Croboto Croboto is offline
Car: 2016 340i x drive
Default DTC and DSC Off - 02-11-2018, 12:16 PM
My car is 2016 340i xdrive,is there a way to take dtc and dsc off without taking the car out of sport mode.
when i turn them off all the way, Idrive says steering and suspension are in sport, but not throttle and trans.
remko3dl's Avatar
remko3dl remko3dl is offline
Car: 440i Coupe
Default 02-12-2018, 10:18 AM
I’m not sure if I understanding your question correctly but you don’t want to be in Sport+ but you do want to completely turn off DTC and DSC?
As far as I know your transmission will only go to sport when you move the lever to sport and throttle should be in sport when you select drive mode sport or sport+
Default 02-12-2018, 11:24 AM
no matter what mode i start out in, taking off DTC and DSC completely,
puts it in a mode with only, steering and suspension in sport mode, throttle and
trans will be comfort mode.
BazBar's Avatar
BazBar BazBar is offline
Car: UK 140i-M Sport Auto
Default 02-13-2018, 05:40 AM
I have also noticed this, i have tried different set up options in the i-Drive but to no joy, why does it do this ?. Do you have the active suspension or the stock sport suspension?.
jalkster jalkster is offline
Car: 340i M-Sport
Default 02-13-2018, 08:13 AM
You cannot run all Sport settings (exhaust burble, sport throttle) with DSC off. Only sport transmission by putting the shifter to the left. Its terrible I hate it.
340i 8AT DME Stage 2 | JB4 | AP Intake | ER ** | Meisterschaft GTC | Ohlins R&T | Ground Control Camber Plates | MP LSD | 437M | RE-71R
Default 02-13-2018, 08:54 AM
there has to be a way around this.
maybe some coder can code it out.
