irishinmeveins's Avatar
irishinmeveins irishinmeveins is offline
Car: 2011 335i
Default Uh oh... Boom sound wot, then loss of power - 05-18-2016, 09:41 AM
Hey all, well I was capturing a new wot today, 40 ish 4 gear. Floored it and as it started into it I heard a boom sorta sound. Then loss of power. I was able to pull over a few moments later. I didn't get a code on dash. I searched on jb4 software ad it did show 2774 mass air flow. I was actually in lunch break from work so I havnt been able to mess with it much yet. I did have it logging when it happened, I will try to post that when I get off.
I'm guessing I blew turbo?? I don't know yet. Any advice?? What to check first?
Thanks in advance.
Damn everything was running great
2011 335i / VRSF ** / 7" VRSF FMIC / Injen Intake / JB4 ISO mod / Flex wires / 40-60 e85/93 / MHD Flash / BMS BEF / BMS Meth Kit / H&R lowering springs / Lux H8 160 / LTMW custom front end / Carbon Spoiler
keyap keyap is offline
Car: N55 135i
Default 05-18-2016, 09:43 AM
Charge pipe?
Car: 2011 335i
Default 05-18-2016, 09:50 AM
Maybe, I hope it's something like that. My boost wasn't registering on gauge. But I think I saw a message that tune was inactivated or something like that. Sorry for lack of info at this point. But I wanted to throw something up for pointers in what to check this evening.
Default 05-18-2016, 09:51 AM
Sounds like a blown chargepipe. Worry not we've got plenty of stronger replacements in stock.
Car: 2011 335i
Default 05-18-2016, 09:55 AM
God I hope that's it! Scared the **** out of me! Thought I blew an engine. With the mass air flow let me to believe either turbo, something blew loose between turbo and before and after intercooler, or??? Charge pipe would be smallest of my worries
Car: 2011 335i
Default 05-18-2016, 11:24 AM
You guys that no it's ok to drive home from work if that's it? I live about 5 miles
Jayock's Avatar
Jayock Jayock is offline
Enginerd
Car: 2009 135i
Default 05-18-2016, 11:44 AM
Youll be sucking unfiltered air into the engine.
See if a couple blew off first. 5minutes in the parking lot with a screwdriver could fix that.
--2009 BMW 135i--2016 Nissan Titan XD (Turbo Cummins ISV)--2016 VW Tiguan 2.0Tsi --1988 Beechcraft Bonanza--Suzuki GSX-R 1000--Honda CBR-600RR--
JB4 G5 ISO | MHD | E85 | Fuel-It S3 LPFP / PI | MFactory S3+ Clutch / SMFW / LSD / Mounts | Diff Lock | UUC Tranny Mounts | DwnPipes / Exhaust / FMIC | Chargepipe / Tial | KW V3s | HR Sways | HPA full M3 Suspension | BMS DCI / Oil Cooler Valve / Cowl Filters / 4bar / 2Step / OCC | RB PCV | Stri Gauges | Pole Position 225/265 | Installing: DR 6466ST
Car: 2011 335i
Default 05-18-2016, 11:58 AM
Blew charge pipe in half at body. I have it on with only half on ring, and baby driving home now
Car: 2011 335i
Thank god!!
suspenceful's Avatar
Car: 2008 BSM 135i
Default 05-18-2016, 12:32 PM
Glad it was only the charge pipe. Get a hardpipe on there ASAP!
Car: 2011 335i
Default 05-18-2016, 12:36 PM
I ordered the BMS one a couple mins ago. I probably lost the clip. Maybe its under the car in the plastic under cover. That thing is exp! [IMG][/IMG]
Car: 2011 335i
Default 05-18-2016, 12:38 PM
Its gonna sit til my chargepipe comes in. Luckily its sunny next couple days, I have my other baby to ride (2015R1)
Car: 2011 335i
Default 05-18-2016, 12:43 PM
If anyone was interested to see log when it blew ..
Stoolz Stoolz is offline
Car: 11 135i
Exclamation 05-18-2016, 12:56 PM
Nobody should drive a modded car without a replacement chargepipe. When mine went it sucked a piece into the throttle body, and very lucky for me it got stuck on the butterfly.
Car: 2011 335i
Default 05-18-2016, 01:05 PM
Terry, make sure that thing gets shipped out today!!! lol
Car: 2011 335i
Default 05-18-2016, 01:23 PM
I found the pieces thankfully. This is what it looks like on. Looks like a clean break (kinda). I could not locate the locking clip. I will raise it and remove cover, its hopefully laying in there somewhere
Car: N55 135i
Default 05-18-2016, 01:31 PM
Great news
dh58 dh58 is offline
Default 05-21-2016, 08:48 PM
when you put your foot down.. do you still have boost?
cracked/broken or came off charge pipe will stop you from building boost. It's happened to me
Rob_BMW_PNW Rob_BMW_PNW is offline
Default 05-21-2016, 09:04 PM
Ive had this happen on my 2015 WRX, **** was scary
fostergfx@gmail.com's Avatar
fostergfx@gmail.com fostergfx@gmail.com is offline
Car: 2012 bmw 335i
Default 05-23-2016, 08:47 PM
been there, done that. freaked me out but knew what it was instantly.. went the the hardware store and bought a 3.5 inch to 4 inch rubber piece, slipped it around both ends until my cp came in. worked great, was a bitch to get it on and find the right piece tho lol
2012 BMW 335i F30 N55/6MT
JB4 | BMS Intake | ER Charge Pipe | VRSF ** | VRSF FMIC | E85 | NGK Plugs | MFactory FW | 335is Clutch | 255/40ZR18 Michilen Pilot Super Sports
Car: 2011 335i
Default 05-24-2016, 11:47 AM
I have left it sitting in driveway until pipe came in. Been riding my r1. Suppose to come in today. I can update tomorrow
Car: 2011 335i
Default 05-24-2016, 03:04 PM
Well, new chargepipe put in, all is well. Thank god I actually found the O-ring laying in the engine area. I was also lucky to find the c clip by removing 3 screws from the under guard. I pried the corner down and it was right there. BMS didnt mention that it did not come with c clip or O-ring. I dont know if you guys searched before, but BMW dealers DO NOT have this clip!! Your only hope is to order online ($25+).
Took her for a spin and everything is back to normal. Actually seems a little more responsive on lower RPM levels. I think I had a slight boost leak, noticeable at low rpms. On more throttle this wasnt as noticeable. Anyway, seems low end has improved slightly. Im still a little scared to wot now lol... I think everyone goes through a healing process when that thing blows. Thanks again for the advice, I will sleep better knowing that I dont have that cheap plastic pipe on there anymore. Plus if I decide to run meth, Im one step closer. Although, I dont think Ill get much performance from that..
