fn42 fn42 is offline
Car: 2008 335xi
Default mmp 1k tuning boost - 07-31-2019, 08:48 AM
the duty bias & FF tuning thread has been pretty helpful but I still can't get the boost to come in smoothly - do I need to be increasing duty bias under 4K RPM more?
thanks!!!
335xi sedan 6mt / MMP 1k turbos / MHD FlexFuel + AIC6 PI / South Bend Stg3 clutch
535xi wagon 6mt / ebay 17t / FBO
Default 07-31-2019, 10:56 AM
thanks!!!
Can you define smoothly a bit more?
I see your over target a bit around the 4k mark- you could LOWER duty bias a bit to keep that closer to your target.
Car: 2008 335xi
Default 07-31-2019, 11:04 AM
after it stops spooling it drops a few lbs and then goes a few lbs over target, you can really feel the 5psi change. thanks for the feedback, I'll pull some out above 4k and see how it does
Default 07-31-2019, 02:40 PM
Yeah, drop it down in the suggested areas, then do 2-3 WOT pulls. Let car adapt a bit & then relog.
We can adjust more from there.
