tunarollz tunarollz is offline
Car: f10 M5 bms stg1, e92 335i bms jb4
Question How to temporarily disable s63tu stage 1? - 11-23-2015, 03:32 PM
Hi guys,
I'm trying to disable the stage 1 (complete stock mode) while I get my flash tuning done.
I know the foolproof method would be to pull the system and put the tmaps back to stock wiring, but as a method to keep the stage 1 in there for future fine tuning, what's the best way to effectively disable the stage 1?
Pulling just the box out won't work, right? I'm guessing this would make an open in the TMAP circuits?
For now I'm just putting 0.0 failsafe boost over stock in the jb4 software interface. Will this essentially tell the stage 1 to sit idle in all aspects?
Thank you!
Jon
335iMspizzle 335iMspizzle is offline
Car: 335i M sport
Default 11-23-2015, 04:11 PM
Originally Posted by tunarollz
Hi guys,
Thank you!
Jon
You will make a huge mistake flash tuning it, coming from someone with experience.
2014 - M6 f06, FabWorx Ctlss DP's, JB4, FSB meth, Turner Exhaust.
2012 - 650i M sport JB stage 1 (Gone)
2009 - 335i N54 JB4, DINAN CAI, MACHT SHNELL DP'S, HPF FMIC, ER CP, SYNAPSE BOV, EISENMANN RACE EXHAUST, BT OIL CC, COOLINGMIST/SNOW PERFORMANCE METH INJECTION - 427 WHP DYNOJET (Gone)
Default 11-23-2015, 05:01 PM
It's a non-CANbus tune so no need to disable or do anything. Set it to map 0 if you want to prevent it from adding boost to the flash map.
Default 11-23-2015, 06:51 PM
Thank you Terry. After I fine tune this setup on the dyno, I'll look to add additional boost with the stage 1 for race gas. For now failsafe boost set to 0.0.
Default 11-23-2015, 07:47 PM
I'd upgrade it to a JB4 ASAP, so you can see what the flash tune is actually doing, via logs. They don't all work as well as they should.
Default 11-24-2015, 12:01 AM
Got it. Thanks Terry. I'll be ordering a jb4 for my 435i soon too. :D
