Murg31 Murg31 is offline
Car: E91 335xi
Default Stock Logs, Preparation for more Mods - 09-21-2021, 05:00 AM
Hi all!
First and foremost: Thanks for this extensive collection of knowledge called N54tech. Really helped me a lot to understand stuff and get further with issues!
I am in the process of learning how to be a DIY-mechanic with my E91 335xi. Step by step I want to go from all the preventative maintenance items up to tuning the car.
So far I did the following work:
  • Walnut blast
  • Vacuum Lines
  • Changed all fluids
  • Installed JB4 G5 ISO + JB4 Mobile (pretty neat to have the gauges in the headunit!)
  • Gaskets: OFHG + everything on Intake side
  • RB PCV Valve
  • 5" Intercooler
  • Modified Fan Shroud
  • Aluminium Coolant Flange
For now I just wanted to test the logging functionality and do some stock runs in order to rule out any major flaws. Since I dont have much experience yet, I hope you could take a look at the data and tell me if it has been done right!
What I found out so far:
  • Unfortunately I forgot to enable all cylinder logging, so only ign_1 is available in these logs
  • When I tried out Map 1, the car had misfires on cylinder 6 as soon as boost has surpassed stock levels. I suspect the coils since they are stock with 115k miles
  • There is an occasional hickup in idle, which didnt go away after walnut blasting. I suspect it might also be due to the faulty coil.
  • Even on stock boost levels, there are ignition drops on cylinder 1. Can this be caused by the issues with cylinder 6?
There are 4 log files. 1 (I hope) clean WOT run in 3rd, then a grouped log (should include a good run at the end), a log in idle and a log with Map 1 which was aborted due to misfires.
Alrght, enough text. Here are the logs:
File Type: csv P32_M1_R1_210920_192028_Map1Misfire.csv (36.6 KB, 15 views)
Steve @ BMS/Fuel-It! Steve @ BMS/Fuel-It! is online now
Default 09-21-2021, 07:07 PM
We can't do much for your misfires...that's something you have to systematically troubleshoot via hardware (plugs, coils. injectors, etc.). Nothing other than the misfire stands out as an issue in the log.
Car: E91 335xi
Default 09-21-2021, 10:07 PM
Hi Steve.
I know that I have to sort out the misfire issue to move further, I have a set of Index 12 injectors and new coils on the way and can't wait to put them in
However I am happy that nothing else seems to stand out. Thank you for taking a look!
Best regards from Bavaria
