135iam 135iam is offline
Default RB Next Gen Plus Log Review - 04-01-2019, 08:34 AM
I did a couple changes over the weekend, and logged. How does everything look? How do I smooth out this choppy WGDC? This is MAP 2, I would like to get this smoothed out before trying Map 6 with the values from the Hybrid turbo thread.
Changes made before log:
New NGK 1 step colder plugs gapped at .022"
Fuel it Stage II bucketless pump
Holley Hydromat fuel pickup
oil change
Mods to car: (2010 135i N54 Manual)
MHD Hybrid back end flash/w JB4
RB Next Gen + turbos
RB inlets
BMS intake
VRSF intercooler
AR *********
Magnaflow catback
M factory LW flywheel w/ Spec stage 2+ clutch
Charge pipe w/tial BOV
3.5 bar map sensor
thanks!
2019-03-31Map-2.csv
2019-03-31Map-2.csv
2010 E88 135i manual/sport package
KWV3'3, M3 arms | ARC 8's 235/275 PS4s | MFactory Flywheel w/ Spec Stage 2+| AR downp*pes | Magnaflows | 7" VRSF IC| RB Next Gen +| inlets/outlets | ER Charge pipe| Tial BOV| BMS intake| JB4 with BEF | fuel-it stage 2 bucketless and Holley hydromat | NGK colder plugs | MHD back end flash and jb4
Default 04-01-2019, 11:29 PM
oil change
RB inlets
BMS intake
VRSF intercooler
AR *********
Magnaflow catback
3.5 bar map sensor
thanks!
Attachment 85084
Attachment 85084
Whoa! You are way over target- lower your boost safety to 20-21 for now.
Let’s set your DB to 50 for now across the board
Car: 2008 E93
Default 04-01-2019, 11:56 PM
Fud =6
Raginge93 Raginge93 is offline
Car: 07 335i
Default 04-02-2019, 12:07 AM
Wonder why it didn’t throw to into safety map since you were way over target
Default 04-02-2019, 05:11 PM
I moved DB to 50 across the board, and set boost safety to 21.
Thanks for the feedback, here are a few more logs.
2019-04-02 18_57_45_Map-2.csv
2019-04-02 18_58_07_Map-2.csv
Default 04-02-2019, 10:59 PM
His boost safety was set to 30 I believe prior
Default 04-02-2019, 11:03 PM
Attachment 85148
Attachment 85149
Lower DB by 5 from 3k-4K
Otherwise logs look okay- a few timing drops on cyl 5, but 5 does happen to be the noisiest cyl in general .
Take 2-3 WOT adaption pulls & relog
Default 04-03-2019, 03:32 PM
Moved DB to 45 from 3000-4000RPM.
Did quite a few adaptation runs.
Here is good 3rd and most of 4th log.
Thanks so much for the help
3rdand4th.csv
Default 04-03-2019, 09:53 PM
Attachment 85186
Hey this looks pretty clean to me
BIG improvement- how does the car feel?
What are you wanting to do? Leave the car here, change maps?
codesx's Avatar
codesx codesx is offline
Default 04-04-2019, 10:01 AM
I'm curious as well.
The WGDC look quite casual.
What fuel are you running?
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Default 04-04-2019, 02:27 PM
BP 93 octane w/ 3 gallons of e85. (May still be E70 winter blend,don't really know)
Default 04-04-2019, 02:44 PM
Car feels smooth with a nice power delivery.
What do I want to do? Can my setup support 19.5-20psi on map 6? I am wanting to see what I can get out of the current mods. With 93 octane.
I plan to add port meth this summer. Either using PHX intake or plate injection. And push towards 25-26psi and try out one of the half mile racing events near me.
Default 04-05-2019, 12:45 AM
Just 93 octane? Or keeping fuel as is now (believe you have a little blend).
We can try it, if you want to jump up to map 7- that targets 19 psi if memory serves me correctly - take a few adaptation pulls & log, we can see what timing looks like
Default 04-05-2019, 05:46 PM
The car was showing 30ish miles till empty, so I topped the tank off with BP 93 octane and switched from map 2 to map 7 and did 3 adaptation pulls before the below logs.
The car pulls pretty hard now. How are the logs?
2019-04-05 18_21_37_Map-7.csv
2019-04-05 18_20_53_Map-7.csv
2019-04-05 18_14_24_Map-7.csv
2019-04-05 18_13_59_Map-7.csv
Default 04-06-2019, 06:48 AM
Attachment 85283
Attachment 85284
Attachment 85285
Attachment 85286
Imo boost looks good, however I think map 7 is a bit too aggressive for the octane/turbos.
If you look your ign_1- you’ll see the drop in timing from 6.x down to 3.x mid pull- we don’t want that + the drops on multiple cylinders.
Couple options- we lower boost (via map 6)
Or you can add in some e85.
johnscales johnscales is offline
Car: BMW 35i
Default 07-15-2019, 03:06 AM
Thread is a couple of months old but this looks way down on power to me.
Only saying because I'm looking for some reviews on RB next gens with a view to getting some RB TWO's plus's. I bought a meth kit in the interim and was putting down 358WHP with FBO + inlets. Am now putting down 401WHP with the additional meth (99ron NO E85) . I thought these were good for upwards of 500?
Logged your csv's on virtual dyno and coming up with ~375whp (I took the 3rd gear portion of the 3rd and 4th pull).
I'd say some tuning is in order as I don't doubt the turbos.
