N54 - Injector Adaptation Values -
10-14-2016, 06:24 PM
Hi All,
I have a 335i 2009 model. I just replaced 3 fuel injectors in bank 1 as it was misfiring.
The idle is still a little rough.
I have a bunch of Injector adaptation readings from the Bavarian Technic tool.
I thought it was a little strange that injector 3 and 4 readings were so low.
I'd appreciate if someone could offer any insight.
Thanks in advance
Car: 335i E92 2009
10-15-2016, 12:08 AM
You coded the injectors ?
10-15-2016, 12:14 AM
No I did not code them.
10-15-2016, 12:27 AM
please ignore the previous reply....yes they have been coded.
Car: 2008 BMW 535i
10-15-2016, 05:29 AM
I would double check your coding again make sure you input the correct values for each Injector you replaced, also were the Injectors you replaced same Index #'s?
JB4 G5, DCI, Er CP with HKS Bov, VRSF DP's, BB Race flash
10-15-2016, 03:13 PM
Do you think there is a problem with the adaption readings for injector 3 and 4?
Note, injector 1 = 98.91%, 2 = 98.43% 3 = 2.66% 4 = 0.51% 5 = 99.50% 6 = 100.00%
Car: 2008 535xi
10-15-2016, 03:56 PM
Have you tried resetting the adaptations?
Thread Tools |
Display Modes |
