pascalm3m5's Avatar
pascalm3m5 pascalm3m5 is offline
Car: F10 535 Xdrive
Default N55 stock, runing map 2,with 94 octane= safe? - 02-20-2016, 01:17 PM
bmw
Weehe Weehe is offline
Default 02-20-2016, 07:46 PM
Give map 5 a try. If it boost the same or more than map 2 I would say map 2 is fine.
LycanX4M40i LycanX4M40i is offline
Registered Users
Car: 14' F25 X3 xDrive28 M-Sport AlpineWhite DHP
Default 02-20-2016, 08:21 PM
+1 on map5
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 02-20-2016, 11:40 PM
Map 2 and map 5 should be fine with just 94 and no other mods. You will find map 2 to be more constant but map 5 may yield higher boost.
Element's Avatar
Element Element is offline
Car: BMW 135i N54
Default 02-21-2016, 12:11 AM
Stop guessing, run some logs and post them in the support section.
keyap keyap is offline
Car: N55 135i
Default 02-21-2016, 03:01 AM
+1
Also, bear in mind map 5 sort of has 'built in' safety measures and will adjust down if you push things too far. Map 2 is set.
Car: N55 135i
Default 02-21-2016, 06:49 AM
You only need the item you linked to if you want to connect via bluetooth and use the mobile app (this also cost some $)
This may work for you depending on what you're using etc.
Email the guys at BMS for support / to confirm exactly what you need.
Default 02-21-2016, 10:20 AM
This...
Element's Avatar
Car: BMW 135i N54
Default 02-21-2016, 11:32 PM
Originally Posted by pascalm3m5
Whats a log, The guys at vagmotorsport , install a jb4 on my car,and, bye i was gone.
That is why you don't let VW tuners near your BMW
Bee Pee Bee Pee is offline
Car: BMW F20 m135i
Default 02-22-2016, 08:36 AM
Originally Posted by keyap
+1
Map 2 may be absolute if using old JB4 FW. My understanding of latest FW, both positap and OBD2, maps 1 and map 2 have initial partial adaptions to set parameters that a suitable/safe for the car configuration, fuel grade and driving style.
On a stock car, I'm convinced that an adapted map 2 may learn downwards to before becoming absolute and may not yield much more than adapted map 1.
Map 5 is constantly autotuning so should be optimising for stock configuration but sometimes autotuning can be "sluggish" when transitioning from DD / commuter mode to WOT demands. May take 1 or 2 WOT pulls before map 5 is optimised for WOT....
F20 M135i EB AT with options - what a hoot !
harkes harkes is offline
Registered Users
Car: M135i
Default 03-03-2016, 06:16 PM
Why do you have the idea that NOT going past 5000rpm and going WOT will hurt your engine? Is it one of those "know it all types" that also believe in Area 51 that told you that?
Car: 2011 e92 335i
Default 03-03-2016, 06:28 PM
I wouldn't spend the money on performance modifications if you only drive carefully (never WOT)
ronanz ronanz is offline
Car: '14 435i FBO ENZO S2
Default 03-03-2016, 06:33 PM
Area 51 is not a myth...
Siren05 Siren05 is offline
Car: 2015 435 GC
Default 03-03-2016, 07:55 PM
I love map 5 now that I have EWG patch, bms intake,AR *********, my car rips like a cheetah on meth
Registered Users
Default 03-03-2016, 08:13 PM
Agreed
So you have meth too ? lol
Default 03-05-2016, 10:23 AM
The thing with automatic transmission, is when you floor it , wot, it always change to redline. Where i had, 100% of my mechanical failure, over the years. Just a idea like that: we should have a option to limited the rev. EX 7000 redline 6500 warning zone and, the option shifting point, 6000 rpm( pamper zone!)
I really think you need to better understand your car. If you hit redline every time you go WOT you are hitting the kickdown. Also, with the stock turbo there is no point in even going past 6k rpms. Lastly, the auto trans will not let you go past redline. It seems like you need to learn how to drive the car properly.
Default 03-05-2016, 09:56 PM
That is what manual mode is for...
Registered Users
Default 03-05-2016, 10:40 PM
I still do some wot, sometimes. 80% of the times the conditions are not possible, for WOT. But, where i can, i play (WOT is a necessity their) i still drive one the most amazing brand in the world!
if you can't WOT once a day not worth driving it with tunes lol best enjoy its stock power
Car: N55 135i
Default 03-06-2016, 05:36 AM
I did not check yet what are the spec. but, i flore it , in manual mode. I think I was around 4000rpm, in 4th and the transmission drop a gear in 3th and suddenly, the engine was at 6000. Like the engine know better what is my goal or feeling.
Would something like this help?
Car: 2011 e92 335i
Default 03-07-2016, 05:41 PM
This thing is awesome on the track. I hope it helps you enjoy your car more.
