Maniac0908 Maniac0908 is offline
Car: 07 BMW 335xi JB4 G5 DP DCI BOV
Default 2012 335is DCT - 09-15-2019, 05:59 PM
Hello, Iv been chasing an issue with my buddies 335is. At max it would bog bad and switch from map 2 to map 4. Last safety was 2(lean). LPFP was going low so we swapped in a stage 2 and looks good now. Iv been reading through terryís posts with the 335is dct. Today I flashed the INA0S PUMP flash. I got it from the zip file on here that has all the BEFís. Iím hoping it was the right/best BEF he can use. Or should I have used a MHD one? I attached a log. Can someone verify that I have all the settings correct and that the car is running good? Avg ignitions seems a tad bit high right? And if thereís a better BEF I should be using please let me know. Thanks for the help.
2007 335XI SEDAN // ACF/VM 6266 SINGLE TURBO// MMP PORT INJECTION // VRSF CP W/ TIAL BOV // XHP 6AT FLASH // MOTIV TUNED // BMS OCC // VRSF EXHAUST // DIY STAGE 3 LPFP// VRSF FMIC //
Default 09-15-2019, 09:46 PM
This looks to be the correct flash, so no worries there
What are you using for fuel? Timing in general doesn’t look great- I’m assuming just 91 or 93 oct?
Default 09-15-2019, 10:20 PM
What are you using for fuel? Timing in general doesnít look great- Iím assuming just 91 or 93 oct?
Ya just 93. Could plugs or coils have anything to do with it?
Default 09-15-2019, 10:27 PM
Plugs depending on age / which ones?
Default 09-16-2019, 10:46 AM
Heís going to swap in the 2 step colder ngkís. Do you think he should drop to map 1? Iím trying to replicate what terry did on the dyno with the 335is. I just canít seem to figure out the exact bef he used and jb4 settings. Hopefully he chimes in.
Default 09-16-2019, 12:45 PM
2 step colder- Gapped to .020
Default 09-17-2019, 03:51 PM
Ok he ordered them. I forgot to ask. For 335is. What should fud be set to? Looks like itís set to 5? Which does something to Avg ingnition? Could you please look over the settings. Thanks!!
Default 09-18-2019, 03:33 PM
And also need to know what number to put for 6cyl timing logs. Have it set to 7 right now.
Help me Terry Won Kenobi, your my only hope.
Default 09-20-2019, 11:59 PM
Bump
Default 09-21-2019, 02:19 PM
Hereís another log after changing plugs.
THE BEAST's Avatar
Car: 2008 E93
Default 09-21-2019, 03:43 PM
Need better fuel. Ur timing sucks Bawlz.
Default 09-21-2019, 03:58 PM
I know man.... I donít get it. Itís shell 93 with octane booster..... so I just realized something. When we flashed the bef, we did flash a custom tune instead of flash a jb4 backend..... does it make a difference?
THE BEAST's Avatar
Car: 2008 E93
Default 09-21-2019, 04:10 PM
No difference. Lower boost and see if timing cleans up.
Default 09-22-2019, 03:39 AM
Ok will do. Letís say it does fix it. Whatís next? What should we try to be able to go to higher boost?
Default 09-22-2019, 04:21 AM
Also, do IAT look ok? Seems like they jump 30 degrees? Would this cause timing?
THE BEAST's Avatar
Car: 2008 E93
Default 09-22-2019, 09:27 AM
More / Higher octane.
THE BEAST's Avatar
Car: 2008 E93
Default 09-22-2019, 09:29 AM
FMIC wouldnt hurt, but its not the root of timing corrections. Corrections are being made even at lower IATs.
Default 09-22-2019, 09:36 AM
Ok thanks man. Just curious, why is it that this car requires a higher octane? Whereas others that are identical will be fine. Is it something internal?
Also can you look at the jb4 settings? Does everything look ok? Should we raise or lower fol? Or anything else like that?
THE BEAST's Avatar
Car: 2008 E93
Default 09-22-2019, 09:42 AM
Humidity, elevation, ambient temps, all play a part. Unless you have another car identical and in the same town thats running better, you cant really compare. Also, gas stations can vary from 1 location to the other. Meaning try a different brand and see if any changes in logs. Ill text you in a minute.
JMVela's Avatar
JMVela JMVela is offline
Car: 335is
Default 09-23-2019, 05:37 AM
Add a meth kit my friend. It will help a lot.
2012 335is DCT 719.9 WHP MMPs BB turbos 93 oct pump gas + Meth. Trebila tuned.
deltalima0's Avatar
deltalima0 deltalima0 is offline
Car: 07 BMW 335
Default 09-23-2019, 04:01 PM
It always does on my 335is. I have flashed it custom and it barely will boost to 15 psi. I always flash the backend now, and i have zero issues. Take the two minutes and flash it as a backend see if it helps.
2011 335is DCT
Pure Stage 2 Hi-Flo Turbos | PSP outlets | RB Inlets | Wagner Evo 2 intercooler | Wagner Dpipes's | JB4 G5/MHD| Precision Raceworks Coils |PFS Bucketed Double shot LPFP | Phoenix Charge Pipe with Tial BOV | JB4 G5/MHD | BMS DCI's
RIP 2007 E90 335i
Doc Race 6266 Single Turbo | TFT Charge Pipe | JB4 G5/MHD | FuelIt stg 3 LPFP | Cpe/BMS PI | 100% E85 | DSS Axles | Cpe FMIC | Tial BOV
N54 World Record ET: 10.721 | Best MPH 130.92
Default 09-23-2019, 05:11 PM
It is the backend, sorry that was confusing. I meant that in mhd we selected flash a custom tune and used the jb4 backend instead of flash a jb4 backend.
deltalima0's Avatar
Car: 07 BMW 335
Default 09-23-2019, 05:21 PM
Yes via MHD, for some reason it makes a difference on my 335is custom vs backend flash when i flash the jb4 BEF. I always flash the JB4 BEF using flash a backend map.
2011 335is DCT
RIP 2007 E90 335i
Default 09-23-2019, 05:31 PM
Ok Iíll have him try that. Are you dct?
deltalima0's Avatar
Car: 07 BMW 335
Default 09-23-2019, 05:35 PM
yes
2011 335is DCT
RIP 2007 E90 335i
