jtrejo jtrejo is offline
Car: 535 2008
Default Transmission slipping questions - 09-14-2016, 08:29 AM
So heres my situation, my transmission cooler lines had fallen off a bracket and ended up rubbing against another line and popped a leak, Once i figured out what it was i found a fellow forum member had some lines thanks again @duperstar. once we put the new lines on and put some tranny fluid back in, it drove fine then next morning it started slipping again, put more fluid in it ran good, no leaks. today the tranny started shifting funny again and tranny light turned on. I stopped car took key out started again drove ok but i still feel shifting a little funny. is the tranny going out or is it just the fluid you think? and how much are new trannies if i have to replace it? thanks for info
2015 535 - JB4 - VRSF pipe- Burger Intake - Straight piped - MHD Backend Flash
BMW135xi's Avatar
BMW135xi BMW135xi is offline
Car: BMW 135I
Default 09-14-2016, 08:52 AM
Go to eBay buy a used one if you have to for $1,000 dollars with low mileage..
I bought one with 36,000 miles , is here at home waiting for Dynamic Propulsive
to come with the friction clutches and the rest for an upgrade.
Impac's Avatar
Impac Impac is offline
Car: 2008 BMW 535i
Default 09-14-2016, 09:27 AM
If i were u i would flash the trans with new fluid twice and reset your adaptions with INPA
JB4 G5, DCI, Er CP with HKS Bov, VRSF DP's, BB Race flash
Car: 535 2008
Default 09-14-2016, 09:43 AM
what fluid do you guys recommend? can I reset adaptations with MHD or JB4 or Carly for BMW?
Impac's Avatar
Car: 2008 BMW 535i
Default 09-14-2016, 11:09 AM
I've used OEM fluid but there are other options just google it, and as for Adoptions i used INPA, not sure if Carly can reset them, and I dont think MHD can reset Transmission Adoptions
Car: 535 2008
Default 09-14-2016, 11:16 AM
do you know that name of our transmission or model number?
Impac's Avatar
Car: 2008 BMW 535i
Default 09-14-2016, 11:40 AM
Of the top of my head i think our A/T is GA6HP19Z
Just double check on realoem type in your vin last 7
Car: 535 2008
Default 09-14-2016, 01:37 PM
https://www.realoem.com/bmw/enUS/sho...diagId=24_1372
showing ATF 2
Car: 535 2008
Default 09-14-2016, 01:38 PM
if my mechanic put pentosin would that cause the issue?
Car: 535 2008
Default 09-14-2016, 03:24 PM
Rmfd automatic transmission EH GA6HP19Z looks this is my transmission type
Jsr1256 Jsr1256 is offline
Car: 08 335i Sport Package
Default 09-16-2016, 06:43 PM
Buy zf6 fluid u can't go wrong made for our transmission
08 E92 335i AT 20k Miles | Wedge E60 Flash| E85 | VRSF FMIC | VRSF Lower Charge Pipe | ER Charge Pipe|Tial Bov| Vrsf *** | DCI | IC Sprayer | Scoops | NGK 1 Range Colder Plugs | Fuel It LPFP | E60 | [12.2 @ 118with e85 flash] [ My E60 flash 1/4 = 11.8 @ 120
Rnm Rnm is offline
Default 09-17-2016, 01:30 PM
Do you know where would be the best place to order oem fluid from?
2007 335i - MHD, VRSF 7" FMIC, PLM *****, Stage 2 Fuel-it!
