Boostl33k Boostl33k is offline
Car: 2013 Gen 3 Jetta GLi
Default AFR readings - 03-09-2018, 01:21 PM
I am curious as to if anyone else has seen this.
I should start by saying I have a 2013.5 Gen 3 Jetta running a JB4 on map 1.
When running at WOT my AFR is showing in the high 3's like 3.7, 3.8 on the JB4 display gauge.
When idling or cruising its doing what it should and trying to keep the car at 14.7 so it's bouncing around near that number.
I do believe I have the AFR wire hooked up properly. The red wire on the in the harness on the firewall.
Default 03-09-2018, 02:37 PM
The AFR will only run rich like that if the car senses a issue with something like exhaust gas temperature to high or potentially a stored O2 fault of some kind. If possible grab a log and shoot it over to George@burgertuning.com and I can have a look.
2017 Audi 8V RS3 Sedan
2018 Polo GTI
Default 03-09-2018, 03:33 PM
I will try to get a log tonight and send it over to you. Thanks!
Default 03-10-2018, 07:06 PM
Scratch this.... I think it was just a fluke.....last night and today it's reading as it should.
