(#4226)
Default 04-29-2021, 09:10 AM
Originally Posted by krissanta94
For whatever reason it didn't upload, hopefully this works!
Looks fine to me!
twister68's Avatar
twister68 twister68 is offline
Car: 2017 Q60 RS
Default Log Help Please Terry - 04-29-2021, 09:41 AM
I think I'm seeing issues but to be honest I'm out of my depth..
Please can you take a look at these logs. Newer one is without ECU Tune and older one is with it.
Only using MAP0 with fuel and EWG wires disconnected.
Thanks Terry
Twister
2021 Genesis 3.3T
Siberian Ice
JB4 kit with EWGs MAP 2 94RON
Feeling the JB4 difference
Alpha_Sting1 Alpha_Sting1 is offline
Car: Kia Stinger GT
Default Here ya go - 04-29-2021, 10:23 AM
I can't use excel files, only native JB4 logs which are CSV format.
Her ya go bud
dareckibmw's Avatar
dareckibmw dareckibmw is offline
Car: Genesis G80 Sport
Default 04-29-2021, 12:12 PM
I just updated firmware from v17 to v22.....is DWP settings on JB4 referring to Default Wastegate Pos? I'll try setting to 60 for now, if that's what this is?
Car: 2020 Kia Forte GT
Default More 13 second passes - 04-30-2021, 03:32 AM
And the beat goes on -
Another trip to NoCal for the Forte GT resulted in more 13 second passes.
Unfortunately my first pass I didn't enable Sport Mode. But it still ran 14.007@102.07
Pass right after that = 13.82@103.16 Sport Mode enabled of course.
Again I got my best run after the car cooled down = 13.77@103.47
Compared to my best Map 3, E30 only run was 13.75@101.9 but I did run 102.12 which ironically was the first pass that outing.
The tenth + from WMI is keeping me in the 13's despite slightly slower 60ft times.
Last pass of the night was about as close to a back to back as I got (15-20 mins between runs). I tried a slightly lower launch RPM. The 60ft was better by a tiny bit but less energy into the rotating assembly meant the inertia wasn't there to run 103+ again so it ran 102.35.
13.800@102.35
The main difference between two weeks ago and last night was much warmer ambient temps peaking at 90 degrees at 4 pm when the track opened.
It was still in the 80's when I ran 13.77, only .02 off my best ET but 1.52 mph gain or about 15 whp with WMI and slower 60ft (2.11 vs 2.07)
Same boost levels as Map 3 (Boost Additive 60).
I am going to head back out this weekend. Based on current forecast it looks like Sunday will be best with a peak temp of 83 degrees. With WMI I am not worried about hot weather but traction tends to be worse. That is mainly a problem for vehicles which much more power than I'm making currently. That said I already have a traction problem even with drag radials so we'll just have to see.
2020 Kia Forte GT
6 Speed Manual
JB4+Bluetooth Connect
Whiteline Springs
13.77@103
Map 7, E30+WMI, Hoosier Drag Radials
Lil Ripper's Avatar
Car: 2019 Veloster turbo
Default 05-01-2021, 12:08 AM
13.800@102.35
Good stuff! What kind of tire pressures are running?
Default 05-01-2021, 03:40 AM
All the runs but the last two are at 17 psi and I didn't know it. I checked the pressure before I left the house. Burnouts had increased it to 17 psi from 15 psi cold.
I took out a pound each time after the first couple of runs. I was wondering why my 60ft where 2.1x instead of improving as the track rubbered in.
The last run it was 16 psi but I launched at a lower RPM.
Not great, I am working on driving the 60fts down. I expect the prep at Famoso will be better.
2020 Kia Forte GT
6 Speed Manual
Whiteline Springs
13.77@103
bigdingus's Avatar
bigdingus bigdingus is offline
Car: 2018 Kia Stinger GT1 AWD
Default 05-02-2021, 09:05 AM
Not long enough to evaluate timing. 0-60 is all launch, little to do with tuning.
Hopefully this log has more of what you need? v24_T1, map 3. Thanks!
Car: Kia Stinger GT
Default Re: ‼️ - 05-02-2021, 03:22 PM
Originally Posted by Alpha_Sting1
So after a primary ******** install with a little bit of throttle it goes into limp mode. CEL came on
Happened on map 0 and 1. Got a code P0049 Turbo overspeed.
Any help would be appreciated, thanks!
Stinger GT JB4
Intakes / Velossa techs/ Intercooler / Secondary DP/ Primary DP/ Muffler deletes / 2.5 Turbo back / HKS plugs
Limp in maps 0,1,2 and 3. No once on map 5
P0049 Overspeed as well. Non foulers are on all 4, still CEL with that P0049
Batmax89's Avatar
Batmax89 Batmax89 is offline
Car: Hyundai Elantra N Line 2021 DCT
Default Hyundai Elantra N Line 2021 - 05-02-2021, 10:01 PM
Hello I have a question, I currently have a hyundai elantra n line 2021 dct transmission with the new 1.6t smartstream engine I would like to know if a jb4 works on the vehicle, the people at jb4 told me that yes it would work thanks to pleasure
Default 05-03-2021, 12:56 PM
Looks good to me, thanks!
Default 05-03-2021, 12:57 PM
If you're talking about fouler on o2 sensors that is an awful idea. If they are on the primary sensors they need to be removed ASAP. Rear o2 sensors not as big of a deal but not useful usually.
Also to look at logs they need to be set to combine so it's just one file. I opened a couple there and didn't see much. Are JB4 EWG connectors installed? For over speed those are usually used to slow down turbine speed.
Default 05-03-2021, 01:53 PM
If Burger Motorsports told you it would work it will work. This forum is also used for technical support by Burger Motorsports the answer will be the same.
As I understand it the "Smart stream" engine is basically the same but has continuous valve duration and a .5 reduction in static compression ratio.
2020 Kia Forte GT
6 Speed Manual
Whiteline Springs
13.77@103
Car: Kia Stinger GT
Default 05-03-2021, 04:17 PM
Why is an awful idea though? Combine as in 1 hour or other hours? No, do not have the EWG connectors. Not having is likely what's putting into limp mode?
Default 05-03-2021, 04:59 PM
People run defoulers because they are trying to trick the powertrain module (engine computer) that you are running no catalyst which is highly illegal, but you think you need that 10-15 hp they provide as proof of a restriction.
Also your contribution to things like clean air and the RPM Act is a small thing in the sea of others modifying cars or so you think. I get a kick out of people that freely admit to wrongdoing.
The JB4 is not a PCM flash that is reprogrammed to ignore error codes from no catalyst that are generated otherwise.
For the JB4 to work properly you need the 02 sensors to behave as normal.
There are better ways to gain a tenth or so of a second which is what 10-15 hp is.
2020 Kia Forte GT
6 Speed Manual
Whiteline Springs
13.77@103
Default 05-03-2021, 07:39 PM
If you have an over boost issue get EWG connectors installed so we can dial in WGDC.
Foulers throw off the o2 sensor readings which the ECU is using to control fuel injection.
twister68's Avatar
Car: 2017 Q60 RS
Default 05-04-2021, 06:28 AM
Terry any chance you can take a look at logs I posted last week please? Thanks
Twister
2021 Genesis 3.3T
Siberian Ice
Car: Kia Stinger GT
Default 05-04-2021, 09:48 AM
OK ordering the EWG connectors. Also bought the JB4 in 05/19...Needing that master chip? Drop down menu choose
Kia Stinger master chip?
Batmax89's Avatar
Default 05-04-2021, 02:55 PM
I tried to plug in the connector and it does not match together
Default 05-04-2021, 02:59 PM
Isn't that sort of bland, you didn't mention a specific connector?
There are only two, Map sensor on the intake manifold and the Map/Tip on the charge pipe connected to the throttle body.
There might be slight differences with the newer engine as they have to update the harness for the 2021 vehicles.
Best thing is to contact support, take pictures and explain your problem clearly.
2020 Kia Forte GT
6 Speed Manual
Whiteline Springs
13.77@103
Default 05-04-2021, 08:01 PM
Yes good idea to have it just in case.
