(#5026)
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 02-13-2020, 06:05 AM
Here's hoping you guys are able to get full wastegate control and knock monitoring. Now that HP Tuner's has unlocked the ECU its looking very tempting...forget Ecutek.
X2. If I can manage a clean dyno making 430-440whp with bolt ons on 93, why possibly void my warranty..
You'll be looking really good with wmi
12.64 @114mph
0-60 4.46
Car: q50
Default 02-13-2020, 07:20 AM
Exactly!
Q50 Premium RWD
BMS JB4 w/ FW, WMI, EWG
BMS HE
Low cost LSD
Default 02-13-2020, 10:54 AM
I'm finding a nice boost response benefit too on lower end power for the non-RS models. I suspect once I sort it out most customers will want them even those running pump fuels.
Oh yes, that is so true! WG control does make much better response all around based on how we map it with the pedal
Car: Infiniti Q50 RS400
Default 02-14-2020, 09:48 AM
Found the command to read "driving mode" (comfort, sport, eco, snow, etc).
Should we setup the JB4 so eco mode always locks in map0, or maybe even the VALET map? And maybe make the "sport" JB4 map user definable in the app?
Another awesome feature. My vote goes to ECO mode on Map0. Eco is crappy as it is lol. I would like to have sport and sport+ user definable.
Thanks for all the work.
Default 02-14-2020, 01:39 PM
Early version of V8 firmware is posted to the database forum (link in first post), could use a log or two to ensure gear is working for all models. ECO is tied to VALET for now too. Could also use an ECO boost/VALET map log or two on an RS to see how they react.
JCB JCB is offline
Car: 2018 Q50 3.0t
Default Gas Mileage Map? - 02-15-2020, 07:03 AM
Just purchased JB4 w/ bluetooth for my 2018 Q50 3.0t. Read as much as I could on this site, but don't see this covered anywhere. Is there map settings that would enhance gas mileage for day-to-day driving? Racechip advertises significant increases in mileage due to torque increase and ability to hold higher gears. Obviously the JB4 is superior to Racechip in its flexibility and ability to configure the maps in multiple ways. Anything Racechip can do the JB4 can do (better). Is the increased mileage just total BS? What map configurations would you recommend for best gas mileage in day to day driving? With the ease of bluetooth I could see flipping back and forth quite often between mileage and performance maps.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 02-15-2020, 07:32 AM
Theres a reason you dont see gas mileage discussions... If gas mileage is a concern, you don't need a JB4 or race chip. But, to answer your question, your best bet would be to either log your own results and see if gas mileage is impacted by Map, or turn the JB4 to Map0 (off) when you're trying to save gas. Your car will be running in stock form on Map0
12.64 @114mph
0-60 4.46
Default 02-15-2020, 09:44 AM
RaceChip is just full of it, their product produces no gas mileage increase. See the FAQ. BTW their logic you'd get better mileage with any tuning you decided to run because they all make more torque lol.
Our low boost VALET map is the closest thing you'll see to increased gas mileage on the vehicle.
https://www.burgertuning.com/pages/faq
Default 02-15-2020, 01:32 PM
Anyway figure out how to grab the v8 BETA firmware for the link and load it up?
Lonmon Lonmon is offline
Car: 16 Infiniti Q50 3.0t AWD
Default 02-15-2020, 03:46 PM
I'm looking forward to v9 with "Wastegate Wires" !
2020 BMW M340ix Portimao Blue
K&N drop in, JB+, Intake muffler delete
2016 Q50 Premium 3.0t AWD (GONE)
K&N drop ins
Megan Racing Lowers
Megan Racing Y p!p3
BMS Heat Exchanger
JB4 W/fuel wires Map 6 custom
E20ish mix made 413whp 410wtq (17-18psi peak)
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 02-15-2020, 04:51 PM
Thanks for clarifying. They arenít shy about claiming the mileage increase! I figure whatever they do you can easily replicate with JB4. Since the mileage increase is BS, I will just be happy with the ipower and flexiblity of JB4! Thanks!
Default 02-15-2020, 05:07 PM
Exactly. No idea how they haven't been sued over those false claims yet.
Default 02-15-2020, 05:13 PM
Yes... just did it now, same method I use when I upload fw via email. On iOS, navigate to the N54 repository, download it. iOS saves it in iCloud Drive. So using the ďFilesĒ app, navigate to iCloud Drive>Downloads and you should see the beta firmware. Using ďSelectĒ, select the fw, copy it to ďOn my iPhone>JB4 Mobile>Firmware folder. Now you can open the JB4 app, go to firmware update>click on the big green arrow, and your beta firmware should be listed there.
Side note, navigating to the n54 repository is a bit challenging since the site does not scale properly using mobile safari... but itís still usable.
Let me just familiarize myself with the new fw and Iíll grab some logs. Just reinstalled my JB4 today, been out of the loop in a while. Car is at 2500 miles now so it should be ready. Wmi reinstall maybe next week.
Default 02-15-2020, 05:57 PM
Did a very short log, lots of traffic i couldnt go full send.. Anything off? This is on v8.. there we're 2 versions, I uploaded the one with descriptions.
Also, on my Boost gauge, after I get to my target, it switches to a 0.6 instead if showing Boost.
Runnng Map6 flatboost +3, 2020 Q50RS AWD 91octane.
Default 02-15-2020, 06:10 PM
I have tried to download the beta into my s9 multiple times and it does not list the version 8 file in the list of jb4 firmware hex files after I press the green arrow. It lists 7.2, 7.1, and 7. I found the beta file from the link in the 1st post. I saw the version 8.1 and the 8.2 which I believe is not for us yet. I pressed down load on the 8.1v and the file appeared to be correct next to the green arrow. I push the arrow and it takes me to a list of version files I listed above. No version 8 to choose from. What am I doing wrong? I tried resetting the app and trying multiple times.
K&N drop ins
Megan Racing Lowers
Megan Racing Y p!p3
BMS Heat Exchanger
Default 02-15-2020, 06:27 PM
No log posted there. You can post it or email them in to terry@burgertuning.com, thanks!
Default 02-15-2020, 06:28 PM
There is an android update coming soon that will only let you pull files off the database system. Donnie tells me until then you should be able to grab the files by surfing to the database website link we have in the first post. But I have not tried it myself as I'm busy testing out the new app version.
Default 02-15-2020, 07:03 PM
Ah. I used my PC. Attaching now..
I finally got it figured out. I loaded it up and test drove around my neighborhood with the gear indicator as one of my gauges. I saw it changing around correctly. I don't have time to go out and log now but I will sometime soon and post them here for review.
K&N drop ins
Megan Racing Lowers
Megan Racing Y p!p3
BMS Heat Exchanger
Default 02-15-2020, 09:16 PM
Looks good. See if ECO mode changes it to map8 and grab a full throttle log on that also.
Default 02-15-2020, 09:32 PM
Verified switching to ECO switches to Map8 on 2020 q50 RS. Very impressive, JB4 feels luxurious lol. I canít wait until map switching via Mode switch is fully integrated. Iíll try and grab a log tonight.
2020 Q50 RS AWD
AEM 50-1200 LPFP
AMS/Infiniti CAI housing
BMS EWG wires
BMS intake inlets
BMS JB4 w/Bt
BMS fuel wires
BMS WMI kit
Custom 2.5in catback exhaust w/res
CZP LDP w/heat wrap
DevilsOwn 2.25gal WMI tank
Infiniti Sports Mufflers
Inline dual OEM/dual pass hx
Stillen RSB
Swift lowering springs
Z1 Motorsports 2 piece rotors front/rear
Z1 Motorsports subframe collars
Default 02-16-2020, 04:20 PM
I found trans temp logging.. Just need to figure out how to convert it to a usable number now. Plugged the byte output in to cyl5 timing for the moment in 8_T4 and plugged "converter slippage RPM" in to cyl4 timing for the moment to determine if it's useful for anything.
Default 02-16-2020, 08:13 PM
We will need more than 6 gauges on the JB4 interface soon.
2020 Q50 RS AWD
AEM 50-1200 LPFP
BMS EWG wires
BMS intake inlets
BMS JB4 w/Bt
BMS fuel wires
BMS WMI kit
CZP LDP w/heat wrap
Stillen RSB
importroller importroller is offline
Car: 2016 Q50 3.0t
Default 02-17-2020, 11:46 AM
looking forward to the overall benefits of the WG control. Especially for those of us with 91 but can add some E85 to the mix.
Default 02-17-2020, 11:57 AM
Yes that is on the to-do list, quite a few app change are coming soon. First to android and then to iOS after as Apple takes so long to approve changes.
