(#251)
Default 02-15-2019, 09:58 AM
No it's not. But, we could ship you a 2580 chipset for it for $25 + shipping. Just email in to sales to inquire.
smithf32 smithf32 is offline
Car: F32 428i
Default 08-25-2019, 08:05 PM
No updates at this time. Once we crack the digital dash we'll update the CANflap at that time.
Curious to know being that its about a year later, is there any luck with this?
I bought this a while back for my F80, and now have an F32 440i with the 6WB option (Digital Cluster).
Default 08-27-2019, 09:31 AM
Sorry no digital dash support yet for menus although the CANflap operation should work
BomberF33 BomberF33 is offline
Car: BMW F33 440i
Default 04-17-2020, 06:15 AM
Hey Terry,
I have an CAN Flap Module whichs works fine in a M3 competition. Now I have a 2019 F33 440i with gasoline particulate filter (german version, no digital dash) and found out, that the flaps are no longer working with my car. The indicator in the dash works like expected, left - activated, right - deactivated, but not the flap itself.
Has there been probably any other firmware update since July 2016 (this was the last version I found mentioned in the forum) which can solve the issue?
Micha
Default 04-18-2020, 09:02 AM
Originally Posted by BomberF33
Hey Terry,
Micha
We have made changes to the in dash part but the flapper commands should be unchanged. It's possible for 2019 440i they have changed the exhaust command for DRF cars, since there is no car local here, it's difficult to determine. But I'll see if any other DRF customers report a similar issue.
Eiknujrac Eiknujrac is offline
Car: 2020 M4 SMB
Default 03-26-2021, 01:38 AM
Hi Terry,
To revive an old thread, I also have installed this on a car with an OPF/GFP (2020 M4).
I had the same issue as BomberF33 - no matter what setting (open/closed/OEM) the flaps remained closed. Even stranger, once removing the module, the flaps remained closed regardless of engine mode until I had shutoff the car and come back later in the day.
Playing around yesterday evening I found that it might be related to the ASD settings: I had enabled option 1 (ASD mute when flaps open), but after disabling this, the flaps seem to work as intended given the basic settings (open/close/OEM).
Will dig a little bit more.
SamF32 SamF32 is offline
Car: BMW 440i
Default 06-25-2021, 04:23 AM
Hey Terry,
Micha
Hi BomberF33,
Did you have any luck solving this issue? I also have a 440i and mine is having the same issue as you had, the indicators work as expected but the flap doesn’t actually change. Any help is appreciated.
joec1101 joec1101 is offline
Car: '15 435i F33
Default 08-16-2021, 01:43 PM
Hi Terry,
As you can tell, I'm bored AF not working anymore
I purchased for my 2018 F87 the CAN flap Module from Etek in April 2018 - At the time the firmware did not work correctly with the new dash, but the flap control works.
Any updates to the firmware for this device? I can't seem to find any info on it.... If so, can you send me a link to download?
TIA
Default 08-16-2021, 02:39 PM
No changes on that front
ashmostro's Avatar
ashmostro ashmostro is offline
Car: 2013 335is DCT
Default 11-11-2021, 05:10 PM
Hello Terry. I have a 2022 F90 M5 and was advised the can flap module will work on my car, but I'm not sure if it does. I can't enter adjustment mode through the BC stalk. Is it incompatible?
EDIT: I purchased the module direct from BMS in October, and as advised I ordered the F-chassis variant. Should I have gone with the G-chassis variant instead given the non-M 5-series is a G chassis?
2022 F90 M5 Comp
blockerm blockerm is offline
Car: 2017 BMW 340 MPPSK
Default 12-24-2021, 07:47 PM
Terry,
Bought a Canbus unit for a 2017 BMW 340 with the MPPSK package. Unit flashes the blinker as expected but exhaust valve does not open or close. Can you send me the latest firmware update?
