Car: Alpine White e82 135i
09-20-2020, 04:56 AM
So no feedback an this bug on revision 15? Feel robbed now because I bought a feature that I cant use. NLS not functioning either. Please can anyone give feedback!
Brendan
Car: 335i 2007 6spdman
09-20-2020, 06:49 PM
Yea my 2 step does not work still.
I someone could explain the new settings and firmware to get it working again that would be appreciated.
10-16-2020, 04:07 AM
Sooooo, still no feedback as to rectifying this issue?
Brendan
10-16-2020, 04:08 PM
The only way to control the engine is with an aftermarket ecu.
I have had everything working then next drive out they dont.
My boost by gear wont work.
Antilag works but timing stays retarded until I change gear. Defeats the whole purpose.
afr and portinjection flow not stable or contrable enough.
Once you get to a certain level jb4 can only do so much.
11-23-2020, 09:48 AM
Can anyone please shed some light on what is going on with the issue on the 2 step not working anymore after firmware update?
11-23-2020, 10:38 AM
No known issues so post up a JB4 log if you need assistance. If using a 2step make sure you have the latest v15 update for twin or v139 for single turbo.
11-24-2020, 09:44 AM
There are multiple people a couple of posts back complaining about the same issue.
I dont understand what must I make a log of.... The 2-step with anti lag integration used to work, I did the update to v15 and it stopped working. One guy reverted back to v14 and it was good again, but this did not work for me.
As I stand now, no 2-step stand-alone or integrated and no NLS.
11-24-2020, 10:47 AM
What isn't happening exactly that used to be happening?
If there was a firmware problem it would effect ALL users of that firmware not just one car for example. For example firmware older than v15 requires a clutch wire we no longer offer so anyone running 2STEP relay without a clutch wire needs v15 or newer firmware or it won't work.
If 2step/NLS isn't working at all for you, perhaps your 2step relay has failed?
11-30-2020, 05:16 AM
Ok thanks Terry.
I will check the relay, just found it strange it stopped working only when did v15 update.
But I do understand what you are saying. It is strange only few cars are effected. especially AnilKram had the issue after update, then after going back to v14 it was fixed.
Will check relay and report back.
12-11-2020, 04:20 PM
Not sure my 2step relay is working as menu 8 is not doing anything / not activating. Changed relay doublechecked everything.
Tried it with MHD rev limiter/ launch control...
3.4k rpm 14psi
5200 rpm 26pis.
No way i am letting go of that clutch
Car: 09 135i
01-08-2021, 12:47 PM
So do we have to purchase a new 2 step relay? I never removed the clutch wire from before either.
09 135I MT jb4 g5/MHD Trebila backend Frankenturbo F21 FBO, PI, stage 3 lpfp, full E85, Quaife LSD
01-08-2021, 12:56 PM
Not had any mass reports of problems. If you need specific technical help just email us.
Car: 2019 AWDGT2
01-08-2021, 02:19 PM
Any plan for this on the Stinger platform?
