(#526)
inkedfool94 inkedfool94 is offline
Car: 2021 Mazda CX-5 GTR
Default 09-21-2021, 07:45 AM
Originally Posted by tymwalk
I'm a big fan of removing the bumper for the install but I guess not everyone trusts themselves to remove everything needed for that.
There is this video but I'm not a fan of the method. Mazda CX-5 Turbo 2nd Map Sensor harness removal tip for JB4 install - YouTube
Do you have any specific concerns when it comes to removing the bumper? What is your experience with turning an automotive wrench?
I can do my oil and that's about it lol. My buddy, who essentially rebuilt a toyota soarer (the only thing stock now is the body) helps me with most of my stuff so I am learning. We just took the bumper off the other week for the FMIC upgrade from corksport, so taking it off isn't truly an issue. He just dislikes body work because of the relining of it lol.
I did watch that video but for some reason it taped to a desk doesn't quite seem the same but thanks
Xirtic's Avatar
Xirtic Xirtic is online now
Car: 2021 Maxda 3 2.5T AWD PP
Default 09-21-2021, 12:54 PM
Both times that I have had to open the unit after install one of the screws/nuts on the smaller connector have vibrated loose. I am certain that a bouncing loose piece of metal near a circuit board is not a good thing. I had no loctite around, so I wrapped the connector in electrical tape to prevent the nut from coming loose in the housing. It may be advantageous to start using nylock nuts for this use.
Josh
Nashville TN & Algonquin, IL
2021 Mazda 3 2.5T AWD Premium Plus Hatchback (Poly Metal)
Mods: None as of yet.
2006 Mazda Miata Sport (Red Copper Mica)
Mods: Many interior, Exterior and Performance changes.
Default 09-21-2021, 01:45 PM
On the blue tooth enclosure? Never had that happen or heard of it happening. You can always delete that cover all together, no one can see it with the enclosure closed. It's only on there for JB4 models that have an exposed DB9 connector.
Xirtic's Avatar
Default 09-21-2021, 01:56 PM
Yes. The Bluetooth adapter serial plug. Has happened twice. The captured nut does not remain captured. When I get back to my TN home, I will raid the hardware drawers for the right nylock nuts.
Josh
Default 09-21-2021, 03:40 PM
Just remove the shell it's purely aesthetic anyway. A year ago it wasn't even there.
Xirtic's Avatar
Default 09-21-2021, 03:46 PM
Thank you Terry. I appreciate the low tech solution. Keeping it simple works for me.
Josh
SixPackABS SixPackABS is offline
Car: Mazda 3 Turbo Hatchback (M3TH)
Default 09-22-2021, 02:09 AM
Yes very tricky to get consistent dyno numbers out of stock or otherwise.
is the 40 HP gain give or take with JB4 guaranteed?
M3TH user
TransModel = A Mazda but identifies itself as a BMW
Mazda6 Driver Mazda6 Driver is offline
Car: Mazda6
Smile 09-22-2021, 08:44 AM
It isn't finished yet. I think John getting more than 40 hp gain once it is finished and everything is stable. From what I am seeing right now this engine is making 300+ crank hp and 350+ lbs of torque with the jb4 which is impressive enough. this thing will be a mini rocket once it's finished. The mazda6's will be a fwd burnout machine as well.
Default 09-22-2021, 10:02 AM
The only things guaranteed in life are death and taxes.
But the dyno reflects what we've been able to make on the current mapping, and there is plenty more potential in the platform we're working on unlocking.
Mazda3turbskie Mazda3turbskie is offline
Car: Mazda 3 turbo
Default 09-22-2021, 11:11 AM
Does 91 Octane Vs. 93 octane make a large difference in the whp and wtq? Sadly cannot get 93 Octane where I live...
Default 09-22-2021, 11:23 AM
You'll make more on 93 than 91 but if 91 is all you have you'll still make a lot more power than stock with the JB4. Maybe you have E85 access to mix in? That gives you > 93 octane performance.
eXult eXult is offline
Car: GTI MK7.5
Default 09-22-2021, 12:31 PM
Is the JB4 for this platform undetectable like on a MK7 GTI? I've previously had a JB4 for my MK7 GTI and interested in this for my wife's 2019 Mazda3 AWD Turbo.
Default 09-22-2021, 01:34 PM
Yes no trace left behind when removed.
Default 09-22-2021, 04:30 PM
Will I still be able to pass the NY annual inspection when I have the JB4 installed? Will it affect emission? Btw just got my JB4 today.
M3TH user
joehinvt joehinvt is offline
Car: 2021 mazda3 hatchback 2.5 turbo
Default 09-22-2021, 04:48 PM
You'll be fine......Just don't say anything and they won't ask anything....... If you're seriously worried just disconnect it during inspection
tymwalk tymwalk is offline
Car: 2021 Mazda CX-5 Turbo Carbon Edition
Default 09-24-2021, 04:29 AM
Yes, the video referenced is terrible. For the CX-5 owners that are dead set on not removing the bumper, the video is explaining that to the right of the MAP sensor is a plastic air dam that is removable. That will allow you to reach into the MAP sensor from the intercooler opening in the front bumper.
Having removed the plastic air dam with the bumper off, there is a real chance of damaging the rivot that holds it in place. I like to keep things installed cleanly so I opted for the bumper removal so I wasn't cramped or pulling rivots out without a proper tool and angle.
Default 09-24-2021, 06:06 AM
Do we need to disconnect the batteries during installation?
M3TH user
AR185163 AR185163 is offline
Car: CX-5
Default 09-24-2021, 06:16 AM
We don't want anyone to play with custom tuning yet in it. Just run map1 or map2.
On E85 just add in say 4 gallons rest pump and enjoy, will make more power on both map1 and map2 vs. pump alone.
Terry, does adding E85 also apply to the CX-5 in regards to making more power?
Default 09-24-2021, 06:23 AM
No, have you been able to locate the installation instructions on the product page? They are very informative.
Default 09-24-2021, 06:25 AM
Do you have 93 octane available to you? If yes, then it isn't worth the hassle of mixing to E30. If you only have 91 octane available then it is worth the effort to mix to E30.
That is only my opinion as a CX-5 owner.
Girthbrooks20 Girthbrooks20 is offline
Car: Mazda3 Turbo Hatchback PP
Default 09-24-2021, 06:47 AM
For those running the Mazda3 tuner make sure fuel bias is set to 25 across the board, that is currently used for the MAF offset strength. For CX models without MAF control the setting isn't needed but won't hurt.
I've seen a few Mazda3 logs with those settings all at 0 which would limit your performance.
I just want to make extra sure before I go changing anything, I should be putting 25 in each of the lines on the fuel bias column? Everything is blank on mine right now.
Car: CX-5
Default 09-24-2021, 07:47 AM
Thank you for the input. No 93 where I live but there's an E85 pump around the corner from me.
Default 09-24-2021, 08:00 AM
Yes on your fuel bias question. It is weird that everything is blank though ...
Even your settings below the table is blank. This is confusing
hello_marco hello_marco is offline
Car: 2021 Mazda CX-30 Turbo Premium Plus
Default 09-24-2021, 12:56 PM
anyone have any pics of their install?
mine just feels like a mess.
i'm new to this so please let me know if there are any issues here also lol
Default 09-24-2021, 01:01 PM
Huh, well that doesn't make me feel too good lol.
