(#251)
Peter @ Pure's Avatar
Car: F20 M135i
Default 02-24-2015, 01:22 PM
Terry ran a cm14 nozzle on the vtt stage2 car. You will see how far you get on just E mix without meth. There is just not enough people with stage2's on n55 YET
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
iuhutch's Avatar
iuhutch iuhutch is offline
Car: 2011 e92 335xi
Default 02-24-2015, 05:44 PM
Originally Posted by JETmn
Maybe that was with an upgraded LPFP? Several of us have found we can't go nearly that high. I am on a stock fuel system and E40 is my borderline. I run E35 to be safe. I tried E45 and had fueling issues.
Dead on. I have the stg2 lpfp and you can run e50 but anything above that causing fueling issues as the hpfp just cannot send that much ethanol.
To run more ethanol, take baby steps. Literally .5gal more e on every other fill-up or so. the DME is much nicer doing the gradual learn.
Also remember that e50 is not 50% e85...
Foacad Foacad is offline
Car: 2012 BMW 135i
Default 02-24-2015, 05:56 PM
Good last line.
I think a lot of people get confused about the whole thing of e50 vs 50% e85 and then you've got e85 that's actually only e70-75 because of winter fuel.
Plus the octane ratings vary quite a bit as well which changes things in JB4.
IIRC, isn't the optimal octane for map 7 103oct? On a 12.5 gallon fill up that would be 5.5 gallons of 100% ethanol and 7 gallons of 93. Which is e44 with an octane rating of 103.1
But say you do "e44" with e85 and 93 mix then 6.5 gallons e85 and 6 gallons 93 is 99.2 octane. Same "e44" but almost 4 octane points different.
Nugs Nugs is offline
Car: 2011 135i
Default 02-24-2015, 07:55 PM
I've run e60 at 20psi on my stage 2 and HPFP stays around 11 which apparently is OK but you wouldn't want it to go much lower.
But it seems to run more consistently on e40 or 50.
Like everyone says work your way up gradually and log, everyones car is a little bit different.
Default 02-24-2015, 08:39 PM
For N55s I've found they prefer to run lean, and don't need a lot of extra fueling, even on E50. Maybe a CM10 or CM12 nozzle is enough. As always you'll need to review your own logs to verify.
Car: 2012 BMW 135i
Default 02-24-2015, 09:33 PM
Terry, what is your take on the octane side of things?
I have a station near me that is a blender pump that has E30, E50 and E85.
If I fill up my tank with their E50 I'm almost sure it's going to be under 100 octane, whereas if I use a mix of 100% ethanol and 93 octane I can still be E50 but higher octane.
I was under the impression this makes a big difference but never see it mentioned. Just the E__ numbers.
Stoolz Stoolz is offline
Car: 11 135i
Default 02-25-2015, 02:43 AM
Nugs, im just gonna follow
you on this i think.
Car: 2012 BMW 135i
Default 03-01-2015, 01:38 PM
Pretty damn excited. Went to Cobb in Plano yesterday to have them see if their AP would flash my 2012. It took perfectly. Sales guy helping me showed me how to add maps to the AP so we put the BMS flash from the first post in here on it.
There might be some placebo effect but just from a couple highway pulls and driving around town the car seems to pull a lot smoother. I'll have to wait till I get back to KC and it dries up a bit to do some logs but so far I'm really happy.
3.5bar tmap sensor is waiting for me back at home so that will go on soon too.
I've read through this entire thread so correct me if I don't have this right. With this back end flash I can do a 50/50 mix of e85 and then do some logs then if it needs any tweaking Terry, you can help out with that?
Car: 11 135i
Default 03-01-2015, 08:54 PM
I asked the same question and got no answer, good luck.
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 03-02-2015, 11:31 AM
You can use map 5 with E30-E40
With E50 and methanol injection map 7 should be fine too.
Default 03-02-2015, 11:52 AM
You can post logs in the support section and myself or Russell will help check them out.
Russell @ BMS's Avatar
Car: 2009 335i AT
Default 03-02-2015, 12:47 PM
When you start mixing E85 with pump fuel your really mixing three fuels.
1. The pump fuel you add to complete the fill, normally 91 to 93 octane.
2. The pure Ethanol in the pump fuel and E85.
3. The gasoline that makes up the balance of the E85, E50 or E30.
The problem is the octane of the fuel that makes up the "balance fuel" when you purchase anything less than E100. Do you really think that octane is anything higher than 87?
Car: 2012 BMW 135i
Default 03-02-2015, 12:58 PM
Thanks Terry. I have a couple logs to post up when I get home in a bit.
Russell, yeah it seems the best solution is to hopefully fine e100 somewhere and fill a can so you can mix it yourself. I'm sure none of the stations blend their E with anything but 87.
e46m3to335i's Avatar
e46m3to335i e46m3to335i is offline
Car: 2015 F22 M235i
Default 03-02-2015, 01:05 PM
Here's what I get delivered right to my door step:
http://www.ebay.de/itm/150480189785?...%3AMEBIDX%3AIT
E100 Isn't cheap though, at least not here. lol.
-Nick
2014 335i xDrive / Silver / ZF8 / M-Sport / 400M / BM3 2H Map / xHP Stage 3 / ATM FMIC / H&R Sports / VRSF **/CP
Car: F20 M135i
Default 03-02-2015, 01:22 PM
-Nick
I tried both E100 and E96.6 bio ethanol. It made no difference. Now I get straight ethanol (not bio version) from the chemist at only 1.20 euro per liter.
peter@pureturbos.eu
pureturbos.eu
Newguy123's Avatar
Car: 12' 135i
Default 03-02-2015, 01:33 PM
lmao peters stockin up
18 Glacier white RS3
#PURETURBOS
#FUELIT
Car: 2015 F22 M235i
Default 03-02-2015, 01:45 PM
Ethanol is ethanol and both are technically considered "bio" because of the way they are produced.
http://cta.ornl.gov/bedb/biofuels/et...Overview.shtml
I originally looked at the 96.6% ethanol but quickly learned that the remaining 3.4% in that blend was mostly distilled water. Needless to say, I didn't want to take any chances with it in my tank.
-Nick
Car: F20 M135i
Default 03-02-2015, 02:01 PM
Need to stack for running E60 or more soon
peter@pureturbos.eu
pureturbos.eu
Car: 2015 F22 M235i
Default 03-02-2015, 02:04 PM
All you non EWG guys get to have all the fun, lol.
e36addict e36addict is offline
Car: 2011 135i DCT
Default 03-03-2015, 08:52 PM
So I got an Accessport V2 for my N55.. It's a 98G0B car, but the AP says it's an unknown ROM. AP is updated to latest firmware level. Am I missing something, or do I just need to contact COBB tech support? Thanks.
2013 X1 35ix - CP, **, JB4/MHD BEF
houtan houtan is offline
Default 03-03-2015, 09:18 PM
You need to enable beta firmware in accessport manager. After that, firmware should update. Then hook it up to your car and it should work.
Car: 2011 135i DCT
Default 03-03-2015, 09:35 PM
Thanks for the reply. I found that after my post.. Tried it, hooked it up to the car with the same result. I sent COBB an unrecognized ROM form with my ECU ROM file attached. Guess i'll see what they say. I suspect it has something to do with the PPK flash? Who knows..
BEE35i BEE35i is offline
Car: MY11 e92 335i DCT
Default 03-08-2015, 08:47 PM
Terry do you have a back end flash available for an Aussie e92 n55 335i? running jb4 and fbo, Charles from pure told me to ask you before buying a stage 2
Default 03-08-2015, 08:56 PM
Flash maps for 2011 - early 2012 models are in the first post. There are no flash maps for mid 2012+ models.
Car: 11 135i
Default 03-08-2015, 10:16 PM
Aus 2010-2012 n55 with appropriate bmw dme firmware are Cobb supported and the BEF is available front page of the thread. I have Oct 2010 build N55 and have the BEF loaded no problems. I'm In Brisbane.....
