inline6xi inline6xi is offline
Car: 2008 bmw 535xi
Default Knock Talk ['08 535xi pure stage 2 running e30] - 02-05-2020, 09:27 PM
So recently i've been getting a knock code, 2E69. I'm FBO with pure stage 2 turbos EXCEPT intercooler. still on stock intercooler. MHD race BEF with jb4.
so the strange thing is, I've NEVER gotten a knock code during or immediately after a pull. it has only happened when cruising on the freeway. the first time it happened, i had been driving on the freeway for about an hour, and it threw the following codes:
2E69 Knock sensor signal
29E0 fuel mixture control
2B28 DMTL micro leak
3100 low boost mode engaged
I have since gotten the knock sensor signal, however, the fuel mixture stuff hasnt come back since. After reading up I've written it off to running e30.
I've been mainly running Jb4 in map 5 since first knock event. first knock event was map 6, 20 psi max target.
I am really at a loss, because I log all my pulls and nothing stands out. Ive even tried to log on the way home from work and 'catch' it throwing a knock code but nothing yet.
this has left me with a few questions about knock in general:
1. if the engine knocks, will it immediately throw the code and go into low boost? or can it happen minutes later?
2. knock can happen at different intensities. To throw a knock code does the knock need to be fairly strong or violent?
3. what should I be looking for in logs to indicate a knock event?
thanks so much for help guys!
Edit:
Very interesting thread on knock code types and bad cam causing knock code:
2e69 code
fn42 fn42 is offline
Car: 2008 335xi
Default 02-06-2020, 08:44 AM
which BEF are you running? the bms ethanol one on 20PSI might have timing that is too aggressive for e30
335xi sedan 6mt / MMP 1k turbos / MHD FlexFuel + AIC6 PI / South Bend Stg3 clutch
535xi wagon 6mt / ebay 17t / FBO
Car: 2008 bmw 535xi
Default 02-06-2020, 08:46 AM
Good question, I should have stated.
MHD Race BEF.
Car: 2008 bmw 535xi
Default 02-06-2020, 05:01 PM
just came across this thread. god I hope this isnt the case.
N54: Knock sensor bank 1
Car: 2008 bmw 535xi
Default 02-08-2020, 05:57 PM
bought a new knock sensor, installing today.
Default 02-08-2020, 08:58 PM
Curious what happens here..
Hoping for the best for you
Car: 2008 E93
Default 02-08-2020, 10:54 PM
Edit:
2e69 code
I think you will be fine. Generally if a cylinder knocks, it shows which cylinder in the code. Seems more like the signal from the sensor is bad. So a code for bad sensor is what I would think you are seeing. Although I havent specifically looked up that code.
Car: 2008 bmw 535xi
Default 02-09-2020, 02:47 PM
got another knock code this morning, with new sensor. I'm installing INPA on an old laptop so I can get more info on this.
Car: 2008 bmw 535xi
Default 02-16-2020, 03:15 PM
So I am still getting knock codes. This is usually happening during light load, 2-3000 rpm and not under much boost, usually 1-4 Psi. I've never had this code under heavy boost, pulls etc.
Freeze frame data using INPA was at 2200 rpm, 4.7 V.
I inspected all of my plugs, and they all look almost new (replaced 4000 mi ago) except cyl 4 plug is fouled and smeeled like fuel. So, I inspect my injectors and they are all index 8 or 9 EXCEPT cyl 4 injector is index 7. Coincidence? I don't know.
I'm thinking that I need new injectors, or possibly just replace the one injector for cyl 4.
Thoughts?
Default 02-16-2020, 10:52 PM
At minimum id replace the cyl 4
