steve30's Avatar
steve30 steve30 is offline
Car: E36 M3, E90 335i
Default Bosch 4 bar TMAP - 04-07-2017, 03:42 PM
I'm having a really hard time finding this sensor.. I've ordered the adapter harness from BMS but can'd find the TMAP itself on the site. I found Terry's post where the had a kit for either the 3.5 or 4 bar sensors and adapters but can't find it on the site. Where can I order this sensor from? I search and all i find it aliexpress and Asian websites and I'd like to avoid buying a knockoff sensor.
N54QC N54QC is offline
Car: 07 BMW 335i
Default 04-07-2017, 04:02 PM
The 3.5 sensor part# 13627843531 and the 4 bar sensor is 281002576 as per there site. Plug part number into google and you should have no problem finding one.
steve30's Avatar
Default 04-07-2017, 04:17 PM
I know the part# but like I said when I google it the websites that come up are selling knockoff sensors. There is this thread: http://www.n54tech.com/forums/showthread.php?t=36457
It says there is a kit in the upgrades section for $99 for the sensor and adapter. I only see the adapter in that section.
Default 04-07-2017, 05:33 PM
We stopped selling the sensors as batch to batch the quality varies a lot. I think somehow counterfeit ones were getting slipped in to our shipments. I kept enough on hand to replace anyone who bought one from us and winds up needing a replacement free of charge. And we are done selling them.
We will continue to sell the adapter ala-cart for those who want it and are looking in to more reliable 4bar-5bar alternatives. The bad news is they will likely be much more expensive.
Impac's Avatar
Impac Impac is offline
Car: 2008 BMW 535i
Default 04-07-2017, 07:49 PM
I got mine 3.5sensor from the dealer
JB4 G5, DCI, Er CP with HKS Bov, VRSF DP's, BB Race flash
Venom77's Avatar
Venom77 Venom77 is offline
Car: 335I
Default 04-08-2017, 12:21 AM
I had a 4bar, I had issues, I bought a 3.5bar and installed it, Issues were solved.
Just get a 3.5bar.
Garrett Gtw 6465, Supporting mods , Mhd/Jb4
brendan's Avatar
brendan brendan is offline
Brendan
Car: 335i 2007 6spdman
Default 04-08-2017, 02:06 AM
Im currently replacing my 4 bar sensor to a 3.5 bar due to issues.
weebles weebles is offline
Default 04-08-2017, 10:35 AM
I just installed my bosch 4 bar which I ordered from BMS last night. How can I tell if it's no good? Any tell tale signs to look for with the counterfeits?
Torgus Torgus is offline
Default 04-08-2017, 01:18 PM
As I have had 1 4 bar fail already I wonder if I should just get the 3.5. I also keep getting 2ABD code errors but I think my tune can fix that. Or so I have hesrd.
Got Boost?
Default 04-08-2017, 02:57 PM
Seems like most of the people who have problems with the 4bar are trying to run flash only. The flash tuners have not figured out how to implement the same sensor scaling we have on the JB4, for some reason.
Default 04-08-2017, 02:58 PM
If you get a 2ABC fault shortly after installing it then its faulty. They normally die quickly if they are going to. Normally if they are working OK they stay working and I've got plenty of spares for anyone who needs one. I have not found a way to tell which is counterfeit and which is real so decided to just stop reselling the sensors all together.
Default 04-08-2017, 06:10 PM
Cool, thanks Terry. So far so good with mine, I've put on a couple hundred KM of light driving (breaking in clutch) with no issues yet.
BuraQ's Avatar
BuraQ BuraQ is offline
Car: 335is DCT
Default 04-08-2017, 08:10 PM
Did you stop selling the N20 3.5bar adapter ?
2011 E92 335is w/DCT
2007 E92 335i 6AT
Default 04-08-2017, 08:27 PM
Nope, it's on our website as it's always been. N54 upgrades page.
BuraQ's Avatar
Car: 335is DCT
Default 04-08-2017, 08:33 PM
Thats why I asked cause I did do that and couldnt find it, but I think I saw what was done its on the same click with the 4bar with a drop down whereas before they were separated
2007 E92 335i 6AT
Default 04-08-2017, 08:39 PM
Yes they have the same area, with a drop down.
http://www.burgertuning.com/N54_JB4_upgrades.html
JB4 3.5bar and 4bar plug and play TMAP adapters
Use these plug and play adapters to quickly adapt a 3.5bar or 4bar
TMAP sensor to your N54, raising the boost maximum boost range from
20psi factory up to 36psi for the 3.5bar and 43psi for the 4bar. For
most applications the 3.5bar adapter is suggested which requires OEM
BMW sensor part number: 13627843531. For very high boost applications
the 4bar adapter can be used which requires Bosch 4bar sensor part
281002576.
Helio324 Helio324 is offline
Default 04-28-2017, 10:24 PM
Does the 3.5 bar and 4 bar sensor use different adapters? I have an adapter for the 4 bar and planning on installing a 3.5 bar and just confirming if I have to buy a different adapter also.
Car: 07 BMW 335i
Default 04-28-2017, 10:59 PM
Yes, different adapters
samstryker's Avatar
samstryker samstryker is offline
Car: 2008 535xiT e61
Default 04-29-2017, 01:12 PM
I have a brand new 4 bar for sale if interested
2008 e61 535xit: VTT GCs, Fuel-it PI, fuelab FPR w/ return line, stage 2 lpfp, fuelab "700" inline pump, RB external PCV, VRSF 7.5" race FMIC, Inlets, outlet, AR ***, 3" chargepiping, 3" exhaust, JB4, BMS PI controller
Mixmaster Mixmaster is offline
Car: 2007 335i E91
Default 05-01-2017, 12:11 PM
Often on startup I throw 2ABD Boost pressure sensor overrun. I clear it and all is good. I have had my 4 bar for about a year but this has only recently started. Its it likely a faulty 4 Bar?
Tony@VargasTurboTech's Avatar
Tony@VargasTurboTech Tony@VargasTurboTech is offline
Car: Anything with a Turbo
Default 05-01-2017, 12:55 PM
Good to see Terry finally gave in, and accepted the 4 bars from Bosch were nothing but a bunch of trouble. Its not just the N54 either, on the ecoboost platforms 2 different manufactures starting having their own made due to issue with the 4 Bars, namely poor idle characteristics, and variance between sensors. Honestly never really got this big infatuation with the 4 bar sensors on this cars. Not many are running more than 36 psi, yet they would throw a 4 bar on it, and lose resolution. At this point if more than a 3.5 bar is needed just get a vacuum block, and run an AEM 5 bar.
Vargas Turbocharger Technologies
Tony@Vargasturbo.com
www.Vargasturbo.com
Making the world happier one turbocharger at a time
Default 05-01-2017, 03:21 PM
That is likely a software setting. Email me for the latest JB4 firmware to see if it helps. If not we'll replace the sensor for you.
Maniac0908 Maniac0908 is offline
Car: 07 BMW 335xi JB4 G5 DP DCI BOV
Default 04-29-2019, 04:14 PM
Is 4 bar codes and stuff all fixed?
2007 335XI SEDAN // ACF/VM 6266 SINGLE TURBO// MMP PORT INJECTION // VRSF CP W/ TIAL BOV // XHP 6AT FLASH // MOTIV TUNED // BMS OCC // VRSF EXHAUST // DIY STAGE 3 LPFP// VRSF FMIC //
Default 04-30-2019, 12:07 PM
We are using authentic Bosch 4 bar sensors, so no issues at all.
we've sold hundreds
