(#4051)
Right.On.Q!'s Avatar
Right.On.Q! Right.On.Q! is offline
Car: 2017 Q60 3.0t Coupe
Default 04-05-2019, 09:35 AM
Working on updating our JB4 guide. Need some engine bay photos of the JB4 harness plugged in and also showing JB4 control box placement. Ideally on a stock engine bay. Our development cars have intakes on and too lazy to remove them.
I have a couple of pics that fit your criteria that may be useful to you. How can I send them to you?
2017 Q60 Premuim 3.0t RWD
BMS JB1/JB4 Module
BMS Air Intake
Tanabe Strut Tower Brace
Tanabe Medalion Touring Axleback Exh.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 04-05-2019, 10:11 AM
@Terry, somewhat off topic but is there a size difference between the Regular heat exchanger you sell vs the Elite?
12.64 @114mph
0-60 4.46
Default 04-05-2019, 10:27 AM
No they are equivalent. The Elite is a little nicer, and weighs less. I think it's worth the extra $100. But we also realize this is a price driven market so have to offer the cheaper option also.
monsta121 monsta121 is offline
Car: Q50 SS
Default 04-05-2019, 11:30 AM
Terry is there some place we can email our logs to you? I keep posting on here but it always gets missed.
maxlegends maxlegends is offline
Car: q50
Default 04-05-2019, 01:47 PM
Hello @terry I was wondering if we can do a FF duty bias tune on our platforms yet? What does PID stand for and what does it do? I tried to look at my FF and WGDC they both 0'd out and my duty bias sometimes goes up. Thanks
40Rolls 40Rolls is offline
Car: 2018 Q50 Silver Sport
Question E30 - 04-05-2019, 02:44 PM
Before I get some data logs this weekend after making an E30 blend, is there any settings I need to adjust on the JB4 for running E30? Would you recommend grabbing a few logs using map 7 before moving on to map 6 adjustments or is there a better map for e30 logs?
Default 04-06-2019, 10:04 AM
Map7 is the most aggressive map. I'd start lower probably map5.
Just quote the thread or bump it if I miss it. Generally speaking I only need to see logs if there is some specific issue with the car we're looking for though.
Car: q50
Default 04-06-2019, 10:16 AM
Bump
Also any way i can make my stock ecu request more boost?
Default 04-06-2019, 12:08 PM
Bump
We don't have EWG control active yet so PID/FF won't do anything.
Not sure what the second question is.
Car: q50
Icon1 04-06-2019, 12:46 PM
I have a luxe and my stock ecu is asking for 8psi of boost and i want it to request say 14, and then add jb4 boost on top is it possible?
EvolvingApe EvolvingApe is offline
Car: Infiniti Q50
Default 04-07-2019, 09:19 AM
Hi Everyone.
Mr. Terry,
Would you mind checking out my logs? Both runs felt smooth for the most part. I might've felt some hesitation down low but it could've just been in my head too, not sure. Thanks in advance!
19 Q50 RS RWD - JB4
Car: q50
Default 04-07-2019, 01:07 PM
Do you understand how the JB4 works vs a full tune with ECUTEK?
Car: q50
Default 04-07-2019, 06:34 PM
Yes the jb4 is a boost controller which tricks and overrides signals that get sent to ecu and it can also adjust afrs and help trick the fuel pump. Whereas a ecutek is a direct change to ecu allowing u to play with more variables such as timing and ignition
Car: q50
Default 04-07-2019, 06:35 PM
And my question has nothing to do with the jb4, im curious what makes the q50 sometimes request 8psi vs 12 on the same exact car in different conditions. What makes those conditions?
Car: q50
Default 04-08-2019, 04:23 AM
Reread what I quoted in that post. That is not what you asked. But to answer what's quoted here, the ecu takes into account things like coolant temp and iats and adjusts the requested boost level. An example of this is if the engine is not warm enough it will reduce the commanded boost level.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 04-08-2019, 08:05 AM
oh max is here? let me get situated..
12.64 @114mph
0-60 4.46
Default 04-08-2019, 08:38 AM
Originally Posted by EvolvingApe
Hi Everyone.
Mr. Terry,
19 Q50 RS RWD - JB4
Looks good to me! How's the 1/4 mile times?
Default 04-08-2019, 08:40 AM
The factory ECU is LOAD based not boost based. It attempts to keep power equal under all driving conditions and climates, regardless of altitude, intake temps, humidity, and the sort. Boost is the variable that it's changing.
ericQ50 ericQ50 is offline
Car: 2016 Infiniti Q50 SS
Default 2016 Inifiniti Q50 Silver sport map 7 datalog - 04-09-2019, 07:43 AM
Hello everyone. I ahve a 2016 Inifiniti Q50 Silver sport running 93 octane with 4 gallons of E85 on map 7. Im just curious if you guys could take a look at these datalogs and see if all is well. Thanks
Default 04-09-2019, 08:29 AM
Seems OK but update the firmware so we can see fuel pressure!
Car: Q50 SS
Default 04-09-2019, 10:05 AM
@Terry can you please take a look at these logs. Both are 3rd gear pulls starting at about 2k rpm. It looks a bit strange to me in the middle of the run.
Mods: jb4 with fuel wires, stillen intakes, megan ldp
Map: 6
jcoffeyy jcoffeyy is offline
Car: 2017 Q50
Default 04-09-2019, 12:27 PM
Sorry if this is a dumb post, but this is where I'm supposed to come to learn about this stuff right?
I just started diving into map 6 but I'm not sure what I'm supposed to be looking for in the logs to make sure everything is running right before bumping it up.
I havent installed my fuel wires yet. Should I wait until they're installed to mess with map 6?
Also, this is on 93 pump gas, AMS instake, BMS HX, Megan *********
1500 - 2.0
2000 - 3.0
2500 - 4.0
3000 - 5.0
3500 - 5.0
4000 - 6.0
4500 - 6.0
5000 - 5.0
5500 - 5.0
6000 - 4.0
6500 - 3.0
7000 - 0.0
Boost Safety - 20
Default Wastegate - 30
Car: q50
Default 04-09-2019, 12:30 PM
Low cost LSD upgrade thread is finally up in this section. Pics wont upload so I linked to Q50.org thread.
Car: Infiniti Q50
Default 04-10-2019, 07:47 PM
I didn't get to check my 1/4 tbh but boy was the car hauling. I'm running 91 octane here in SoCal so I've actually gone down to Map 1 since then for fear of cooking the engine. With your input though maybe I'll go back up to Map 2!
That's awesome! I'd been looking for an LSD upgrade for some time now but was put off by the price. Now that you've provided an alternative though maybe I can finally give it a go. Keep us updated.
2019 Q50 Red Sport 400 RWD - JB4
