Big_twins_z4 Big_twins_z4 is offline
Car: 2010 bmw z4 sdrive35i
Default First time log submission for review - 04-12-2021, 09:00 AM
I have a 2010 z4 with the following mods.
Pure turbo stage 2 DD
2 inch silicone inlets
Dual cone intake
Precision raceworks ignition
Stepped wagner FMIC
FTP charge pipe
Turbosmart diverter valves
1 step colder plugs
High flow catted *********
Eisenman race exhaust with secondary *** delete
Jb4 with your backend flash and settings for hybrid turbos
I am running 92 octane, and use this car as a daily driver.
I have 2 3rd gear pulls with the traction control and kickdown turner off attached. Running map 2, but i am getting overboost and kicking into map 4. Looking for adjustments. Thanks.
Default 04-12-2021, 09:21 AM
You're getting some overboost at tip in. You may need to adjust your duty biases a bit lower in that RPM range...maybe start with 1500 set to 42 and scale up by 2 and drop your FF to 80.
Default 04-12-2021, 09:36 AM
Thanks, i will make the adjustments and record a new log.
Default 04-13-2021, 09:08 AM
Here is a new log with the recommended changes. It didn't kick into map 4. Awaiting you wisdom.
Default 04-14-2021, 10:05 AM
Okay, still overboosting a bit...try dropping FF to 50 and see how that looks.
Default 04-15-2021, 09:09 AM
New log with ff changed to 50.
Default 04-15-2021, 09:12 AM
Forgot to attach log.
Default 04-15-2021, 09:28 AM
That looks better.
Default 04-15-2021, 11:30 AM
Should i just run it for a while and see if i kick into map 4?
Default 04-16-2021, 09:11 AM
Hopefully that won't be the case but yes.
