Roopj Roopj is offline
Car: 2017 Ford Raptor
Default Hard shifts with Map 1 and above - 03-08-2020, 06:30 PM
I've only had my JB4 for a short time on my 2017 Raptor but I have a problem with the transmission every time I change from Map 0 onward. I start having HARD shifts that almost seem like slipping between gears 1-3 and 6-8. I've jumped between Map 1 and Map 3 and I get the same effect. When I move back to Map 0 the problem goes away. 40K miles and runs on 93 octane regularly.
Have you encountered this problem before or know of a way to fix it? I like the gains I get but the hard shifting I can't handle.
Thanks in advance.
Default 03-09-2020, 11:03 AM
Are you on update firmware?
Is your OBD2 plugged in correctly?
Default 03-09-2020, 05:25 PM
Yes I've got the OBD plug in firm and I've recently updated to the newest firmware (ver 8 i think)
Default 03-09-2020, 09:28 PM
When you can lets see a log on map1 to see if that sheds any light on the issue.
Default 03-11-2020, 06:48 PM
Attached are logs from Map 1 and 3. I'm hoping it's not something with the transmission as I've seen problems with it on this forum.
Default 03-11-2020, 06:50 PM
oops, Map 1 was too big to be attached. Here's the link for it on my gdrive:
2020-03-10 17_05_25_Map-1.csv - Google Sheets
Default 03-14-2020, 04:34 PM
Hi - any updates after reviewing the 2 outputs?
Default 03-23-2020, 04:07 PM
Can anyone help? Been waiting a while now
CobraPower CobraPower is offline
Car: 2020 3.5 EcoBoost
Default SO? Ever get them to reply? - 03-04-2021, 07:16 PM
So how are things?
Default 03-04-2021, 07:41 PM
Every once in a while I notice a hard shift but it's irregular. Are you in sport mode? That seems to shift more abruptly.
When you post logs, upload the actual log to this site, nobody will click on links due to concerns with those.
