Impac's Avatar
Impac Impac is offline
Car: 2008 BMW 535i
Default Engine oil question - 08-03-2016, 02:54 PM
What Engine Oil should i use ? Car is 08 E60 535i, JB4 MHD, FBO, Stage2 LPFP and just got done installing Hexon RR600 and Inlets will be tuned by Trebila soon
JB4 G5, DCI, Er CP with HKS Bov, VRSF DP's, BB Race flash
Default 08-03-2016, 09:07 PM
I've always just used Mobile1 0-40 and never had an oil related issue on the 6 or so N54s we've owned. It's cheap and easy to get.
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 08-03-2016, 10:33 PM
I use Castrol 0-40. It's cheap at Walmart
09 335 - 6266
07 335i - 6870, E85 - SOLD
Aaron Aaron is offline
Car: 335is
Default 08-03-2016, 11:32 PM
Renewable Lubricants Bio-SynXtra SAE 5W40 Heavy Duty Super High Performance absolutely annihilated the competition in several post-interval lab tests on turbo/DI motors. It's not cheap, but after reading the lab tests, I couldn't ask for better.
FCobra94 FCobra94 is offline
Car: '07 E90 335i
Default 08-04-2016, 06:07 AM
I run it...UOAs came back lookin good.
N55guy N55guy is offline
Car: M235i
Default 08-04-2016, 06:21 AM
As Terry said, my Porsche came with Mobil1 0W-40 and I've carried that over to my BMW. Walmart 5 quart jugs are about $25
RCB RCB is offline
Car: E61 535XIt
Default 08-04-2016, 06:32 AM
I run 5w40 Rotella T6 synthetic with a MANN filter.
2008 E61 535xit MHD, VRSF CP, Tial BOV, DCI, RB Inlets and Outlets, VRSF 7"FMIC, Custom ***, BMS OCC, RB External PCV, M5 seats, LED interior/DRL, 20" Style 128 wheels, KWv3, M5 steering wheel, M-Sport conversion, Bimmer-Tech HD/Apple TV, RB Twos
2008 Lexus ISF I/H/E, Figs suspension arms, BC/swift, BC wheels, PSS (305 rear)....
1993.5 Supra 857 WHP, GT42R, CCW/R888 (305 rear)...
1968 Plymouth GTX 440 (For Sale)
2017 Chevy 2500HD Z71 LTZ
IG: CBBOOST
Snertz's Avatar
Snertz Snertz is offline
H O O N
Car: Ein M
Default 08-04-2016, 06:39 AM
+1 for Mobil1 0w-40, $23 bucks on Amazon prime for 5qt jugs, occasionally the 6pk of qt bottles can be had for $28.
H O O N
Torgus Torgus is offline
Car: 335xi
Default 08-04-2016, 06:49 AM
I'm switching everything over to that myself.
Got Boost?
Car: 335is
Default 08-04-2016, 07:27 AM
Good thing M1 is cheap. Because cheap is the name of the game with engine oil. M1 isn't very great with the demands of a turbo/DI motor, you guys might want to have analysis done.
I'm in the process right now of having mine sent off at intervals, going to see if I can push my change intervals back to 10,000 miles.
Car: '07 E90 335i
Default 08-04-2016, 11:15 AM
Here's mine:
http://www.bobistheoilguy.com/forums...Number=2782766
E92Beast E92Beast is offline
Car: 09 E92 335i AT
Default 08-05-2016, 02:46 AM
Only thing I don't like about M1 is they changed a while back. it use to be great.
09 E92 335i Msport, fbo+e85 flash, 11.91 @ 119
10 E90 335i, MHD Stage 1
CT_Drifter's Avatar
CT_Drifter CT_Drifter is offline
Car: 14' F30 335i EWG N55
Default 08-05-2016, 04:45 AM
Did you notice the Mobil1 0-40 isn't BMW LL-01 rated anymore? I still use it assuming the reason is political not technical....
JayJ JayJ is offline
Car: 135i N54
Default 08-05-2016, 07:14 AM
Motul X-Cess 5w40
Stucks Stucks is offline
Default 08-05-2016, 08:01 AM
joe gibbs driven dt40 5w40 or some other high zinc oil (brad penn, rotella t6, ect)
Current: 2008 e92 335i coupe.
9krpmrx8's Avatar
9krpmrx8 9krpmrx8 is offline
Car: 2011 335i Sedan
Default 08-05-2016, 08:23 AM
I have run Mobil1 0W-40 in every car I have owned and I have done several UOA's and it has always performed great. I have run and Tested T6 and it did very well. I started with Castrol 0W-30 and it did not handle hold up nearly as well as the Mobil1 in a 1500 mile OIC, it was were the Mobil1 was after 4000 miles. All my cars are turbocharged. My boss also owns a few Porsches and runs M1 0W40 and has never had an issue.
But more important than the oil you choose (as long as you run the right "weight"), is how often you change it. Most brand name oil now days are pretty good so if you are doing normal oil change intervals you won't have a problem. But if you like to stretch your intervals then you better pick a quality oil that will last.
Alpine White 2011 335i Sedan with Nav, etc.
Mazda RX-8 Touring, Turbocharged, etc., etc.
E9X Post Texas!
Traf Traf is offline
Car: 2009 135i Coupe
Default 08-05-2016, 09:05 AM
Motul 8100 X-Cess 5w40
f*** v-bands clamp
matthewo matthewo is offline
Default 08-05-2016, 01:49 PM
shell rotella 5w40 every 5k miles, cheap and $5 mail in rebate per gallon, use your work address as they only let you do 4 gallons a year, not sure you will really need much more unless you car burns it like mine
InsipidMonkey InsipidMonkey is offline
Car: 08 E61
Default 08-05-2016, 02:35 PM
Mobil one has a $12 rebate on 5qts going on now, bringing the cost down to about $10 ($22.88 - $12) for 5 qts.
Amazon: https://www.amazon.com/Mobil-120760-...56775a63ed0195
Walmart: http://www.walmart.com/ip/Mobil-1-0W...5-qt./23636902
Rebate link: https://apfco.com/secure/R8235W/
To receive your rebate, simply complete the form below and upload your purchase receipt(s) (from participating retailers only) dated between August 1, 2016, and October 31, 2016, with eligible purchases circled. If you prefer to send your request by mail, print the form and mail it, along with your receipt(s), to the address indicated on the printed offer form. All requests must be submitted by November 30, 2016.
For faster processing, redeem online below.
Mobil has been offering this rebate every year in the Spring, this is the first time I've seen it in the fall as well. I've always received the rebate checks quickly, no issues ordering from Amazon or Walmart.
08 335Ci's Avatar
08 335Ci 08 335Ci is offline
Car: 08 335Ci
Default 08-05-2016, 03:05 PM
Amsoil 5w-40 European formula. Not cheap, but neither is my engine. Just had to add 1/2 qt. at 8000 miles.
My wife's Toyota uses no oil between changes. (97K on the clock)
Remember, you get what you pay for.
'10 E92 335 M Sport, JB-4 G5 ISO, 3" CPE Charge pipe, WMI w/dual CM 5 nozzles, 3.5 Tmap, ARM Relocated Inlets (don't do it), VSRF Outlet, BEF, Front Strut Brace, SS brake lines, Drilled and Slotted Rotors, Anti-lag, OCC. Escort Max 360
Totaled by a careless driver:
'08 E92 335, M sport option
