh1966 marsh1966 is offline
Car: M135i
Default 08-26-2020, 09:20 AM
Originally Posted by Augustor
Where I can download the firmware 7? And what has changed?
You will get the firmware on the first page.
MINI B38/B48 BMW X1/X2 JB4 - N54Tech.com - International Turbo Racing Discussion
but i run the obd11_4 version as the v6_2 firmware stopped the water and oil guages from working and also had problems with fault code reading. No problems with v4.
Car: M135i
Default 08-26-2020, 09:21 AM
Rottenfish Rottenfish is offline
Car: F56 Mini
Default 08-26-2020, 03:48 PM
Originally Posted by Jay1312
Had this few times before; once the obd cable was loose and then randomly froze few times. Updated to firmware 7 hasnít happened as frequent ( only once so far).
At least I know what was happening now, I can undo it
Car: B46 F56S
Default 08-26-2020, 10:53 PM
I had to go back to 6_2 to get rid of the freezing. Itís solid again.
Car: M135i
Default Map 6 Log - 09-26-2020, 03:36 AM
Can someone check this log for me, map 6 tesco 99 fuel.
thanks
F56_MCS's Avatar
F56_MCS F56_MCS is offline
Car: 2014 F56 MCS
Default 09-28-2020, 12:28 PM
Originally Posted by johntotah94
Anyone getting an issue of the PIDs freezing/gone when clicking ďclear codesĒ?
Been happening this past month with the new JB4 app and firmware.
After clearing codes, only Map and Boost is displayed, everything is at 0.
I tried disconnecting Bluetooth, killing app, disconnecting OBD2 cable, driving 2 hours and no response. Only fix is to turn car off and back on and everything operates as normal.
Thoughts? @terry @payam @ando
Canít attach photos via phone as file is slightly over limit.
I have had exactly the same problem
I have had my JB4 on my 2014 F56 MCS for 2 years without any problems but after the recent firmware update through the app (hex.7) my gauges freeze after trying to clear codes.
I have tried all the solutions listed above by johntotah94 with no joy.
How do I roll back to a more stable version 6_2.hex? @terry @payam @ando
Default 10-10-2020, 08:12 AM
We've had a few reports of wonky CANbus behavior on v7... Not sure what is causing that yet but I'll keep poking around. Anyone have v7 working/logging normally?
Brandy41 Brandy41 is offline
Car: Mini F57 JCW
Default 10-10-2020, 12:05 PM
I had the same problem, solved goin back at firmware _4.
Car: Mini F57 JCW
Default Mini B48 map 1 and 2 default values - 10-13-2020, 04:58 AM
Hi Terry,
Did you have a chances to looks what are the problems with the last firmwares about working and logs? Iím still running _4 firmware that works fine.
Other question: is it possible to post map 1 and 2 default values? Iíd like to make something in between on map 6. Thanks in advance.
Default 10-13-2020, 02:49 PM
On the MINI firmware no, I've seen plenty of logs with v7 CANbus working fine. So we'll need to track down why a handful of cars are having issues with it.
On the maps just look at target in your own logs then you can adjust as needed for map6.
Car: Mini F57 JCW
Icon1 Maps comparation - 10-14-2020, 01:57 PM
Hi Terry,
I pulled some data from the JB4 logs from the pulls I did during the rolls.
I made a table with the RPM values present on map 6 and I reported the targets (obviously additives) of the various maps and the actual boosts achieved both in PSI and in BAR (which give me more an idea), for maps 0, 1 and 2.
I know isn't very precise, but I think is good enough.
The pulls were done one after the other, so ambient pressure and temperature were pretty much the same.
I noticed a interesting thing:
Map 0, (stock), is much more ready in the 1500-2000 rpm range, both of maps 1 and 2, and 1 is more ready than 2, it would seem that the lower the target value, the more the ECU pressure and effective boost are higher.
In all the maps, in the 3000-3500 rpm range there is a significant drop in the boost, then it goes up and stays stable and then goes down again, however give it a look and then tell me what you think.
Sorry for my English, and thank for your time.
Jay1312 Jay1312 is offline
Jay1312
Car: BMW 320i and M5
Default 10-14-2020, 04:35 PM
Seems ok last month or so. Previously had issues due to bod cable coming off.
NotSoMiniJIM NotSoMiniJIM is offline
Car: 2020 Mini Cooper S Countryman
Default 12-03-2020, 02:39 PM
Just installed the JB4 in my 2020 Countryman. I used MAP2 and took a short log. Is it normal for boost and AFR to not be recorded in the log? Also, the app doesn’t display any real-time info on the gauges...ideas?
Default 12-10-2020, 02:30 PM
Originally Posted by NotSoMiniJIM
Just installed the JB4 in my 2020 Countryman. I used MAP2 and took a short log. Is it normal for boost and AFR to not be recorded in the log? Also, the app doesnít display any real-time info on the gauges...ideas?
The 2020+ models use the BMW platform 58 firmware rather than platform 48 MINI firmware, for full logging. Try loading that.
gtavo gtavo is offline
Car: Mini F56 B38
Exclamation EWG firmware Question & Fuel Pressure Connector - 12-21-2020, 10:26 AM
Hi Terry! I recently recently bought a EWG connector for my Mini B38. What firmware for the EWG should I install? Since the EWG connector is b58.
Also, If you guys can help me how settings works since my tuner never work with ewg on jb4 before. Maybe a guide so he can get through. Thanks !
Also bought a JB4 fuel pressure connector since we are planning to run e85 with 93 octane. If you can help me with that to that would be awesome!
Default 12-21-2020, 12:05 PM
Use the latest MINI firmware! Default settings, grab a log, and we can evaluate.
thinkfast thinkfast is offline
Car: MINI F56 JCW
Smile JB4 Newbie - 01-02-2021, 07:22 PM
I am about to receive my new JB4 for my '19 F56 JCW.
What is the difference between the following firmwares?
Which FW is preferred?
Default 01-05-2021, 02:33 PM
Firmware is in the app now, updated the first post to clear it up.
Abdullah1907 Abdullah1907 is offline
Car: Mini Cooper 1.5T B38
Default Yesterday, 02:46 AM
I have Mini Cooper b38 I saw couple of people who tries map 6 on these cars. Approx. how many hp will it get me? And which map considers as "stage 2"? Thank you
