Car: 2011 135i N55 DCT
06-26-2017, 07:05 AM
Originally Posted by wrxified
Yes. Simply because it's registering the license to your VIN
Hello all
Question, my car have a file load with the Cobb acces port, do I need to uninstall it or I can install the bef file on top of that one.
Car: 2011 e92 335i
06-26-2017, 07:25 AM
Originally Posted by frefer82
Hello all
Unmarry Cobb AP to install MHD.
07-02-2017, 06:30 AM
Hello, I un marry Cobb, then install the JB4 pump file with the MHD, and select the bubbles sound cold start 1 second and the other one 2 seconds, and sems to be ok then I chose 4/2 in the wheel controls, after that I turns off the car, and connect my phone and upload the latest ISO file from N54 page, but have a question, when I buy the N55 flasher in the MHD app and after all was done I tried to read the error codes from MHD and it reads bue days no vin found ?????
It's that normal or I did something wrong ?
Car: 135i N55 DCT
07-03-2017, 01:59 AM
You cant read codes with mhd and jb4 from the obd oort unless the jb4 is set to map 0.
Read codes through the jb4 usb cable
135i N55 / KW V3 / CP-E charge pipe / CP-E 5" DP / CP-E 7" FMIC / JB4 S2 / MHD / K&N inbox / Custom made 3.25" catback / Tons of other mods
Car: 11 135i
07-03-2017, 02:57 AM
Hey my launch control doesn't seem to work anymore, is that a side effect of the kickdown flash option?
Car: 135i N55 DCT
07-03-2017, 04:13 AM
Yes, the launch control is dependant on the kickdown button
07-03-2017, 05:29 AM
Yes the JB4 was in map 0, but the thing that have thinking it's that the mhd says that there was no vin number.
Car: 2010 335i xDrive Sedan
07-06-2017, 08:19 AM
I'm running the BMS PUMP BEF with JB4 using MHD. I've switched to map 0 to try to get ready for obd inspection. I've driven around about a hundred miles and still have four readiness codes incomplete. Do I need to flash back to the stock BEF? Or just drive more? The two oxygen sensor readiness, and eBay and fuel system are not ready. Thanks!
07-12-2017, 09:41 AM
Autoclear was on. Oops. All good and passed now!
On another front, I can't seem to launch the car nearly as hard as before the BEF. I can bring up the revs to 2500 or so but boost seems soft. Is this from the BEF?
Thanks,
Adam
07-13-2017, 07:59 PM
For the 135i DCT cars, I just realized we accidentally left the torque eff divisor stock in the latest BEF maps... Email me for a change to test that should improve holding power.
07-14-2017, 09:49 AM
Posted the updated maps to the first post. Let me know if any issues crop up with the torque scaling raised back up.
07-14-2017, 12:27 PM
Thanks,
Adam
Thoughts on this? Car is a 6AT.
Car: 12' 135i
07-14-2017, 01:45 PM
I'm DCT but what seemed to really help me from 0mph launch was playing with the menu 11 settings. Idk why but it seemed to hit boost way quicker
18’ Glacier white RS3
#PURETURBOS
#FUELIT
07-14-2017, 01:46 PM
Yes we also made a change that effects how much you can prespool the turbo... On the latest test firmware I disabled it in 1st gear. Email me if you want to test it.
07-15-2017, 04:46 AM
I would love to try it out. What's your email? Not sure but I cannot find it on here. Or just email it to me directly, adam.farnung@gmail.com
Car: 2012 bmw 135i
07-16-2017, 01:18 AM
Can you prespool a turbo if you have a dct?
2018 Individual Tanzanite Blue Competition M4
Car: 2011 135i
07-16-2017, 09:55 AM
When we install the new firmware "7/14/17" do we have to do the full 35min write or will it work just doing the 4min quick flash?
also how does the prespool the turbo work?
07-16-2017, 09:57 AM
Always quick flash, except for the first time loading.
Car: 2012 135i N55 DCT
07-16-2017, 06:51 PM
Hi Terry, in the latest map update, what is the _THR map? is that for TBI equipped cars??
2012 135i N55 DCT Cabonschwarz Metallic
--- JB4 w/ BMS BEF / Pure Stage 2 / Pure Inlet Pipe / DV+ / TBI / Wagner D-P / Wagner FMIC / BMS Intake / Cobb CP / Stage 2 LPFP / 19" VMR V703's / Eibach Pro / Blackline LCI's / RIEGER ---
07-16-2017, 07:33 PM
The THR template has a less sensitive throttle mapping in it.
Car: 2011 BMW 335i
07-16-2017, 08:49 PM
THR also works great with xHP Stage 3. The non THR maps, after a while my car starts surging really bad.
2011 335i / MHD E85 BEF / JB4 ISO / xHP Stage 3 TCU / M3 Control Arms / VRSF Piping/ Phoenix CP / YCW Coilovers 6K-18K / Enkei Raijin 18' Wheels / Michellin PSS
07-16-2017, 09:23 PM
Ahh I see, thanks!
Car: 07 335i AT
MHD update 1.11 -
07-17-2017, 02:45 AM
1.11
- E30 and Stage2+ maps revision (1.0)
- Revised linear throttle at low throttle.
07-17-2017, 08:25 AM
hello mate, can you tell me how to do the quick flash on the MHD app,
thanks.
Car: 11 135i
07-17-2017, 09:19 PM
thanks.
Just like normal, it's just faster when you have MHD already flashed to the vehicle.
