(#326)
nitrobass24 nitrobass24 is offline
Car: Maserati Ghibli
Default 06-07-2020, 07:41 PM
Good evening Terry - Here is a ton of data for you guys. I took this while on a rally tonight. I added 4.5 gallons of e85 for a total of 6 gallons estimated and topped the rest off with 93 pump, aiming for about E30.
I did run into an issue with boost, but was not able to figure out what it was.
First Run tonight was great See File P51_M5_R4_200607_1816-LongRun
We stopped for about 30 minutes, I turned the car off for this time.
When we got back underway I could tell something was wrong. I didn't have any lights on the dash, but when i hit the pedal it was just Mashed Potatoes. Pulled my phone up and I saw in the JB4 app that I was not getting any boost. There are a couple of different logs here.
One while I was still on Map 5, Then two after switched to Map0 to bypass the JB4 to see if the car would sort itself out. All three of these are appended with -No Boost.
Again we stopped for about 30 minutes. I turned the car off restarted and did a lap around the block still no boost. I went and filled out to top off with 93 pump a little less than a quarter of a tank. Got back underway and was running on Map 3 now, boost is back. At some point I did change it to Map 5 again, but I dont see that reflected in the log. The file for this run is appended with Boost Back.
Default 06-07-2020, 08:07 PM
The map5 data itself looks good. Most likely you triggered some sort of fault, likely due to "boost too low" from the DME's perspective, which needed to clear itself. Sure no fault codes are stored?
As for the map0 switch raise your boost safety setting to 20psi as 18psi is within reach of map5 and a false trigger for you.
Default 06-08-2020, 06:44 AM
Thank Terry - I did check for codes when I first stopped after I realized I had no boost. There were no codes at that time. I just again to see if anything was stored and still do not see anything.
What is the max boost that I should see on Map 5? Looks like at one point I hit 19.5 PSI.
Default 06-08-2020, 07:43 AM
In your logs target is the request over factory. Usually you won't make as much as requested over stock due to WGDC and turbo limitations, especially on the higher maps.
C777 C777 is offline
Car: 2016 Maserati Ghibli SQ4
Default 06-09-2020, 10:21 AM
Do I need to install firmware in order? Stable v2 then Beta v3. Or can I go directly to v3? I havent updated since purchase in Dec 2019. Thanks.
Default 06-09-2020, 07:37 PM
Couple of logs with v3 firmware.
PDX.R32 PDX.R32 is offline
Car: 14' Maserati Ghibli S Q4
Default 06-18-2020, 07:22 PM
Had my first CEL come on today; and it threw me into limp mode too! Looks like it was code 304B on Map2 on V2. Just was reading up on the forum and saw a V3 was released... Bet your ass I updated it! So far I'm loving the JB4. Can't wait to start adding ********* and intakes to let it breath a bit better.
Thanks for the constant updates and information Terry! I still need to send in my logs to you.
2014 Maserati Ghibli S Q4
1989 Nissan Skyline R32
Portland, OR
Insta: @PDX.R32
Default 06-23-2020, 12:45 PM
So I might get beat up for asking this, but is there such thing as an Eco Map?
Going on a road trip soon and was thinking it be nice to have a map that is tuned for max MPGs when under say 3k RPMs, but would kick in when needed to overtake/pass.
Default 06-23-2020, 04:35 PM
Map4 is a VALET map although has not been well tested, give it a shot.
AustinMAS14 AustinMAS14 is offline
Car: Sq4 2014 ghibli
Default 06-30-2020, 04:08 PM
Hello, I am new to the forum. Can somebody take a look at my log? This is map 2 on 93 Lastest update firmware First Log MAP 2 93 Octane .csv
Default 06-30-2020, 04:44 PM
Originally Posted by AustinMAS14
Hello, I am new to the forum. Can somebody take a look at my log? This is map 2 on 93 Lastest update firmware Attachment 96966
Looks good to me!
Default 06-30-2020, 04:49 PM
Thanks, Terry
would you say its safe to try map3?
Default 06-30-2020, 07:45 PM
Yes you can give it a whirl.
Default 07-01-2020, 11:19 AM
Thanks, here is a map 3 log. Not sure if I need to raise the boost safety for this map. I Definitely could tell a difference.
P51_M2_R3_200701_1114.csv
Default 07-01-2020, 11:37 AM
Looks fine to me, you can stay on this map. I'd raise boost safety to 20psi just to keep it out of the way as weather changes, etc.
Default 07-01-2020, 12:26 PM
Thanks Terry where exactly do I go to change that?
Default 07-01-2020, 12:40 PM
Boost safety is on the user adjustment page, can't miss it.
Default 07-01-2020, 03:30 PM
Thanks is it okay to switch from map 3 to map 2 with boost safety set at 20 ?
Default 07-01-2020, 05:33 PM
Yes no problem, that's a global setting.
9double8 9double8 is offline
Car: 2015 Ghibli SQ4
Default Yesterday, 01:22 PM
I've had my JB4 installed for the last 3-4 months running on Stage 2. I'm on my 2nd tank of 5 gals of E85 and top off with 93 octane. Thought I had 2 data logs, but just this one. Only other mod are K&N air filters.
How am I looking? Can I move up to the Stage 3?
Default Yesterday, 04:21 PM
Yes, go for it!
Default Today, 05:48 AM
Here is a pull now with Map 3, still with the 5 gals of E85 and topped with 93 octane.
Default Today, 08:16 AM
OK you can stay on map3 with the E85 mix.
