(#5501)
palazzja palazzja is offline
Car: 2016 Q50 RS AWD
Default 07-01-2020, 03:25 PM
Hi all!
Just got my EWG wires and am about to install.
I have the fuel wires hooked up and enabled Bit 0
I also enabled bit 6 for Red Sport.
Do i need to enable any other bits for the EWG wires?
Thanks.
Car: q50
Default 07-01-2020, 04:08 PM
Nope you got it.
Q50 Premium RWD
BMS JB4 w/ FW, WMI, EWG
BMS HE
Low cost LSD
Aileron76 Aileron76 is offline
Car: 2016 Q50 SS
Default 07-02-2020, 06:10 PM
Hey guys, would appreciate a look at my logs:
2016 Q50 silversport w Megans, MBRP exhaust, and jb4
No fuel wires or EWGs yet, but want to dial in my map 6 before putting those on.
My map 6:
1500 - 3
2000 - 3
2500 - 5
3000 - 6.5
3500 - 7
4000 - 8
4500 - 8
5000 - 8
5500 - 6.5
6000 - 4
6500 - 3
7000 - 0
Also, hows my map 6 look?
Im running 94 octane Canadian gas exclusively
2016 Q50 AWD Silver Sport
Megan Lower DawnPoipes
MBRP 3" Exhaust
18x9 FC04s w Conti DWS06s
JB4 w EWG wires
Pending Fuel Wires
Pending Z1 Collars
boonsgarage boonsgarage is offline
Car: 2018 Q50 Red Sport AWD
Default 07-02-2020, 07:51 PM
Originally Posted by Serstylz2
Hey Boon, it wasnt you per se, it was FACEBOOK. There's some people on there giving out bad info and swearing it's the gospel. You didn't do that at all, no worries and I apologize if I offended you at all.
Oh nah, it's all good man, just glad you let me know my map wasn't good.
I've updated the description in the video with your map 6 also, and a link to this thread, so that anyone watching will hopefully use that map instead.
Default 07-02-2020, 07:57 PM
That's pretty crappy to hook up a jb4 with fuel wires and dump a bunch of boost into a loaner car.
Well, it's not as bad as the guys who welded cages into GT350H's, raced them on the weekends, then cut the cages out before returning them to now-bankrupt Hertz, right?
But no, the car was good to go, I actually ended up having to return it maybe a week or so after putting the JB4 on, and had the car for 2 months prior to that to boot.
RS408's Avatar
RS408 RS408 is offline
Car: 2017 Q50 RS 400
Default jb4 - 07-02-2020, 11:13 PM
hey guys,
Not sure how to read logs. Running a map 6 based off of research from here. 2017 red sport w/custom catback only. Any pointers or advice ?
Car: q50
Default 07-03-2020, 04:13 AM
My map 6:
1500 - 3
2000 - 3
2500 - 5
3000 - 6.5
3500 - 7
4000 - 8
4500 - 8
5000 - 8
5500 - 6.5
6000 - 4
6500 - 3
7000 - 0
That map 6 doesn't match the logs. Your logs look ok, but I don't see any target of +8 which would be too much for your setup anyways most likely.
Q50 Premium RWD
BMS HE
Low cost LSD
Car: q50
Default 07-03-2020, 04:14 AM
2 wrongs don't make a right. They're both pretty crappy things to do.
Q50 Premium RWD
BMS HE
Low cost LSD
Car: 2016 Q50 SS
Default 07-03-2020, 01:09 PM
Woops! Sorry, heres some better logs.
File Type: csv 1593806810193_P50_M6_R8_200630_2013.csv (34.0 KB, 4 views)
MBRP 3" Exhaust
JB4 w EWG wires
Pending Fuel Wires
Pending Z1 Collars
Car: q50
Default 07-03-2020, 01:26 PM
Those don't look bad. You might change your settings to only log WOT. All the part throttle stuff just takes up space and time.
Q50 Premium RWD
BMS HE
Low cost LSD
Car: 2016 Q50 SS
Default 07-03-2020, 05:37 PM
Ok awesome. Yes, ill try to set it up to only revord WOT, still learning the system a bit.
Now to wait for positaps to come in for the fuel wires (i dropped one in the engine bay...f)
Also, got my EWGs today, gonna put those ontonight probably. Gotta give a ahout out to bms, i bought them and they came to my door in Canada from Cali in 2 days. Awesome service
MBRP 3" Exhaust
JB4 w EWG wires
Pending Fuel Wires
Pending Z1 Collars
JonnyB JonnyB is offline
Car: 2017 Q60 RS400 AWD
Default 07-03-2020, 07:19 PM
Hey folks - been reading a lot on jb4 bit still not 100% sure if my logs (attached) look good, more specifically my ignition lines.
Both runs were map 6, first one I was targeting boost 3 a bit too quickly but maxing at 3 at the 5k rpm mark. Second log I changed it (after reading more posts here and not liking my ignition timing) I moved to start slower (at 1 psi) and slowly increasing by .5 till reaching 3.5 around 5k mark and then sharply tapering it down.
93 octane, very hot day, 3rd/4th gear pulls. 2017 RS Stock with BMS HX and Michelin PS 4S.
Appreciate any insights. Wondering mostly how can I know if I'm pulling timing/or if something is really looking bad.
Fyi - have a bunch of mods ordered plus JB4 fuel wires and EWG not installed yet (waiting for CBE upgrade).
Car: 2016 Q50 SS
Default 07-04-2020, 10:42 AM
A few more maps, turned up boost a bit higher up range, as Terry made fun of it a bit in the EWG thread
Also put on the fuel wires...but it seems like my afr still hits 25? I did set option 0 to "on"...so wth
File Type: csv 1593884470837_P50_M6_R7_200703_2228.csv (33.9 KB, 4 views)
MBRP 3" Exhaust
JB4 w EWG wires
Pending Fuel Wires
Pending Z1 Collars
guitaristguy313 guitaristguy313 is offline
Car: 2020 Infiniti Q50
Default 07-04-2020, 11:32 AM
Did you remember to hit save after enabling bit0? Under options in your log it says none. I made the same mistake before.
Never mind I saw on your other log it says 0_On
Danny705 Danny705 is offline
Car: 2019 Q50 Red Sport
Default Just updated to the newest Beta firmware - 07-05-2020, 09:29 PM
I just updated my firmware to the newest Beta version. After completing the update and the JB4 restarting my car was in limp mode. It didnt throw any codes. I tried restarting the car and the jb4 an i was still in limp mode. I had to unplug the jb4 and replug and resart the car then it came out of limp mode and seem to run fine. I did a couple of pulls on map 6 and logged them. Can anyone tell me how they look. I have 2019 q50 RS with fuel wires no other mods. Im not sure if im reading them right but it doesnt look like im getting full boost throughout the rmp range and also it shows the pedal is not fully depressed throughout the rpm range which is not the case. I hit 3rd gear in the first pull. Both pulls were done from a stop.
Car: q50
Default Yesterday, 07:36 AM
Logs look fine.
Q50 Premium RWD
BMS HE
Low cost LSD
Car: q50
Default Yesterday, 07:38 AM
Your logs look fine too. Your last log shows a 1-3 pull that looks fine.
Q50 Premium RWD
BMS HE
Low cost LSD
Default Yesterday, 08:35 AM
Bump - looking for some feedback, this is my third post without any feedback Appreciate anyone taking some time to look at these, thanks so much.
2017 Q60 Red Sport AWD Obsidian Black / ProActive + Tech Package / Weathertech Q60 Mats / Michelin PS 4S / Nokian Hakkapeliita R3 / 18' RWC IF395 Anthracite (winter) / BMS Elite HE / JB4 + Bluetooth + FW (not installed) + EWG (not installed) / Chrome Delete Front Grill / CF Duckbill RR Spoiler (not installed) / Add OCC (ordered) / RSR Down Springs / FI HF FDP (ordered) / FI CBE (ordered)
Car: q50
Default Yesterday, 08:49 AM
Both your logs looked fine. I get nervous when I see large dips in timing or timing at WOT that stays less than 5 degrees. You dont have either.
Q50 Premium RWD
BMS HE
Low cost LSD
Default Yesterday, 09:05 AM
Thanks so much for your reply! One thing I'm wondering, I do see a steeper drop in timing on first gear when doing a 0-60 pull. Guess that's normal/expected ? I don't see the same drop when doing a 3rd gear pull.
Thanks again for taking your time on this
Car: q50
Default Yesterday, 09:16 AM
I wouldn't sweat it if you see it in 1st only. It could be a different row of the timing table based on load or all kinds of other reasons.
Q50 Premium RWD
BMS HE
Low cost LSD
RS408's Avatar
Default map 6 logs - Yesterday, 09:34 AM
Lowered boost and ran a few more logs. What do you think? Posted a few runs and map 6 settings.
Looks like timing gets a little better with 2.5 max added boost, still pulling too much tho? Trying to figure out how to make more power.
map 6, Redsport, catback only, 91 only
RS408's Avatar
Default map 1 - Yesterday, 11:36 AM
here's a map 1 log. looks better then map 6 log...
Default Yesterday, 04:37 PM
Would need CSV for any tuning advice!
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
