Car: 2007 335i
27.9 Map 6 and Map 3 and Wedgeperformance flash -
11-23-2013, 01:32 PM
All I can say is this combo is freaky fast!
Wedge performance flash gives you gobs of torque and then you couple that with Terry's new 27.9 firmware you have a record breaker. As we know on map 3 a while back was great but you had to wait for flow before building boost...now the boost just shoots up and goes crazy! With the wedgeperformance flash you grab RPMS VERY fast, when car hits 3000+ it is game over! I am having a hard time keeping car straight. In the logs below I was fishtailing up to the middle of 3rd  .
Note: you have to have proper mods, octane to run his flash, nearly 15 degrees of timing.
Map 6 logs: (0n the 18psi log I was only at 45% dutycycle.)
Map 3 log (this is a 60 add because of the aggressive timing 80 add was way to much, tried a 70 add and could not keep car from going sideways...so whats the point LOL!!)
Car: 2007 335i
11-23-2013, 01:37 PM
Notice how fast boost build and how fast car grabs RPMS.....scary fast lol!
Where can we find this Wedge performance flash?
Is this a replacement for Terry's backend flash?
Car: 2007 335i E92
11-23-2013, 02:18 PM
+1 what is this Wedge performance flash?
|2007 E92 SGM 335i|
Cobbv3 • BMS DCI & OCC • VRSF *** & FMIC • E85 • Custom Backend & Alpina TCU flash • ER CP • RB PCV+Cap
Walbro 255 • Rohana RC5 19s • Nittos 555 245/275 • Cyba Scoops • LUX V3 • M3 Cowl • ST Coils • LCI Tails
Car: 08 135i , 06 325xi e90
11-23-2013, 02:46 PM
Those logs are perfect...
11-23-2013, 02:49 PM
meth and pump gas 93 ?
11-23-2013, 03:14 PM
Have you tried this flash with ISO19? I found the boost build is killer fast with ISO19, but I haven't tried 27.9 to be fair.
2008 335i Coupe 6MT
JB4G5, DCI, Wagner FMIC
Car: 2007 335i
11-23-2013, 04:09 PM
Meth, E85
Car: 2007 335i
11-23-2013, 04:10 PM
I will have wedge chime in here!
Car: 2007 335i
11-23-2013, 04:24 PM
ISO 19 would have more lag if using meth since it does not have the meth safety changes. You would have to wait for flow before building boost.
11-23-2013, 04:56 PM
Ah, good point. I was thinking no meth since I dont use it.
2008 335i Coupe 6MT
Car: 2007 335i
11-23-2013, 05:23 PM
get meth!
Because Racecar
Car: '08 135i
11-23-2013, 06:19 PM
Nice! Def interested in getting a copy of the flash youre running.
-'09 135i MT - Custom 6466 ST - 680whp
-'08 135i AT - 6466 ST - dead
-'97 318is - Daily
-'82 320i
Car: AW 135i
11-23-2013, 06:25 PM
pretty please share the flash!!! : )
RIP 2008 AW/BL 135i
Car: '07 335i e92
11-23-2013, 06:31 PM
haha, Rob you are doing a good job. No need for me to get involved. ROFLMAO haha
Car: 09 335i xDrive 6spd
11-23-2013, 06:36 PM
Wedge I might hit you up for the flash... Only downside for me is I couldn't run it often since I don't always have E85. I'm currently doing the BMS Race flash and daily driving map 1 then switching to map 3 if I want more power and meth or map 7 if I grab E85.
On another note, Rob did you use one of the new future use settings to disable the JB4 waiting for meth to build boost or is it something that changed on the flash side?
 < Click picture for photoshoot
E90 335i xDrive 6spd, Nav, Prem, Cold Weather, & Sports package - Msport Conversion
Mods: JB4 + MHD, Doc Race ST, Pure 6266, AD-Eng PI/Mounts, Fuel-It st. 3, Custom Exhaust, Tuned by TwistedTuning
More Pictures: Build Thread /// Dyno Soon to Come
11-23-2013, 06:57 PM
Can't wait for Wedge to get in here  Sounds very exciting!
11-23-2013, 07:21 PM
get meth!
I could run it. I just don't think it really would do me any good since I have E85. I am already capping my boost not because of timing, but because of the stock turbos. Been running 17.5 psi for 60,000 miles. Don't really want to run them harder since I can hear them before the car gets warmed up.
Would love to see the flash though. I have my own flash, but its really just fuel economy changes. Once the new clutch breaks in I will maybe throw some more timing at it.
2008 335i Coupe 6MT
Car: 2007 335i
11-23-2013, 07:30 PM
I am using FUB = 2 "spray and pray" with HSF-4.
11-23-2013, 08:00 PM
It's aggressive but looks to be running strong. JB4 + back end flash FTW.
I'd probably stay with map 3 (so you at least have the SAP safety) and then maybe lower additive a bit further.
Car: 2007 335i
11-23-2013, 08:15 PM
Lower it? Ran 20 down to 18 for a year but with less aggressive timing lol! I will try that...I can't raise it because I can't get traction lol! Yes, JB4 + flash =  X 10
11-23-2013, 08:36 PM
In to see where this goes next!
Any plans to put her on the dyno?
11-23-2013, 08:46 PM
I would personally. It all depends on your risk tolerance.
Car: 2007 335i
11-23-2013, 09:18 PM
You know me T....I love to push the envelope lol! Haven't blown a turbo yet
Car: 2007 335i
11-23-2013, 09:20 PM
you bettered believe it!
Thread Tools |
Display Modes |
