Car: 2007 BMW 335i Coupe
03-18-2020, 01:03 PM
Yes
Quick question. I bought a used JB4. Is there a way to check if I have the antilag chip already? Thanks
Car: 2007 e90 335i sedan
anti lag problems -
04-07-2020, 01:33 PM
Hey just bought the anti lag kit for my e90 335i sedan,(stock turbos) I downloaded the tune from bms to my dme but whenever I hit the volume button and floor the car it just accelerates the same as if I weren't holding the volume button. If u have any ideas on what im doing wrong message me. thanks
04-07-2020, 01:38 PM
04-07-2020, 03:44 PM
Can you log so we can see what's going on?
jb4 log -
04-08-2020, 12:29 PM
04-08-2020, 12:49 PM
Can you post the CSV file please.
jb4 log -
04-08-2020, 04:36 PM
20200324_1551_runs(10).csv
04-09-2020, 08:42 AM
Email me Payam@burgertuning.com
Car: 2007 bmw 335i
04-25-2020, 10:44 AM
Do you need to buy the antilag kit even for the g5 board?
04-27-2020, 09:07 AM
If you want antilag, yes. You'll need the full kit.
05-07-2020, 05:59 PM
Hey so I'm on G5_ISO_32_15 and the 2 step does not come on with anti-lag anymore. Bit 3 is still checked on and it was working fine in 32_14. Should I turn off bit 3 to get 2 step + anti-lag integration back?
Also ever since turning on beta anti bog fix (manual) I can't No Lift Shift anymore.
Car: 2011 e93 335is
05-08-2020, 06:59 PM
I have a 335is with DCT. Want to get anti lag with 2 step. I have a jb4 g5 installed already. Getting ready to purchase the anti lag chip. Do I need the get the 2 step relay also? If so, is there something special I will need to do to get everything working?
Car: 2009 335i convertible
05-12-2020, 03:58 PM
2009 335i convertible manual i m tryin to get this anti lag chip working but for some reason i dont it is not working i updated to latest version i m new to n54 programming juat bought the car i have full vrsf street exhaust injen intake jb4 g5 latest version did everything that is mention in the thread but no results am i doing something wrong because the thread didnt mention anything about manual application how to engage on manual trans please help
Glando7
Car: e90
05-21-2020, 01:09 PM
Hey did you get a response on this. I'm in the same predicament as you are right now however, I'm on G5_ISO_32_14.
Anti-Lag works..... 2-step and NLS is a nogo. Troubleshot the clutch signal by changing Future A and verifying 1 or 0 on the LPFP setting. LMK if you have any luck.
'07 Pyrite Brown Metallic e90 M/T
Stock Snails | B4 G5 ISO + MHD Bef | N54 Tuning 3' **'s | Wagner Evo 2 FMIC | ER Charge Pipe | Forge Diverter Valves | NGK Plugs | Fuelit Bucketless stage 2 LPFP | MagnaFlow Exhaust | BMS OCC | BMS DCI | UUC SS | Apex FL-10's F:18x9 R: 18x9.5 in Anthracite | Firestone Firehawk F: 245/40/18 R: 275/35/18
Maintenance
Water Pump + TStat | VCG | Index 12 Injectors | Walnut Blast | RB PVC | New Plugs + Coils | Upper Coolant Lines
05-21-2020, 02:06 PM
If you are a manual are you sure auto shift reduction is set to 0? The JB4 uses that to know you have a manual and enable NLS.
Glando7
Car: e90
05-21-2020, 07:58 PM
Hi Terry,
Yes, I am running a manual, and I have Auto shift reduction set to 0. Please let me know if there's any more information I can provide. Thank you!
Maintenance
Car: BMW
06-26-2020, 09:04 AM
Hey Terry,
Does this anti lag feature work for the 335is equipped with a DCT?
2013 335is: V8Bait tuned, M4 DCT flywheel, E50 + AEM meth kit with dual BM5 nozzles, MMP relocated inlets, VRSF outlets, CTS 7" IC, DCI, BMP Stage 2 fuel pump, PR coils, 3" DP, BMS charge pipe
2018 340i: Pure Stage 1 turbo, BMS meth kit, BMS intake, JB4 + MHD, DP
2011 335d: BRR tuned
Car: 2010 135i msport
06-30-2020, 03:45 AM
Hi Terry,
I'm having the exact same issue. Have you found a remedy?
Car: 2008 BMW 535xi
07-10-2020, 03:56 PM
i bought this anti lag and im rdy to install it now, i am looking for the BEF download link but cant see it. is it hidden?
07-10-2020, 04:08 PM
Car: 2015 bmw 650i xdrive
07-15-2020, 01:48 AM
Is the anti-lag available for the n63tu yet? or will it be eventually?
Mike
2007 BMW 650i ms port (SOLD)
2015 BMW 650i X-Drive
-CL DP
-custom fully open true dual exhaust
-MAF delete
-BMS WMI
-JB4 tunes
Car: 09 135i
07-15-2020, 04:31 PM
Im also manual and having issues as the other guys above with the new firmware 32_15 beta
09 135I MT jb4 g5/MHD Trebila backend Frankenturbo F21 FBO, PI, stage 3 lpfp, full E85, Quaife LSD
08-04-2020, 07:53 PM
Mine still doesn't work integrated :/
Before 32_15 it'd work as intended, but now with 32_15, it doesn't want to trigger in integrated mode.
I even tried reverting back to old firmwares and it still doesn't work.
Car: 09 135i
08-17-2020, 08:03 AM
I went back to 32_14 and it works fine. I'm sure the bugs will get worked out.
Car: Alpine White e82 135i
09-03-2020, 04:17 AM
Did update yesterday, nithing works anymore. Reverted back to 32_14_2...still not working.
Reset JB4, tried toggling bit 3....no luck!
Please help! Have a RSQ3 race coming up....
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Leon@86
Thread Tools |
Display Modes |
