(#1176)
Skilly Skilly is offline
Car: 2012 535i bmw
Default 11-01-2020, 09:51 PM
Aight thanks man I appreciate you
brooks1005 brooks1005 is offline
Car: 2013 BMW 335i
Default 11-05-2020, 04:41 PM
Originally Posted by MrHaloHalo
I've been using 9E60B_PUMP since last December and its been great. I just noticed that there is now (actually since Aug. 19 apparently) 9E60B_PUMP2. What are the changes in the new PUMP2 vs. the old PUMP BEF?
Did you get a response about the new file?
2013 BMW 335i Coupe M-Sport, BMS Intake,FTP charge pipe, JB4 Stg 2 w/BEF, Active Autowerke D**npipe, Rev9, XHP stg 3
Buzz@N55's Avatar
Buzz@N55 Buzz@N55 is offline
Car: BMW 335I 2012 E92 N55
Default 11-05-2020, 06:00 PM
I run the pump2 flash. Terry is the man to explain the differences between the two maps.
MrHaloHalo's Avatar
MrHaloHalo MrHaloHalo is offline
Car: 2014 X1 35i
Default 11-06-2020, 09:16 AM
I asked Terry and he just said there was nothing major as far as differences between the two BEFs. I've flashed PUMP2 but only driven about 40 miles with it. Can't really tell a difference, but I haven't got any logs yet.
Car: 2013 BMW 335i
Default 11-06-2020, 12:35 PM
I asked Terry and he just said there was nothing major as far as differences between the two BEFs. I've flashed PUMP2 but only driven only about 40 miles with it. Can't really tell a difference, but I haven't got any logs yet.
Thanks for the insight! Installing everything now.
N55Ferraro N55Ferraro is offline
Car: 2011 e92 335i xdrive
Default Jb4 flashing issue - 11-10-2020, 06:22 AM
Can anyone give me some help here, I set my jb4 to map 0 flashed Mhd bef 98G0B_PUMP.bin car starts fine when I go to switch my jb4 to screen 4/2 that works but when I put my jb4 map back to 2 my gauges bug out then the hazard light flash and my jb4 map is back on map 0 did I do something wrong? Itís like the jb4 and Mhd arenít on the same page.
kkusi1373 kkusi1373 is offline
Car: 2011 335i Xdrive N55
Default 11-11-2020, 01:08 PM
Hello,
I am new new here. Please forgive me if I post this question in the wrong place.
I have 2011 335i xdrive N55
I was wondering if someone can explain the difference between the JB4 BEF files pump_usa.bin vs Pump.bin?
I use 93 octane
Thank you.
Car: 2013 BMW 335i
Default 11-11-2020, 03:17 PM
Originally Posted by kkusi1373
Hello,
I use 93 octane
Thank you.
Go to the Support and Logs area and ask there. I'd be interested too. I flashed the 9E60B pump2 bin and it ran great.
Johnad8888 Johnad8888 is offline
Car: BMW 335 n55
Default Hybrid maps? - 12-08-2020, 01:20 AM
I'm not sure what maps are the "hybrid Turbo" maps when I download the file with all the maps? does anyone know which maps they are? I'm looking for the BEF map for PS2. Thanks in advance.
Car: guess...
Default 01-02-2021, 03:14 PM
Hey, now that I have my MHD/BEF/JB4 system up and running well, is it too late to try the MHD burble feature? I mean, can I reconnect my phone to the OBD2 port, toggle on the burble, hit flash and have it work?
andrews013's Avatar
andrews013 andrews013 is offline
Car: 2013 E92 335i xDrive
Default 01-02-2021, 03:51 PM
Yes, you can flash and change settings as often as you want. I have done it at least weekly since it came out a year ago for late E series.
2013 E92 335i XDrive
JB4, MHD E85 BEF, EOS PI, Fuel-it Stage 2 LPFP, XHP Stage 3, XDelete Sport, 3.5 Bar TMAP, VRSF 7 HD IC, GFB DV+, VRSF D/P, VRSF CP, PE Mod, ST V1 Suspension.
Juzzz Juzzz is offline
Car: 135
Default 01-10-2021, 11:09 PM
Firstly, solid thread. Thank you!
Im wondering which BEF file I need to use for running my N55e DCT on 98ron? Iím not currently running and xhp gearbox tune, but Iím considering it. Also will this need to change when I install a Pure stage 1 turbo (itís my daily) and fmic?
Buzz@N55's Avatar
Default 01-10-2021, 11:19 PM
You need to run the pump flash. The back end flash is based on the fuel used. I have the exact same N55 with DCT in a e92. The pump file is good for all pump fuels but can also go upto an e30 mix. I will eventually get the Xhp flash as I have heard great things about it.
Car: 135
Default 01-10-2021, 11:43 PM
Thanks Buzz@N55, there are quite a few pump files so I was hoping to clarify which one.
9E60B_PUMP.bin
9E60B_PUMP2.bin (this is the most recently updated)
9E60B_PUMP_THR.bin (from my reading this is if you have the xhp gearbox tune)
98G0B_PUMP.bin
98G0B_PUMP_135_DCT.bin
98G0B_PUMP_THR.bin
Buzz@N55's Avatar
Default 01-10-2021, 11:51 PM
9E60B_PUMP.bin
98G0B_PUMP.bin
98G0B_PUMP_THR.bin
What date was the build on your car? If before 03/12 98G0B if built after 9E60B
Car: 135
Default 01-11-2021, 12:31 PM
Build date is March 2013.
9E60B_PUMP2.bin looks like the latest version.
Buzz@N55's Avatar
Default 01-11-2021, 12:55 PM
If your in America use the 6E60B. PUMP.bin the PUMP2 is for eu car and removes the DTML function so you donít get codes for it. Terry did it recently for my car as Iím in Australia and get the euro speck bmws here
Car: 135
Default 01-11-2021, 01:54 PM
Thanks! I’m in Australia too.
I can’t wait to get the car dialled.
