01-27-2017, 10:56 AM
If you take a stock map and change the fuel scalar, and flash it, it's still a stock map with a changed fuel scalar.
Car: 2011 e92 n55 xDrive 6MT
01-27-2017, 11:00 AM
That's what I figured. I just wanted to make sure there wasn't some other magic happening "under the hood". Thanks, Terry.
2011 E92 N55 xDrive 6MT
01-27-2017, 12:40 PM
Wow, firmware 14 and menu 11 set to 5000 just woke up the car. Its pulling like a freight train now and is much, much smoother.
2011 E90 335i 388 whp/475wtq on E50
Car: 2011 N55 135DCT
01-27-2017, 12:42 PM
I did the same wow what a diffrence
Car: 2011 e92 335i
01-27-2017, 12:43 PM
I found the car to be pretty inconsistent and overboost when set high. I have mine set at 1,000.
01-27-2017, 12:47 PM
I made 432 whp with pump on 18 psi. Soon i will up boost and run e70 with TBI
Car: 2011 BMW 335i
01-27-2017, 12:54 PM
Same here, car runs (and sounds bad) after 1,000 on menu 11. Anything over 1,500 and it starts to sound like a vacuum cleaner under the hood.
1,000 seems to be the sweet spot.
2011 335i / MHD E85 BEF / JB4 ISO / xHP Stage 3 TCU / M3 Control Arms / VRSF Piping/ Phoenix CP / YCW Coilovers 6K-18K / Enkei Raijin 18' Wheels / Michellin PSS
01-27-2017, 12:59 PM
Menu11 just sets the boost target itself as a function of pedal input. The higher the boost target at partial throttle the louder it's going to be.
Car: 335i x-drive n55 2011
01-27-2017, 08:10 PM
Can i run fw 5.14 on jb4 only ??? I just set it to 4/3 right ?
I wanna try throttle changes too
Car: 11 135i
01-27-2017, 09:50 PM
Yes
Car: 2011 E90 335i
01-28-2017, 10:42 AM
How do you have the pipe connected to the turbo? I assume you have the pure inlet and then just a silicone coupling?
Nope.... I did weld aluminum piece to the housing
F10 N63tu @FrozenF10 Grey with full OEM M5 conversion Beta JB4/BCM, GTX3076r | F10 stealth progressive meth| Custom inlets with CAI | Eibach springs| custom exh**st with 😼less dwnps |
E90 N55 VS2 DBB with custom inlet-short air intake | BMS JB4/MHD bef/ISO+FF wires E50 corn | 100% Meth-Injection | BMS-occ,cf,ocv, | Big Tom FMIC | Fuel-it S2 LPFP | 5" CP-E ** | BMW-pe |
01-28-2017, 11:28 AM
^ nice. You have a picture of the pipe between the filter and the turbo?
Car: 2011 E90 335i
01-28-2017, 11:38 AM
Yes sir, I do have pipe connected between those two couplers, unfortunately I don't have any pictures from this set up. BTW that's my first version without MAF housing.
Car: E92-335i-N55-2011
01-28-2017, 01:36 PM
another update on the 5.14 firmware about the menu 11 throttle
everything works as it should ( in normal 'Drive' )
but if i put my DCT/DKG transmission in SPORT mode,
it's want to go full power even when i just slightly touch the gas pedal,
E92 335i 2011 N55 | JB4 G5 ISO | M Performance Exhaust | BMS DP | Wagner evo 2 comp Intercooler | BMS catchcan | BMS Chargepipe | MHD FLASH
Car: 11 135i
01-28-2017, 02:52 PM
Well that could explain something.
When I set menu 11 high my turbo sounds kinda nasty loud. I tried to show my mechanic the noise on a street test but it was gone. Might have been the S mode buttton?
01-29-2017, 11:20 AM
Mine setting is not even set at high, but at 2000rpm
In normal drive mode everything works fine
but when i press my sport button the gas pedal is not linear anymore
Like i said .. in sport mode my car does full power even when i just slightly touch the gas pedal.. i hope terry could do something about it,
02-02-2017, 09:40 AM
For those with EU spec cars without the evap system found in USA spec cars I've updated a version of the firmware to keep those faults off. I'll post them up shortly but if you need it quicker just email in for it.
02-02-2017, 09:49 AM
Hi Terry. What email must i use or can you mail it to jacques.dlange@eoh.com please
02-02-2017, 09:57 AM
Originally Posted by JacquesN55
You were the one who sent in photos of a stolen Fuel-IT PI kit asking for help with it?
02-02-2017, 10:01 AM
Hi Terry. I found the stolen PI kit in a forsale add and then reported it to my tuner yes.
02-02-2017, 10:02 AM
I gave in the persons details and phone number yes
02-02-2017, 10:43 AM
All i did was see the kit forsale in a advert and then mailled Steve asking if it will fit n55. Then i was told by my tuner it was stollen PI kits. Then i gave in the website of the add and also the contact info.
02-02-2017, 10:50 AM
I never bought it or anything.
02-02-2017, 10:55 AM
Ah OK, got it. That was the only discussion I had in my box re: your email address. Anyway I emailed the EU spec file.
02-02-2017, 10:58 AM
Awsome thank you Terry.
Thread Tools |
Display Modes |
