Car: N54 135i
Testing Injectors - Quick Question -
07-13-2016, 03:24 PM
I believe I have a leaky injector/s and plan to test them this weekend. Just had new OEM turbos installed, so don't have the JB4 in to check logs right now. Question is, has anyone used the testing method in the below video or have any additional tips? Looks pretty cut and dry.
More importantly, will I need to replace the injector seals and/or decoupling elements because I'm pulling them?
https://www.youtube.com/watch?v=N-cliDST_vc
Much appreciated.
Car: E92
07-13-2016, 05:05 PM
U can reuse the decouplers if you do it. I've wondering about that same video before. Technically you would have a hard time getting the injectors back in due to the seals expanding. I would simply run the motor so it exhibits the problem of a bad injector then check each one looking for a wet plug.
Car: N54 135i
07-14-2016, 07:38 AM
Thanks for the response.
The major sign I'm getting of a bad injector is a rough cold start after sitting over night or long period of time; warm start-up is fine. It settles down after initial cold start is over. There’s also a slight rough idle when warmed and at a stop, but nothing like a cold start. No misfires or issues during WOT; bearing in mind I’m on stock tune right now. I checked plugs when I first noticed it and they looked fine, only had about 5,000 miles on them. Valve cleaning was done about 7,000 miles ago. Other than taking a log, I'm thinking the test in the video might be the best way to confirm it’s an injector. I’ll reinstall the JB4 this weekend and see if there is anything obvious before pulling them.
"Technically you would have a hard time getting the injectors back in due to the seals expanding."
Any idea if this would be true even if I replaced the seals with new ones?
Car: 09' 335i Sedan
07-14-2016, 07:54 AM
Just don't install the new seals until after you have performed the test.
Car: N54 135i
07-14-2016, 08:01 AM
Thank you, appreciate the tip.
That was the plan, wait until I am ready to put them back in and swap seals at that point.
07-14-2016, 10:25 AM
If you do remove an injector, you have to put a new seal on it. If not, the seal will not go in correctly, causing gases to escape during compression torching the hole the injector sits in. You will then need a shop to make a custom seal to fit the newly enlarged hole or buy a new head. The seals are $2 a piece. I purchased this seal kit and it works great. It's also the cheapest one out there. If you are in the PNW you can borrow mine.
2008 E92 AW 335xi 6MT: VTT GC Turbos w/ Inlets n Outlet + JB4 + Custom BEF + BMS CP + BMS Meth kit & TwistedTuning DP Meth Plate + 6 Aquamist .4mm Nozzles & 350cc 7th nozzle.
07-14-2016, 01:04 PM
I've never had issues with the seals. Even bought used injectors from ppl, threw them on without issues.coded and been fine for 7k now.
2007 e90 335i
Hexon turbos
Fbo with Cpi tuned at e55
Jsr Custom tuned
Car: 2007 BMW 335i E92
07-14-2016, 01:12 PM
I made that video,
did not had any problem with seals, running Single Turbo
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
Car: N54 135i
07-14-2016, 04:02 PM
Thanks for the info. I'm down in AZ, but appreciate the offer.
If I did replace the seal, is it not just as easy as replacing something like an o-ring? Obviously, it's not an o-ring and I’d get the proper seal, but it looks like the original can just be taken of and the new one slid into place; then back into the head. Not sure what the seal kit would be for(?) I don’t have prior experience with these injectors nor have I seen one in-person, so maybe there’s more to it than I'm seeing. Thanks again.
Originally Posted by Levan-i
I made that video,
Thanks for the video and for replying!  So it's as simple as pulling the injector out, rotating it 180deg and cranking to see if one or more spray? If so, seems like a pretty simplistic was to identify a bad one. This seal replacement has me a little concerned, but nothing that’ll stop me from replacing them or giving this a shot.
Car: 2008 535xi
07-14-2016, 05:06 PM
There is a special tool that shrinks the seal down once you install it. Then once you install the injector the seal will expand in the hole.
Car: N54 135i
07-15-2016, 09:13 AM
Thank you for further explaining.
Sounds like it's not as easy as just pulling, testing, and replacing. Maybe I'll hold off on this until last resort. I'll install JB4 on Saturday (it’s your’s on Sunday, Tyler) and get a cold startup log, hopefully that’ll give some further indication on which injector/bank is bad.
07-15-2016, 09:42 PM
thats correct, just don't connect signal wires to them
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
Thread Tools |
Display Modes |
