(#1826)
ipetey ipetey is offline
Car: 2020 m340i
Default 06-12-2020, 10:19 AM
You plug in the flash adapter and upload the JB4 flash map for your fuel. Then set options bit6 on in the JB4 app. Done.
Thank you!!!!!! Perfect. Just one question, do I need to do anything special when connecting the flash adapter? Since the JB4 is connected in the OBD plug, do i have to make sure the car has been locked for 10 minutes or anything like that. Or i can simply unplug it, plug in the adapter do the flash map and reconnect my jb4. No locking the car/waiting etc.
Outlawmotorsports Outlawmotorsports is offline
Car: 2020 Supra
Default 06-16-2020, 07:41 AM
Can someone provide input on installing the EWG Harness on my 2020 Supra JB4? I took a quick glance at it this morning and it appears there is already a wire in #9 where the purple wire is supposed to go. Am I missing something?
absaifan absaifan is offline
Car: Supra 2020
Default 06-16-2020, 07:48 AM
Look at it again, you must be reading it wrong.
Here's a pic I found online.
Car: 2020 Supra
Default 06-16-2020, 08:03 AM
Thank you! The pic i found online when i searched had the numbering order completely different.
Car: Supra 2020
Default 06-16-2020, 08:15 AM
Use the Burger Motorsports diagrams / videos to be sure, they explain it all well.
If you install the pin in the wrong hole, it'll be a mission to remove it without damaging the harness pin so be definate.
Kona61 Kona61 is offline
Car: A90
Default 06-25-2020, 03:34 PM
Hey guys, I had a question about the JB4 on an A90 Supra. For the usage of Map 4 and 5, you recommend the EWG wires and that's all? No BEF necessary? Also, if I can use it, how close do I need to get the E85 content for both maps 4 and 5?
Car: Supra 2020
Default 06-25-2020, 03:44 PM
I got the best power results using the EWG, it's worth to install it to better manage the boost up top.
BEF is an excellent add-on especially if you want to go for higher boosts and upgrade the turbo etc.
Can't comment on e85 as I never used it, sorry.
510W_MPP340 510W_MPP340 is offline
Car: Zhp 340 18
Default 06-25-2020, 05:11 PM
How much can a stock b58 turbo take up until blow lol... hp/boost. ?
Car: Supra 2020
Default 06-26-2020, 01:29 AM
18-20psi all day and 420-450 whp on pump gas, depending on your mods.
Gearbangin Gearbangin is offline
Car: Supra
Default 06-26-2020, 09:38 AM
Whats up all! I Have been running the JB4 on my 2020 Supra for several months on MAP3 with 93 Octane. I recently added the EWG added E40 using MAP 5. It was maxing out the fuel trims so I switched to E30 and MAP 4. (Terry gave me some good feedback)
Anybody have any feed back or suggestions to run MAP5 and an E blend?
xz329 xz329 is offline
Car: F30 330e
Default 06-30-2020, 08:58 AM
Am i the only one feeling older firmware making more power n higher boost than new firmware?
Especially v11 and v13 firmware feel more power than v16
Default 06-30-2020, 07:50 PM
The newer firmware is newer for good reason, but I always tell people, run whatever firmware they prefer.
Default 06-30-2020, 07:51 PM
If map5 is more than the fuel trims can handle, adding in our BEF at some point is an easy way to resolve that and allow 100% E85.
