oracle462 oracle462 is offline
Car: 2018 340xi
Default B58 340xi log review - 10-03-2021, 08:16 PM
Hey all,
Looking for some feedback on this log. Done in 4th gear with a shift to 5th. Car is currently with AA catted ********, BMS intake. Map 4. Thoughts?
Car: Evo VIII
Default 10-04-2021, 11:13 AM
Logs look pretty normal, but trims are maxing out. I would not recommend adding any ethanol due to the maxed out trims.
Car: 2018 340xi
Default 10-04-2021, 03:01 PM
Thank you! What options do I have to get the trims in good shape? I’d love to run map 5 at some point but need some guidance as ways I could achieve that.
Car: Evo VIII
Default 10-04-2021, 06:05 PM
Are you currently running ethanol? If so, what percent ethanol are you running?
Car: 2018 340xi
Default 10-04-2021, 06:19 PM
Nothing currently but there’s a station nearby. There is a royal purple octane booster in the full tank with this log.
Car: Evo VIII
Default 10-05-2021, 10:01 AM
Try map 5 and upload a log without any E85. If you want to run E85 flash the BMS BEF.
Car: 2018 340xi
Default 10-07-2021, 04:59 PM
Hereís a map 5 pull in 4th and 5th gear from the same tank with Royal purple octane booster as the previously posted map 4 log.
Car: Evo VIII
Default 10-08-2021, 01:11 PM
It looks like you are maxing out trims and are starting to lean out still. I would start running map 4 instead, to keep things safe. Please upload another log in map 4. Thanks!
Car: 2018 340xi
Default 10-14-2021, 01:50 PM
Hereís another map 4. Looks like timing isnít good here either?
Car: Evo VIII
Default 10-15-2021, 09:48 AM
Trims look much better, still maxes out at start, but AFR's never went lean. Still too many corrections. Go ahead and run more octane, or try a log in map 2 and upload it.
Car: 2018 340xi
Default 10-15-2021, 06:13 PM
Tried a station close to work that had E85 since I needed to fill up today. I put in 2.1 gallons of e85 and then 92 on top of that. (Thatís the best they had). The station closer to my house has 93 and e85.
The timing looks a lot better here and trims look a little better also if Iím looking at it correctly. AFR seems to move around a lot, no?
Car: Evo VIII
Default 10-18-2021, 10:34 AM
Log looks good for the most part. Trims max out but you never end up going lean. Just something to watch for. Try to not put in more than 2 gallons of ethanol for right now. Can you get another log but in map 2 next? Thanks!
Car: 2018 340xi
Default E40-60 bef loaded - 11-25-2021, 08:11 AM
First trials at e40.
Default 11-26-2021, 01:33 PM
HPFP is crashing...too much ethanol.
