omarmarji's Avatar
Car: n54 335
Default Solution to AT?? - 01-11-2016, 12:38 AM
The outcome of this thread will determine my fate with the money i have for spending purposed obviously on my e90....
My 335 is undergoing a Single Turbo swap, now with that being said i'm basically afraid my auto trans will go kaboom like everyone elses...was there a solution discovered that no one knows about besides swapping to MT? if so what is it! if not then i will be ordering all the manual parts like i said my fate depends on the outcome of this thread. thank you
751WHP 688WTQ
JP Works Kit Record
SOLD: E90 335i 751whp 688WTQ
Taron's Avatar
Taron Taron is offline
Car: 2008 BMW 335XI
Default 01-11-2016, 03:04 AM
try swapping to 6hp26 from 335d, there are some thread on the net how this probably can be done, however noone tested, i'm on 335xi and I will go with mt on the last end, swapping to 6hp26 is my next try (
psychosinmylobby psychosinmylobby is offline
Car: 07 e92
Default 01-11-2016, 08:26 AM
What parts are you referring to is transmission specific?
There are a few people running ST and 6AT no problem. I would stick with the 6AT + Sonnax Zip Kit + new ATF until it blows then consider a swap (MT / DCT). This will allow more time for solutions to develop / get proven.
I think swapping to a 6hp26 is not proven to work / take the power. May or maynot cost you later on if it fails.
omarmarji's Avatar
Car: n54 335
Default 01-11-2016, 08:32 AM
I already get trans fault codes for 4-5th gear slippage but I don't notice it at all but it goes away once the car is off I just think that's due to heat and low fluid but , zip kit ?
751WHP 688WTQ
JP Works Kit Record
Car: 07 e92
Default 01-11-2016, 08:53 AM
Is your ATF fluid low?
I used to have slippage (but no codes). I checked my trans while I did my *** and there was ATF all over the bottom side due to leaking mechatronics sleeve. Checked my ATF and it was low. Filled it back up and it never slipped even after the additional power.
Sonnax Zip Kit may give positive results but it isn't proven with numbers. But people have done it and reviewed it to have positive impact.
I don't want to get your hopes up tho, your slippage issues sounds much more serious since you got codes. If it is cheaper to do the swap now than later, you should do the swap.
omarmarji's Avatar
Car: n54 335
Default 01-11-2016, 08:56 AM
But my trans doesn't slip at all the the funny part
751WHP 688WTQ
JP Works Kit Record
TwistedTuning TwistedTuning is offline
Car: 2007 335xi 6MT Sedan
Default 01-11-2016, 09:16 AM
if your trans doesn't slip i would just stick with it. keep good clean fluids in it and etc. then if it goes as stated go for the MT swap. just my opinion.
"Increasing the Area Under The Curve"
Custom Performance ECU Calibration
www.twistedtuning.com
twistedtuned@gmail.com
omarmarji's Avatar
Car: n54 335
Default 01-11-2016, 09:18 AM
i share the same opinion, but i dont know if i should give the trans a chance or just go straight for the MT swap
751WHP 688WTQ
JP Works Kit Record
Default 01-11-2016, 09:22 AM
I say give it a chance. I mean there are several people putting down pretty decent power with them. Maybe do minimal things to it for now to help it cope.
The Zip kit that was mentioned as stated seems to have good reviews. Definitely either upgrade or add a trans oil cooler to keep heat down as much as possible. and just see what happens.
omarmarji's Avatar
Car: n54 335
Default 01-11-2016, 09:23 AM
good advise, i will take it, i already have my oil cooler set up and everything i just need to connect the lines now
751WHP 688WTQ
JP Works Kit Record
Race8877's Avatar
Race8877 Race8877 is offline
Car: BMW 135I
Default 01-11-2016, 11:22 AM
PURE TURBOS:
Insider ZF knowledge:
Replace your Front Stator bushing with the Omega upgraded part:
http://www.omegamachine.com/db/ZF6HP...hing%20kit.asp
The front stator bushing is what causes most 4th, 5th, and 6th gear problems. It can be done without disassembling the whole trans.
The front stator bushing is not only a shaft support bushing, but more importantly: seals oil pressure to the E clutch (4,5,6). The OE ZF bushing is inferior, the bearing babbitt fails especially with increased torque.
Our shop 135i OE bushing was worn out, with a measured clearance of .008", OE spec is .0015". The excessive wear bleeds off the much needed engagement pressure for the E clutch.
Most ZF6HP21 trans problems are caused by this bushing. But of course, trans shops won't tell you this.
Default 01-11-2016, 11:31 AM
Originally Posted by Race8877
PURE TURBOS:
GREAT POST and very informative
omarmarji's Avatar
Car: n54 335
Default 01-11-2016, 11:46 AM
i agree but damn im so convinced to manual swap it
751WHP 688WTQ
JP Works Kit Record
Car: 07 e92
Default 01-11-2016, 12:55 PM
PURE TURBOS:
Very interesting. Any DIYs out there for this?
Until the 4l80e has been figured out, MT is the best option to handle power period.
AUbeast86's Avatar
AUbeast86 AUbeast86 is offline
Car: 2007 335i e92 Coupe
Default 01-11-2016, 01:00 PM
Great info! This could be worth doing on my spare transmission. I'll start tearing it apart to see just how involved it is.
Car: 07 e92
Default 01-11-2016, 01:10 PM
It would be tremendous help if you could do a DIY if you are able to do this.
Looks like Sonnax makes a set for the 6hp21 as well with upgraded materials.
Default 01-11-2016, 01:36 PM
The full lvl10 build is good for 600whp or so, at least for awhile. Beyond that there is no known AT solution. It becomes MT swap time.
natedog7700's Avatar
Car: 2007 bmw 335i e90 auto
Default 01-11-2016, 05:34 PM
A single swap on a AT is a recipe for disaster unless you plan on running no more power than standard RB's. Then what's the point?
BMW 335i
RB's 550whp
2000 Camry
2000 LS1 T56 Camaro
Koenigsegg Agera R - SOLD
Lamborghini Huracan - SOLD
2014 Bugatti Veyron - SOLD
Default 01-11-2016, 06:02 PM
https://www.youtube.com/watch?v=zYxuHPV02gY
Pure porn
http://sales.omegamachine.com/ZF6HP19_Bushing_kit_p/14500.htm
$99
Car: 07 e92
Default 01-11-2016, 07:29 PM
So tranny removal is required. At that point, swap to a MT for sure.
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 01-11-2016, 08:23 PM
Save yourself the headache later and MT swap it for now. Then 4L80E swap down the road whenever that kit is ready.
omarmarji's Avatar
Car: n54 335
Default 01-11-2016, 08:54 PM
4l80 kit will cost more than a manual swap lol
751WHP 688WTQ
JP Works Kit Record
Van3 Van3 is offline
Car: Bimmer
Default 01-11-2016, 08:58 PM
What would one have to do for a manual swap? IS there any DIY ?
omarmarji's Avatar
Car: n54 335
Default 01-11-2016, 09:05 PM
No but from my experience it's pretty straight forward
751WHP 688WTQ
JP Works Kit Record
Car: 07 e92
Default 01-11-2016, 09:20 PM
Anyone know the hp/tq limits of a DCT + Dodson clutches? That's another option.
