e36bmer e36bmer is offline
Car: 2011 135i
Default S55, Pure S2 turbos - No boost after hard pulls - 07-16-2020, 11:01 AM
Hi, I have an S55 with Pure stage 2 turbos. First, I feel like the turbo lag is way more than I would expect. Second, it keeps going into a limp mode with no boost when I do a hard pull, but I get no codes thrown or anything. When I power off and on, then things go back to normal until the next time I floor it. I would appreciate any help on the topic. I don't see anything jump out to me in the logs or in the stock ECU. I've updated to the latest firmware. I also hooked up MHD to try to see if this car has a BEF or some other tune on it already.
Can I get some help to see if there is anything I can look into to fix this?
2013 X5M - MCB/Black, JB4, Dual CM10 Meth, Velos Stage 2+, Kinugawa Compressor Wheels (Mine)
2011 135i - AW/TerraCotta, JB4, MHD BEF, FBO, DCT (Wifey)
2005 M3 - Interlagos Blue / Black ZCP, all kinds of goodies (Toy)
Default 07-16-2020, 11:30 AM
What fuel, mods, etc? Boost itself seems fine.
Set duty bias to 50 across the board, pid gain to 20
Car: 2011 135i
Default 07-16-2020, 11:39 AM
Do you see in the second pull where boost drops to essentially nothing but target is still the same at 22 or so?
Running 93 pump., Bms intakes, BMS charge ***** (but stock j pipe), JB4, free flow VSRF dowpipes, Akrapovic full exhaust, CSF intercooler and heat exchanger.
