Car: E90 335i n55
e90 n55 335i hybrid turbo log review -
11-04-2020, 04:09 AM
Hello everyone, I finished installing my new turbo, stage 1, made a few logs on map5 and map 2, the car behaves ok and feels much stronger at high rpms, on the first log, threw me on map4, then reduced, manually ff / wastegate adaptation from 95 to 74, and there was no problem with map4 anymore ... I hope for any advice on what I can improve, possibly for map 6 settings .... currently the car has the following mods hybrid turbo stage 1 ( high flow turbine wheel, 52/68 compressor wheel) gfb diverter, turbo outlet, dp, cp, big FMIC, I have an adapter for n20 tmap but I haven't put it yet 93(100 ron) octan pump gas.Thanks and be healthy
Sorry wrong section...
2011 e90 n55, vrsf down pipe,cp,fmic jb4,AT xhp stage3
Car: 135i n55
12-02-2020, 04:10 PM
I have the same setup.
Car: 2012 n55 135i
12-04-2020, 10:58 AM
I've got the same setup, as well.
Install that N20 TMAP sensor and change boost safety to 22psi.
Your logs look pretty good.
2012 135i Mods: air scoops, CP, BMS filter, PS1, N20 TMAP, ADE FMIC, BMW PE, JB4, BMS BEF, 1M front body, full M3 suspension
Owned so far: 88 M3 x 2, 95 325is, 95 M3 x 2, 06 Mini Cooper S, 08 335 xi, 09 Z4 35i, 01 M3, 12 135i
Car: E90 335i n55
12-05-2020, 04:36 AM
it's snowy and wet here at the moment, and I can't do many experiments, but yes this will be the next step n20 tmap and experiments with a little ethanol ... thanks!
Car: 2012 n55 135i
12-05-2020, 06:08 AM
2 gallons E85 on top of 93 pump made a big difference for me.
Car: E90 335i n55
12-05-2020, 07:30 AM
here we do not have access to e85, there is 99.6% pure ethanol, but it is difficult and expensive to find ... I have tried several times mix e18-20 the difference is noticeable
