(#551)
335togo's Avatar
335togo 335togo is offline
Car: 2011 M Sport E93
Default menu 11 - 02-02-2017, 11:14 AM
Originally Posted by diesel3443
Wow, firmware 14 and menu 11 set to 5000 just woke up the car. Its pulling like a freight train now and is much, much smoother.
to clarify ..what is the menu 11 adjustment and is that only for PS2 and/or stock turbo...can i do that from jb4 BT...thx
2011 E93 JB4 w/bluetooth, Fuel-it stage 2 pump w/line and ethanol sensor, VRSF down pipe, AR Intercooler
Peen Peen is offline
Car: 2011 BMW 335i
Default 02-02-2017, 12:52 PM
It's a pedal to boost target...
You do it with steering wheel controls. And yes, stock turbo or PS2
2011 335i / MHD E85 BEF / JB4 ISO / xHP Stage 3 TCU / M3 Control Arms / VRSF Piping/ Phoenix CP / YCW Coilovers 6K-18K / Enkei Raijin 18' Wheels / Michellin PSS
katsooba's Avatar
katsooba katsooba is offline
Car: 135i N55 DCT
Default 02-02-2017, 01:48 PM
may i have the EU spec backend flash?
i also have a technical support question regarding the JB4 hardware
i cant put my email here, so it is my user name @gmail.com
135i N55 / KW V3 / CP-E charge pipe / CP-E 5" DP / CP-E 7" FMIC / JB4 S2 / MHD / K&N inbox / Custom made 3.25" catback / Tons of other mods
Default 02-02-2017, 01:56 PM
Added the _EU spec files to the download in the first post.
335togo's Avatar
Default Menu 11 - 02-02-2017, 05:01 PM
Can you walk me through it as to how to get to it
Stoolz Stoolz is offline
Car: 11 135i
Default 02-02-2017, 10:44 PM
Sweet
mreik mreik is offline
Car: 2011 135i
Default 02-03-2017, 03:45 AM
Can anyone help a noob?
How do I "select mode 4/2 in dash so your JB4 knows you're running a BEF"
***^^^I just figured out that this is referring to the JB4 not the MHD flash.
Also, where are you guys changing the firmware and menu?
Thanks for any help!
Newguy123's Avatar
Car: 12' 135i
Default 02-03-2017, 05:08 AM
Select 4/2 by using your steering wheel, you download the newest firmware from the first page then load it to the jb4 using the usb cable or if using the jb4 app then bluetooth
18’ Glacier white RS3
#PURETURBOS
#FUELIT
Alpha Twins's Avatar
Alpha Twins Alpha Twins is offline
Car: E92-335i-N55-2011
Default 02-03-2017, 05:22 AM
I cant' find the _EU spec files in the first post ?
E92 335i 2011 N55 | JB4 G5 ISO | M Performance Exhaust | BMS DP | Wagner evo 2 comp Intercooler | BMS catchcan | BMS Chargepipe | MHD FLASH
Abdul Abdul is offline
Default 02-03-2017, 10:43 AM
Hii Terry! Where is the File ? And how can i choose burble the same like PP-Kit with MHD BEF?
Default 02-03-2017, 11:30 AM
Files are in the first post. On burble settings I think its flash time option setting.
sparky_phantom sparky_phantom is offline
Car: 2011 BMW 135i DCT
Default 02-03-2017, 11:37 AM
When you flash the tune there is a option right before the flash to do the exhaust burble. The setting I believe was called "Options". As far as I can tell you can get this option for BEF or just a regular flash with MHD.
Default 02-03-2017, 06:42 PM
Perfect i have it! But now another Question.. I had PP-Kit and now it changed with the BEF. What kind of settings i have to edit to get the same burble or the pop? I will exact the same -.-
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 02-03-2017, 06:50 PM
MHD says they use all the same burble tables as PPK.
Default 02-03-2017, 07:22 PM
What about the seconds ?
Car: 2011 e92 335i
Default 02-03-2017, 07:24 PM
They are adjustable with MHD, what about them?
Default 02-03-2017, 07:45 PM
Which is exactly the same like ppkit? and does sport work if i have mt ?
Car: 2011 e92 335i
Default 02-03-2017, 08:56 PM
The overrun tables that cause the burble are the same. They added duration for those that want it to last longer. IF your car has different drive profiles you can select how it behaves on each profile. Otherwise drive is what you want to use.
sorry if Grammer or spelling is off.
Default 02-04-2017, 02:29 AM
Also.. then if i use the default settings then it will be exactly the same? Burble is not soo important but the POP... only cause of them i will flash to stock to get it back..
ihazvanos ihazvanos is offline
Car: 2011 e92
Default 02-04-2017, 10:51 AM
For now you can only adjust how long the burbles last. they are super quiet. Eventually I think they will add a "burble intensity" setting" like the N54 and will be able to adjust how loud the pops are. I miss my loud pops too
MHD//VRSF DP//BMS CP//BMS intake
Default 02-05-2017, 04:16 AM
Absolutly ! I miss it realy and think about to flash back to oem and wait till MHD Update with the "burble intensity".. I will only to have the exactly same PP-Kit with MHD
Default 02-05-2017, 08:04 AM
Does flashing back to stock make more crackles and pops? Been running BEF for a month or two now and it really has been very quiet.
katsooba's Avatar
Car: 135i N55 DCT
Default 02-05-2017, 09:43 AM
Personally i run 4s in sport mode and 2s in normal mode
I love it!
Default 02-05-2017, 02:20 PM
I love it!
Is not 1sec the default of PP-Kit ? I run a MT E82 N55.. And i dont know if Sport-Modus change something or not by MT..?
diesel3443's Avatar
diesel3443 diesel3443 is offline
Default 02-07-2017, 08:07 AM
Well the car was running well, now I am throwing all these codes and it is running like poop.
2EFE: No Description found
2F04: No Description found
2EE0: Combustion misfiring, several cylinders: Fuel injection deactivation
2EF4: Combustion misfiring, cylinder 6: Fuel injection deactivation
Looks like all misfire codes? Any clue? Bad gas? I had a lot of E85 in the tank, just filled up this morning with only 93
2011 E90 335i 388 whp/475wtq on E50
