Car: 135i n54
Inlets outlets for RHD 135i -
07-05-2016, 05:33 AM
After much research I'm still not sure which brand to go for regarding inlets. I was swaying towards VTT till I saw a thread on another forum about how much of a PITA the fitment was and the way it's squeezed between the steering rack doesn't look too clever. Tft seem viable but an expensive option (extra elbow needed) or the new rb inlets? Anyone here got these fitted on a RHD without having major fitment concerns? I'm pushing these tiny turbos at 20psi daily and wanted to relieve them somewhat.
Brendan
Car: 335i 2007 6spdman
07-05-2016, 02:32 PM
Fitted two set s of rb inlets.
Both on my car, fitted 1.75 inch inlets very easily.
2 inch snout was more difficult as there's no space to put the rear inlet on without loosening the manifolds first.
The silicone inlets don't go anywhere near the steering rack.
Still havnt seen any logs showing tft inlets are an improvement over the silicone types.
07-05-2016, 07:57 PM
I had both sets of inlets from VTT and RB and I have to say the RB's are made much better and tougher. The VTT ones are very flimsy. Go with the RB's.
135i - JB4 15ohm l Mr 5 Intake l AA C@tless ********* l ETS Intercooler l BMS Methanol Injection l Berk Tech Mids l Berk Tech Axleback l BMS OCC l ER CP l Turbosmart BOV's. SOLD
335i DCT - JB4 G5 ISO l AA C@tless ********* l ETS Intercooler l Custom Intake l Meth l BMS E85 Flash l BMS OCC l ER CP l Walbro 255 l Turbosmart BOV's. CURRENT
Car: bmw 335i e92
07-05-2016, 09:22 PM
I have the total inlets and very very happy with the performance and the workmanship and design. Definitely the best value for money spent but other people will disagree. That's my 2 cents
Aussie e92 335i. Pure Stage 2 Twin Turbos, Pure Performance Motorsports Forge Rods and Pistons, Fuel-it Port Injection, 7.5" Race intercooler, Fuel-it Stage 3 LPFP, Ugraded Fuel lines , Tial 50mm BOV, TFT RHD Inlets, JB4 g5, MHD 98Ron Wedge Hybrid Custom Backend flash, BMS OCC, T20MAP, AR Design 3" Cattless **, Remus Dual 2.5" system with 84mm quad tips, RB PCV valve, AFE intake scoops, Bimmer Coils, CSF Radiator
07-06-2016, 04:22 AM
I just bought inlets and outlets from MMP. Guess those are good too
E92 335i N54, Hexon RR500, JB4, DCI, MMP inlets, ER chargepipe, Turbosmart Kompact Dual Port BOV, ATM IC, Wagner downp*pes, MPerformance exhaust, oil cooler, trebila flash (via MHD Flasher), E60, M Performance 370mm brakes, styling 313 wheels, M Performance suspension, Fuelit Stage2, MFactory LSD, MFactory SMWF
Car: E90 LCI 335i
07-06-2016, 04:39 AM
I'd go RB inlets and for "outlets", I'm assuming you mean hot side charge pipe, just modify the stock item to get rid of the dents or at least the biggest one.
Car: 2007 335i
07-06-2016, 06:55 AM
I don't think there is a rhd outlet yet. The lhd and rhd outlets are different
Car: 135i n54
07-06-2016, 10:16 AM
Apologies I meant the steering spindle. Here's a pic from someone else who tried installing VTT outlets. I'm going to play it safe and go for the RBs everyone's been raving about and wait for a true rhd outlet or go about modifying the current outlet.
Brendan
07-06-2016, 04:01 PM
Spindle is what I meant to say too.
You were talking about outlets. I was thinking inlets.
The rb rhd out let is pretty much the same as above, that is being test fitted by two ppl currently.
I wouldn't stress too much about outlets on stock turbos best to wait until rb or others gets them sorted.
07-07-2016, 06:29 AM
What rb outlets are you referring to?
I have a set of the original rb outlets that utilise the metal rear turbo outlet pipe and you have to cut the front pipe into an elbow and bead roll it. A lot of work but it works nicely. I had both metal pieces ceramic coated and removed the squashed section of the rear turbo outlet. I'm FBO with inlets And straight pump gas with rb turbos I hit 23psi and hold 20psi to redline with 38% WGDC up top. Pretty efficient I say
UK V8Bait Tuned
Built Motor
TD Turbo 335i
Car: e92 335i N54 2007
07-07-2016, 07:21 AM
I'll have a set of RHD compatible TFT inlets for sale £500.
I'm going single turbo and this will no longer be required.
I have a CF pipe which goes around the steering spindle but doesn't foul it. Its 2.5" at both ends of the 90 deg pipe.
Included will be
1, Hot side pipe work
2, 2x air filters
3, CF RHD pipe for fitment
4, 335d expantion tank and plumbing
5, 4x 90 deg reducers for 1.75" and 2" fitment
Vid of pipe custom pipe
https://youtu.be/BUe6YuaOOQg
BMW E92 335i N54 6AT, Single Turbo to be decided  . Turbosmart BOV / Spearco FMIC / Wagner Down *****, Stg3 LPFP and Fuel-IT PI kit, Aquamist PWM Meth trunk mounted, single 0.7mm nozzle spraying 60% meth, JB4 G5 + FSB + N20 Sensor + JB4 BT Connect, MHD JB4 Backend Flash, Fuel = e60 + 60% Meth, M3 Rear Subframe Complete swap + custom prop, front m3 wishbones, KWv3 Suspension, M3 brakes front rear, H&N ARB / 19" M359 Reps + Michelin Super Sports tuned by TREBILA
07-07-2016, 07:29 AM
I also modified my OEM outlet
Brendan
07-08-2016, 12:25 AM
Rb outlets I'm talking about are ones on the evo set for rhd.
38% wgdc on that much boost is less then I have on rb stealths on less boost with unsquashed hot chargepipe and inlets.
What wgdc are you reading? Bank 1 2 or base?
07-08-2016, 06:38 AM
Bank 1. 3rd gear is 38% WGDC up top 4th is slightly higher
UK V8Bait Tuned
Built Motor
TD Turbo 335i
Car: 2007 335i
07-08-2016, 10:33 PM
I'm gonna wait on ft turbo outlets and save myself the headache
07-12-2016, 08:16 AM
What are FT Outlets?
Car: 2007 335i
07-13-2016, 01:49 AM
Sorry auto correct. I meant RB outlets for rhd
Car: 335i e92
04-20-2017, 02:50 AM
Long shot but if you are still selling these or if anyone is. Please let me know
Car: 2007 335i
04-20-2017, 05:27 AM
Contact rob @rbturbo
I'm rhd 135i n I have his inlets outlets n recently got replacement stage 1 chras.
Thread Tools |
Display Modes |
