fn42 fn42 is offline
Car: 2008 335xi
Default misfires > 6500 am I out of fuel? - 05-04-2020, 09:38 AM
https://***********/u/fn42/log-1588593509
20200503_164704_runs(1).csv
the problem I am having is that on high boost (>25) the car loses all power over 6500rpm and throws misfire codes for all 6 cylinders
LPFP drops to 50 and HP drops to "6"
car has a walbro 450 + 750cc PI, 2 step colder plugs @ .020
should I be doing a bigger LPFP or is this the HP side cutting out?
thanks
335xi sedan 6mt / MMP 1k turbos / MHD FlexFuel + AIC6 PI / South Bend Stg3 clutch
535xi wagon 6mt / ebay 17t / FBO
Stevo585's Avatar
Stevo585 Stevo585 is offline
Car: 2007 335i Coupe MT
Default 05-04-2020, 10:08 AM
Your timing looks good.
I think you want to bump up your Fuel Bias but I'm not sure; I'll let an expert chime in!
2007 e92 335i 6MT MSPORT -- DAW Stage 4 Turbos -- AD Engineering Port Injection -- VRSF Down Ps -- BMS DCI -- VRSF Inlets -- VRSF Aluminum Outlets -- ARM Chargepipe -- Turbosmart DVs -- 7" ARM FMIC -- LSD -- 335is Clutch -- BMS Short Throw -- Stage 2 Bucketless -- n20 Tmap -- Custom 3.5" Single Exit Exhaust
Car: 2008 E93
Default 05-04-2020, 10:17 AM
Attachment 95548
thanks
As far as fueling is concerned, I would do dual walbros. Your lpfp is pretty maxed out, so even if you bump pi up, lpfp wont keep up.
Car: 2008 335xi
Default 05-04-2020, 11:15 AM
damn ok, I have been looking at those BMS fuel pump controllers anyway
Default 05-04-2020, 11:51 AM
Ummm yes, you are out of fuel, HPFP is tanking & LPFP is in the 50s
Pretty dangerous man.
How are you controlling your pi? Our controller?
Car: 2008 335xi
Default 05-04-2020, 12:39 PM
no it's a splitsecond AIC6 & I am running the motiv flexfuel box to scale it for ethanol
I could go higher on the duty cycle for the PI. It's probably 70-80% at 25psi
but it sounds like I just need another pump
Default 05-05-2020, 12:55 PM
Your out on the low end & top.
Id run a significantly less aggressive map until you sort that out.
Car: 2008 335xi
Default 05-06-2020, 05:34 AM
thanks
definitely still working on the fuel map
at the low end part where it's lean the fuel scalar works out to be over 1.3 on E50, I feel like that is already more fuel than it should have? ecu_psi == boost here so I cant blame the jb4 right
Car: 2008 335xi
Default 05-06-2020, 05:44 AM
oh I bet the big turbos change VE a lot in that 10psi range so that kinda makes sense
Default 05-06-2020, 06:21 PM
Yeah 10, 12, 20, 30 psi on big Turbos isn’t the same as stockers- so be careful
If you had our integrated pi controller, dialing the car in would be a heck of a lot easier with more protection
