(#76)
joeinsd joeinsd is offline
Car: 2010 e92 335i msport
Default 04-17-2020, 08:46 AM
Originally Posted by joeinsd
Motiv Flex module installed. FF map from Trebila received and flashed via MHD.
Now, is this the ONLY setting to turn on in JB4 the DTML FlexFuel Input option?
Do any of the other inputs need to be turned on as well, such as the 14/15/16 input?
Wanted to confirm since no one had answered. Also because e content sometimes is pegged at 100 when DTML is on.. Thanks!
fn42 fn42 is offline
Car: 2008 335xi
Default 04-19-2020, 04:58 AM
Make sure you are running at least G5_ISO_32_14_T11 FW
T11) Fixed issue with E85 reading not showing properly when using MHD back end flash flex fuel integration, enabled on WMI page bit2 on for DTML Flex Input.
mine didnt read correctly until I flashed it
335xi sedan 6mt / MMP 1k turbos / MHD FlexFuel + AIC6 PI / South Bend Stg3 clutch
535xi wagon 6mt / ebay 17t / FBO
Default 04-19-2020, 08:55 PM
Thanks for chiming in fn42.
I'm running 32.14.T11. Today I had both bits turned on and it showed content, but fluctuates with throttle.. That's not normal, is it?
https://youtu.be/cLhOERxlCLQ
