cmrobert cmrobert is offline
Car: 2018 Q60 3.0t Luxe AWD
Default 3.0t Luxe 91 Octane Map 1 Logs - 12-01-2019, 12:39 AM
I just installed my JB4 and fuel wires on my car today and was wondering if it looked okay for me to jump up to map 2. I tried to get some logs in before the rain came down heavy but they may not be the best. Any advice is appreciated!
Lonmon Lonmon is offline
Car: 16 Infiniti Q50 3.0t AWD
Default 12-02-2019, 10:56 AM
Looks good to me, timing, afr, and boost all look good for 91 octane. You are reaching a max of about 15 psi. You may be able to get another psi on 91 octane but I would not push it past 16 psi on 91.
2020 BMW M340ix Portimao Blue
K&N drop in, JB+, Intake muffler delete
2016 Q50 Premium 3.0t AWD (GONE)
K&N drop ins
Megan Racing Lowers
Megan Racing Y p!p3
BMS Heat Exchanger
JB4 W/fuel wires Map 6 custom
E20ish mix made 413whp 410wtq (17-18psi peak)
Default 12-02-2019, 01:00 PM
Awesome, thanks. I’ll do some logs on map 2 and post them just to be sure. In terms of boosting octane, is it safe to regularly mix a small amount of E85 in with 91 to make E20-25 with no supporting mods besides the JB4?
Default 12-02-2019, 02:10 PM
Yes, mixing about 4 gals and the rest 91 should be good. Make sure to run it down as close to empty as possible as you will start to stack ethanol if you don't get the mix right. Its not a bad idea to buy an ethanol tester (very cheap and easy) to at least know the content of the e85 you are using. Most can be between e60-e85 depending on the station and time of year (winter mix has less ethanol).
K&N drop ins
Megan Racing Lowers
Megan Racing Y p!p3
BMS Heat Exchanger
Default 12-02-2019, 09:16 PM
I ordered an ethanol tester so I can test the E85 near me before I mix it into my 91. I also attached the logs for map 2 just to double check its safe at the current octane
Default 12-02-2019, 09:22 PM
Looks fine to me!
