Default 2019+ Ford Ranger 2.3L EcoBoost - 02-26-2020, 05:54 PM
We will use this thread for discussion and updates on our new Ranger JB4!
Order here: https://burgertuning.com/products/jb...-2-3l-ecoboost
JB4 Mobile Smart Phone wireless connection directions Click here
BMS data cable hard wired directions Click here
JB4 Map Guide:
Map0: Fully disable JB4
Map1: +3.5psi peak over stock, default map, suitable for all fuels.
Map2: +3.5psi peak, less top end taper, more aggressive version of map1.
Map3: +4psi peak, suggested for 93 octane or up to 30% E85 mixtures.
Map4: +6psi peak, suggested for 30% E85 mixtures and/or unleaded race fuel
Map5: +7psi peak, suggested for 30% E85 mixtures and/or unleaded race fuel
Map6: User adjustable by RPM map on user adjustment page, values are peak boost over stock by RPM under heavy throttle.
How to update firmware:
For firmware updates we suggest you turn off WiFi, change upload timeout to 25, and set your phone next to JB4 box under the hood.
Default 02-26-2020, 05:56 PM
Hit the dyno today for some tuning fun on a 2019 Ranger, ~93 octane fuel. Baseline was 267whp / 306wtq which was about what I expected given the larger heavier tires on it.
Stepped up through the various map profiles all the way up through map5 which peaked at around 319whp / 372wtq. Boost, timing, and air/fuel looked solid through the runs with minimal knock count observed. Overall, all good stuff!
Up next will be some dragy 1/4 mile and 0-60mph testing!
Default 02-26-2020, 10:15 PM
Great stuff Terry!!
50whp and 70wtq gain already, wow.
Default 02-27-2020, 05:56 PM
1/4 mile and 0-60mph times are in. I know we can get the tuned times better but this is a good start.
reaperofchaos87 reaperofchaos87 is offline
Car: 2019 Ford Ranger
Default 03-25-2020, 12:25 PM
This is great! What map was the 1/4 and 0-60 times in the last post run on?
Default 03-25-2020, 04:41 PM
Map2 IIRC, have a RWD customer who recently posted a 5.7s running map3 with 30% E85.
RangerUNY RangerUNY is offline
Default 04-01-2020, 07:11 PM
I am reading that the SPD/aFe catted DP require a tune. Do one of the maps, for the Ranger manage the back pressure reduction? Should I not get a DP? Is one better than the other? Any guidance is appreciated.
Default 04-01-2020, 08:43 PM
I have not tested a DP on the Ranger.. If you get one record a JB4 log and we'll help you adjust for it if needed.
