Go Back   N54Tech.com - International Turbo Racing Discussion > Model-Specific Engine Tuning & Modification Discussion > N54
Reload this Page Turbo Poll
View Poll Results: Which turbo would you go with?
Vargas N54 "GC" Stock location 16 19.28%
Pure N54 Stage2 29 34.94%
RB Super RB EVO 5 6.02%
MPP Stage 3 12 14.46%
Motiv Single Turbo Kit XR 95-67 21 25.30%
Voters: 83. You may not vote on this poll
jasonnevis jasonnevis is offline
Default Turbo Poll - 11-18-2016, 05:34 PM
My stock turbo's are rattling so bad, I'm look for new turbo's that if I choose can give me huge power, reliability as car is used as a daily. Future proof option to achieve big power if wanted together with fueling.
Pure N54 Stage2
RB Super RB EVO
MPP Stage 3
Other considerations:
-Support
-Warranty
-Ease of installation
-Longevity
-Low RPM power
-Price
If I've missed an option let me know.
Stevie Stevie is offline
Car: 2008 BMW 535XI
Default 11-18-2016, 05:40 PM
Pure N54 Stage2
RB Super RB EVO
MPP Stage 3
Pure or mmp will be your best bet.. the new GC are looking promising.
J.J4ck0wsk1 J.J4ck0wsk1 is offline
Car: N54 335i FBO Meth
Default 11-18-2016, 05:56 PM
On a side note I adjusted my wastegates which have never been adjusted before and my rattle is now 90% gone. The back one is cake, the front you can shim the actuator bracket with washers by removing the vacuum canisters, radiator fan, and front inlet. I dreaded adjusting the turbos, but it was actually easy and well worth it. At least for now..
Otherwise I'm waiting for mmp cast versions, hopefully in the next 6 months or so!
08 E92 335i Alpine White On Coral Red 6 Speed
BMS DCI+Aquamist METH Kit+MHD+VRSF+AR25 Resonators+HPF IC+AA CP+AA BOV+SSK+KWV1+Mfactory SMFW+550i/335is Clutch+BBS LM Reps+Diff Brace+M Performance Shift Knob+RB PCV+HPF OCC+NGK
Mustang Dyno: 426whp/484wtq on E30/Meth/Stock Inlets+Outlets/Procede Only @ 18psi
Current Estimate: 450/500 on E50 Custom EDC Tuning MHD Flash @ 21psi
Default 11-18-2016, 06:49 PM
Hybrid Twins: Vargas GC
Bottom Mount: Motiv
Top Mount: VM/ACF
Young_Man Young_Man is offline
Car: E90
Default 11-18-2016, 07:14 PM
GC's here with no complaints so there's my vote lol
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 11-18-2016, 07:16 PM
Pure or single
Newguy123's Avatar
Car: 12' 135i
Default 11-18-2016, 07:25 PM
Pure all day :P
18’ Glacier white RS3
#PURETURBOS
#FUELIT
Default 11-18-2016, 09:02 PM
Reliability and alot of power usually don't go together. I personally would go with pure and stay in the low 23psi range to keep everything safe, sure it won't net u the 600whp,but at the same time you will be alot safer at 23psi vs 27psi..just my opinion
2007 e90 335i
Hexon turbos
Fbo with Cpi tuned at e55
Jsr Custom tuned
Venom77's Avatar
Venom77 Venom77 is offline
Car: 335I
Default 11-18-2016, 10:34 PM
Top mount with a Garrett Gtw turbo imo
Garrett Gtw 6465, Supporting mods , Mhd/Jb4
Car: 2011 e92 335i
Default 11-18-2016, 11:15 PM
This, you don't need to max it out to have a fun reliable setup.
Immoralus's Avatar
Immoralus Immoralus is offline
Car: 2008 335xi
Default 11-18-2016, 11:19 PM
I'm looking to whatever will yield me the most hp all while letting me get atleast 50k out of the turbos... tall order I know.
08 335xi- JB4/Trebila,RB Inlets, VRSF CP ,FMIC, DP ,BMS DCI,e50 and Fuel-it Stage 2. 11.8 @ 118
Default 11-18-2016, 11:23 PM
Thanks for all your votes and comments so far.
I did forget two main options:
1. Hexon Hybrid 2 RR600
2. JP Workz Full Top Mount Precision Journal Bearing Kit
I know it doesn't make sense, power and reliability. The idea would be to run early 20's PSI for daily cruising. With the capability to do glory runs at higher PSI levels no problem. Just don't want the turbo's to be the bottleneck and have to worry about swapping them out if the power level isn't satisfying enough....
Car: 2011 e92 335i
Default 11-18-2016, 11:56 PM
Hexon's aren't an option currently
Venom77's Avatar
Car: 335I
Default 11-19-2016, 12:56 AM
When it comes to a topmount the what you gain between turbos is more spool and reliability over power. Every brand has one that will make the power you want.
bdhh's Avatar
bdhh bdhh is offline
Car: 2008 335i convertible
Default 11-19-2016, 06:53 AM
you forgot A&D engineering bottom mount.
Thats what I ordered. Better heat management.
2008 BMW 335i Convertible
ADE Bottom Mount 6062 Single
VRSF Charge Pipe & 7in intercooler Tial BOV,
Ign Project Plasma Coils & grounds
Robs High & low side Catch Cans with
head plugs.
Diff Brace, Fuel it stage 2 & Meth Port Injection
Aquamist HSF-4 Meth injection
Alpina Flash
BMW PE Mufflers
MDH Flash
Line lock & 16in Drag Radials
11.7 ET, 1.8 60ft, 122mph
Default 11-19-2016, 01:35 PM
Two of the worst companies in this market lol.
FWIW, I've had my VM top mount for over 50k miles as a DD since Apr 2014. I would take it anywhere. Camping trips, Vegas, etc, all over 250+ miles each way. No issues ever at all.
brendan's Avatar
brendan brendan is offline
Brendan
Car: 335i 2007 6spdman
Default 11-19-2016, 05:39 PM
2 worst campaniles available currently. One does not even exist anymore and one is shady as
vitan's Avatar
vitan vitan is offline
Car: e92 N54 335i
Default 11-20-2016, 06:03 AM
Bottom Mount: Motiv
Top Mount: VM/ACF
+1
07 335i
Socket's Avatar
Socket Socket is offline
Default 11-21-2016, 01:51 AM
My Pure Stage 2 looks like they are rattling and smoking in under 12 mnths on 19 psi...
alvinhobh alvinhobh is offline
Car: 07 BMW 335i Coupe
Default 11-21-2016, 06:58 AM
Also depends on how efficient your system is. For example, If your FMIC drops 5-10 psi, its an added stress on the turbos, making them worker harder to target a certain psi. The reliability of a turbo is a direct correlation to your supporting mods.
07 335i e92 - money pit
Impac's Avatar
Impac Impac is offline
Car: 2008 BMW 535i
Default 11-21-2016, 01:25 PM
What !!! Pure turbos are smoking??? I was about to order Stage2 and I see this WTF.
JB4 G5, DCI, Er CP with HKS Bov, VRSF DP's, BB Race flash
Newguy123's Avatar
Car: 12' 135i
Default 11-21-2016, 01:54 PM
If this is truly the turbos they offer a 1 year warranty send them in and have them checked, lots of things besides turbos can cause smoking on the n54!
#PURETURBOS
#FUELIT
500hp500tq 500hp500tq is offline
Default 11-22-2016, 07:31 AM
Don't think RB is making EVO's anymore, after speaking with him i went ADE bottom mount kit, hella simple!!
http://www.ad-eng.net/store/p25/AD_E...F335i_%29.html
|2008 135i N54 | VRSF FBO| Motiv Port Injection | BMS PI Controller| AD-E ST Kit 6062 | JB4 G5 ISO 13.0 | BMS ST/MHD E85 Flash | 60% e70 | Fuel-It Stage3 LPFP | Spec2+/SMFW |3.5 TMAP | NLS
"stock"
illtww illtww is offline
Car: 525i
Default 11-23-2016, 07:25 AM
What does MMP "CAST" get us?
Cory S's Avatar
Cory S Cory S is offline
Car: 2011 335i-X
Default 11-23-2016, 06:04 PM
Installation issue....
