Car: 2019 Q50 Luxe
04-23-2020, 04:11 PM
I'll just put the connectors on the JB4 and reconvene tomorrow .. I'm sure someone will chime in by then
12.64 @114mph
0-60 4.46
Car: Q50 Red Sport
Pics -
04-23-2020, 04:17 PM
Here are some pictures i took. i hope they help.
Car: 2019 Q50 Luxe
04-23-2020, 04:22 PM
Thank you, I think I can work with that!
12.64 @114mph
0-60 4.46
Car: 2019 Q50 Luxe
04-24-2020, 05:44 AM
Does bit5 disable the EWG settings like it does for Stingers?
12.64 @114mph
0-60 4.46
Car: 16 Infiniti Q50 3.0t AWD
04-24-2020, 11:44 AM
Got my EWG wires installed today. Very easy, took about 15mins. Set my bias at 55 all through the rpm band and FF to 60. Had to turn my peak boost down a pound as I hit just shy of 20psi at the top of 2nd gear. Got a quick log of two 2nd to 4th gear runs and everything looked pretty good with a peak boost of about 18 at 5k rpm tapering to about 14 by redline. I saw one little timing drop out so I will lower the boost a touch there or add octane. I compared boost from these logs to previous and under 4k I did not notice much difference so far but I did see a 3psi or so difference in the mid range. It felt like boost came on stronger (especially before I reduced the peak slightly). Very excited to play with this more when the weather is better (raining today). I only went through the gears twice after the car warmed up before returning back to work at lunch. I will post logs once I have time to get some better isolated 3rd through 4th gear pulls.
2020 BMW M340ix Portimao Blue
K&N drop in, JB+, Intake muffler delete
2016 Q50 Premium 3.0t AWD (GONE)
K&N drop ins
Megan Racing Lowers
Megan Racing Y p!p3
BMS Heat Exchanger
JB4 W/fuel wires Map 6 custom
E20ish mix made 413whp 410wtq (17-18psi peak)
04-24-2020, 12:45 PM
It should test it out. You'll know it's working if WGDC stays pinned at 50 (no offset).
Car: 2019 Q50 Luxe
04-24-2020, 05:42 PM
Got a problem. Installed EWG connectors, revs in driveway were fine, started driving and limp mode but no CEL. Parked and turn off, back on, driving again, as soon as I hit significant boost, car rocketed forward, TC disabled, I almost went sideways and then I got a CEL and it says Warning Malfunction See Owners Manual. JB4 codes are 2562 and 2586. Any ideas?
12.64 @114mph
0-60 4.46
Car: 2019 Q50 Luxe
04-24-2020, 06:31 PM
Never mind. I never updated the user settings and the wastegate being at 0 across the board is a bad bad thing
12.64 @114mph
0-60 4.46
04-24-2020, 08:28 PM
Yes we'll adjust the firmware soon so those 0 setting issues don't cause an issue.
04-24-2020, 10:09 PM
Never mind. I never updated the user settings and the wastegate being at 0 across the board is a bad bad thing ��
Yeah, at first I had adjusted the bias to 55 and the ff to 60 but did not change the PID to 20 and the auto shift reduction to 60. I think it was causing some slight overboosting.
K&N drop ins
Megan Racing Lowers
Megan Racing Y p!p3
BMS Heat Exchanger
Car: 2019 Q50 Luxe
04-24-2020, 11:00 PM
My car is a damn ROCKET SHIP now. Gotta completely relearn 0-60 technique or disable EWG for digs. Traction GONE and completely hanging with tuned Qs on 93
12.64 @114mph
0-60 4.46
Car: 2019 Q50 Luxe
04-25-2020, 12:00 AM
Did some racing and got some logs for review. Some of these will hopefully suffice.
12.64 @114mph
0-60 4.46
Car: 2019 Q50 Luxe
04-27-2020, 03:11 PM
Log check anyone?
12.64 @114mph
0-60 4.46
Car: 2016 q50 premium
04-28-2020, 11:07 AM
Originally Posted by jsbowling42
do you have a link to the post? i looked through Terry's posts yesterday and didn't see it.
+1 on the graph. I missed it to!
Car: Q50 Red Sport
04-29-2020, 09:45 AM
Car: 2019 Q50 Luxe
04-29-2020, 01:56 PM
Hey Terry, anything you need to see from a logging standpoint? Also I do believe bit5 does disable EWG. Let me know if you need a guinea pig foranything. .
12.64 @114mph
0-60 4.46
04-30-2020, 10:51 PM
Good stuff!!! you did the logs on the Map 6 you shared here on the forum? 93 octane?
2019 Infiniti Q50 Silversport
JB4 with fuel wires, EWG wires,
HKS lower down P!pes
Burger tuning heat exchanger
Car: 2019 Q50 Luxe
05-01-2020, 04:57 AM
12.64 @114mph
0-60 4.46
05-01-2020, 08:58 AM
Nothing for our development at this time no, just if you need tuning advice.
Car: 2019 Q50 Luxe
05-01-2020, 06:25 PM
Quick log with some e20 in tank
12.64 @114mph
0-60 4.46
Car: Infiniti Q50 RS400
05-02-2020, 12:50 PM
Any RS on firmware v9_T2. Any significant changes from v8? Thanks.
2020 Q50 RS AWD
AEM 50-1200 LPFP
AMS/Infiniti CAI housing
BMS EWG wires
BMS intake inlets
BMS JB4 w/Bt
BMS fuel wires
BMS WMI kit
Custom 2.5in catback exhaust w/res
CZP LDP w/heat wrap
DevilsOwn 2.25gal WMI tank
Infiniti Sports Mufflers
Inline dual OEM/dual pass hx
Stillen RSB
Swift lowering springs
Z1 Motorsports 2 piece rotors front/rear
Z1 Motorsports subframe collars
05-02-2020, 04:55 PM
Looks good to me
Car: q50
05-03-2020, 05:19 PM
wut? V8 is the latest per the 1st post.
Q50 Premium RWD
BMS JB4 w/ FW, WMI, EWG
BMS HE
Low cost LSD
Car: 2016 Q50 Red Sport
05-03-2020, 06:33 PM
That is false. V9 is now out.
Car: q50
05-04-2020, 04:07 AM
Edit...read the notes on V9- "Fixed compatibilitiy issue with latest JB4 Mobile v3.7 adapters causing false map switches and setting reset.".
Q50 Premium RWD
BMS HE
Low cost LSD
