(#501)
335iMspizzle 335iMspizzle is offline
Car: 335i M sport
Default 04-26-2016, 07:30 AM
Originally Posted by m5james
Bump for wanting E70 X5M support to be able to use the JB4, BCM and meth controller. At this time I've got a stage 2 tune, exhaust (gutted factory down *****, added in an x-pipe, muffler delete with Vibrant resonators) and intake system in the works. I'd love to run meth, not only for being a power adder but also for its cleaning abilities before my heads look like something I've seen on 335i's. I can go from mild to wild, but at the same time I've got ZERO way to control the ECU with any of these kits on thw chance I lose meth pressure due to a clogged line, so all these fancy controllers in the kit are nothing more than an indicator that I've toasted my engine if I don't get outta the throttle soon enough. Mind you since I've got no meth tune, I'd only run straight water to maybe doing -30 washer fluid and a bottle of Heet until meth tuning becomes available.
http://www.coolingmist.com/pagedispl...key=turbo_kits - as simple as they get, then I'd use my washer fluid for a reservoir
http://sohiperformance.com/i-2151943...lWxBoCmf3w_wcB - nice looking kit but still seems overkill at the moment and I've got no desire to have a gauge installed into my interior unless needed
http://howertonengineering.com/product/aquamist-hfs-4/ - extreme kit, but the same issue still remains...ECU control.
Give the S63 non-TU some love!!
WHERE ? I can not find it, can you make it in RED BOLD ? I don't see it i swear
2014 - M6 f06, FabWorx Ctlss DP's, JB4, FSB meth, Turner Exhaust.
2012 - 650i M sport JB stage 1 (Gone)
2009 - 335i N54 JB4, DINAN CAI, MACHT SHNELL DP'S, HPF FMIC, ER CP, SYNAPSE BOV, EISENMANN RACE EXHAUST, BT OIL CC, COOLINGMIST/SNOW PERFORMANCE METH INJECTION - 427 WHP DYNOJET (Gone)
Car: 335i M sport
Default 04-26-2016, 07:32 AM
Firmware is in the first post.
Where ? I do not see it ???
Default 04-26-2016, 08:19 AM
Bottom of the first post. Really can't miss it!
m5james's Avatar
m5james m5james is offline
Default 04-26-2016, 09:26 PM
Why'd you quote me
Bump for Terry...am I 100% wasting my time in hoping that you'll give the S63 any love in regards to JB4 and BCM so we can start running boost numbers like the S63TU guys?
Default 04-29-2016, 02:20 PM
Note for those running the JB4, meth, and the REV3 bluetooth kit. I've had 3 customers now report an issue with their meth randomly turning on and draining the tank when they are not in the vehicle. In all three cases they had a REV3 kit installed so we're pretty sure its related somehow. If anyone else has had this issue crop up let me know so we can get to the bottom of it.
Why'd you quote me
Just not enough of them out there to work with. It is possible the existing JB4 for the s63tu is compatible. Test one out and shoot me a log.
ERM5 ERM5 is offline
Car: M5
Default 05-04-2016, 08:59 PM
Went out to grab a log of Map 2 on 93 octane tonight. MDM on, car cutting power in this 50 degree weather, still managing a 7.2s 60-130 time.
After sending over the logs to BMS, car seems good to leave as is - even though trims maxed out, AFR is in check. Attached are the verified VBOX files and a screenshot of the log .
m5james's Avatar
Default 05-05-2016, 09:31 AM
I can't PM you so can you PM me, please.
conquistador conquistador is offline
Car: 2012 335is
Default 05-05-2016, 09:36 AM
For CA guys, which octane booster are you using? Or are you buying 100 octane and mixing with 91?
Will JB4 or our ECU's adapt to 100/91 mix?
Default 05-05-2016, 09:40 AM
PM system is disabled for me. Just email us!
steeve13m steeve13m is offline
Car: 13 M5 DCT
Default 05-05-2016, 10:19 AM
ERM5 what a/f numbers are you getting on map2 at the 5500-7000rpm range? I was in the 13/14 range
Car: 13 M5 DCT
Default 05-05-2016, 10:23 AM
Do we have any solid root cause? After swapping my ecu JB4 board and wiring the power of the Meth FSB controller and Bluetooth Rev3 device to the red fused red cable above the oem ECU passenger side box(instead of getting power for positive batter post)....and using a plastic jb4 case instead of the metal one.....all has been working fine....no meth flooding my engine after car sat for hours....
Car: 13 M5 DCT
Default 05-05-2016, 10:24 AM
I use Lucas octane booster...really good octane boost for daily driving
Car: M5
Default 05-05-2016, 10:44 AM
Check the log from a few posts up to get a general idea of the AFR curve. Here are specific values from 4th gear:
Car: 2012 335is
Default 05-05-2016, 12:45 PM
Are you running meth?
Default 05-05-2016, 12:48 PM
No but we have a suspicion that its related to the REV3 power wire. Have we had to relocate it to the JB4 harness yet? If not I'd do that.
Car: M5
Default 05-05-2016, 12:57 PM
No - my car is otherwise stock other than the JB4+BCM and 93 octane.
ur20v ur20v is offline
Car: BMW F10 M5
Default 05-05-2016, 05:29 PM
Terry, I want to run water / meth injection, I only want the cleaning and ATI lowering benefits, can I control the 50/50 water/meth injection to run at the high level with JB4 but limit boost to 19/21psi to keep torque and the DTC clutches in check? I ordered the #5 injectors, should I go smaller with this in mind? I know others have this use in mind as well.
Jay
Default 05-05-2016, 05:40 PM
CM5 nozzle sound good for that role. Just run a really low additive on map8. Like a 10 additive to start.
Car: BMW F10 M5
Default 05-05-2016, 05:49 PM
Terry,
Thank you.
Just tried to call you but got Bavarian Autosports, obvoiulsy not you lol- can you PM me a number to contact you on or reply to my email.
I want to sort the order out for the JB4, filters, water injection kit etc.
Jay.
Car: 13 M5 DCT
Default 05-06-2016, 08:45 AM
your car runs richer than mine not sure why(below is rpm/af on 4th gear map2...but didnt go too far up in rpm on logs)....so you are in the safe zone on map2 maybe on the very rich side(low 12's is target at peak rpm I believe)......I run K&N drop in filters and octane booster....
5090 14.8
5147 14.4
5216 14.4
5393 13.9
5503 13.9
5473 14.7
5552 14.4
5657 14.4
5720 14.4
5771 14.3
5845 14.1
5950 13.6
6030 13.2
Car: M5
Default 05-06-2016, 09:18 AM
5090 14.8
5147 14.4
5216 14.4
5393 13.9
5503 13.9
5473 14.7
5552 14.4
5657 14.4
5720 14.4
5771 14.3
5845 14.1
5950 13.6
6030 13.2
I have a 2016 Competition pack, you (not sure if this makes any difference)? Log was done in 50 degree weather, what were your conditions?
Default 05-06-2016, 09:21 AM
The CP would increase the amount of boost you can run before running out of fuel trims without meth. It's like a mini back end flash map. On the converse if you do add meth some day it will slightly limit power due to a lower maximum timing advance.
Car: 13 M5 DCT
Default 05-06-2016, 09:24 AM
Yes CP version might explain it....2013 M5, 85F FL....either way I am installing performance clutchpacks soon and aiming for 26psi(maybe more PSI on 93oct+octane booster) with CM10 larger meth nozzles to control a/f....then will post Dyno stats
Car: M5
Default 05-06-2016, 09:27 AM
Very helpful - maybe with what were seeing the competition package cars could get away with Map 2, while non-comp vehicles will need meth.
I am definitely looking to add meth in the near future, but I'm going to do both the meth and dodson DCT upgrade at the same time because its inevitable that the clutches will give out at some point.
