brendan's Avatar
brendan brendan is offline
Brendan
Car: 335i 2007 6spdman
Default port injection and 2 step - 07-18-2020, 11:17 PM
I have had 2 step working before Installing port injection. Worked as it should.
I just got my ecu reading gears and thought I would try 2 step again. Previously ecu was not reading gear and it would cut at 2step rpm while in gear at wot.
I set menu 8 3000rpm
Once im wot it revs up then slugishly hangs at 1500 and up 500rpm or so.
Put menu 8 4000rpm. In neutral at wot it shoots to 4000rpm then drops back to 1500 slugishly hangs 1500 and up 500rpm.
What cryptic 2 step settings do I need.
Ecu is a manual.
brendan's Avatar
Brendan
Default 07-20-2020, 05:27 PM
What settings do I need to change from the e85 ts single turbo map to the port injection e85 ts single turbo map?
brendan's Avatar
Brendan
For the 2 step to work?
