Scydle Scydle is offline
Car: Infiniti Q50 3.0T
Default Everyones Trans Temp / Heat Exchanger Setup - 08-10-2019, 09:41 AM
My trans temp is always at 132 even at cold start. Even after the cars warm its always between 132 and 138. Is the sensor bad?
Arkadiy18ap Arkadiy18ap is offline
Car: Infiniti q60
Default 08-10-2019, 06:49 PM
Thats hight temprature look like u got air
Car: Infiniti q60
Default 08-10-2019, 06:52 PM
My trans temp is show -30 after bleeding system is any one know this kind problem
maxlegends maxlegends is offline
Car: q50
Default 08-11-2019, 03:12 AM
Unfortunately its normal if you have a stock heat exchanger and ur idling for a while in 90 degree weather. You need to upgrade the hx. Buy the burger one or ams
Car: Infiniti q60
Default 08-11-2019, 01:47 PM
Hey i dont have stock heat exchanger i have ams one i went today toshop they check car and said its problem with jb4 gages dont work proparly i try to flash and update same prpblem gage for heat exchanger work but show nagite tempature from -30 to -17 depends how hard i drive the car
Car: q50
Default 08-11-2019, 04:41 PM
It's not an issue with JB4. Mine always reads accurately and changes with a pull.
Q50 Premium RWD
BMS JB4 w/ FW, WMI, EWG
BMS HE
Low cost LSD
Car: Infiniti q60
Default 08-11-2019, 05:34 PM
Here screen shot off my tempreture so u can undestand what do i mean
Car: q50
Default 08-11-2019, 06:23 PM
I'm not doubting you have a problem, just saying it's not the jb4. If you have a working obd2 and getting other signals then it's not the jb4. Likely a sensor or wiring issue.
Q50 Premium RWD
BMS HE
Low cost LSD
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 08-15-2019, 07:59 AM
what firmware are you on?
12.64 @114mph
0-60 4.46
Car: Infiniti q60
Default 08-15-2019, 02:05 PM
I wass on 7 didnt help will do bleeding for system again maybe will help will se
