(#426)
Default 01-31-2016, 01:00 PM
The power potential for a JB4 vs. a Stage1 is similar. But the JB4 will be much smoother, and offer more features, while hitting the same peak power level. To get more power than Stage1 you need the JB4 + BCM.
cjrdriven cjrdriven is offline
Car: 2014 BMW M5
Default 02-01-2016, 11:47 PM
And JB4 plus BCM is worth all the install labor plus some! Car comes to life.
limeypride limeypride is offline
Car: 2015 BMW M6 Gran Coupe
Default 02-02-2016, 05:54 PM
Hi!
Are you able to elaborate and explain what you mean by the 'car comes to life'? I have the stage 1 and have been happily using it for years now--it's been in 4 or 5 cars and is currently in my M6. I'm trying to gather some more objective data as to why I might go for the JB4+BCM upgrade. Are you able to compare the two (assuming you had the stage 1 that is)?
Thanks.
2020 BMW M8 Competition Gran Coupe
Default 02-02-2016, 06:20 PM
Default 02-02-2016, 06:51 PM
Excellent... both you and your customers seem elated!
Feel free to chime in on my question below assuming your obvious enthusiasm and possible bias doesn't hinder your objectivity :
Default 02-02-2016, 09:03 PM
The JB4+BCM adds power and features over the Stage1. We've not come across any customers who have upgraded who didn't think it was well worth it.
Car: 2014 BMW M5
Default 02-03-2016, 09:20 PM
Originally Posted by limeypride
Hi!
Thanks.
Going from 17/18 psi to 21/22 psi and hitting more consistently to target you will absolutely feel the power difference. Remind yourself of power difference you felt from stock to stage 1. Then you can almost compare that to stage 1 to jb4 + BCM. If you then add meth to that, car will scare you again.
Default 02-03-2016, 10:14 PM
Thanks... that's helpful.
stevan335's Avatar
stevan335 stevan335 is offline
Car: e93 335 i
Default 02-06-2016, 02:57 PM
Anybody a few more pictures of m5 install?
335iMspizzle 335iMspizzle is offline
Car: 335i M sport
Default 02-07-2016, 11:08 PM
Car feels fast on map2 with bcm, feels like I've added e85 honestly
2014 - M6 f06, FabWorx Ctlss DP's, JB4, FSB meth, Turner Exhaust.
2012 - 650i M sport JB stage 1 (Gone)
2009 - 335i N54 JB4, DINAN CAI, MACHT SHNELL DP'S, HPF FMIC, ER CP, SYNAPSE BOV, EISENMANN RACE EXHAUST, BT OIL CC, COOLINGMIST/SNOW PERFORMANCE METH INJECTION - 427 WHP DYNOJET (Gone)
TheDoctor's Avatar
TheDoctor TheDoctor is offline
Car: BMW 335i
Default 02-09-2016, 04:19 AM
Hello I've ordered s63tu M5/M6 JB4 BETA w/ BCM & OBDII, should I order the stage 1 also??
and If I order it where should I plug it as the s63tu M5/M6 JB4 BETA w/ BCM & OBDII will be plugged in the TMAP sensor.
335i M//, 07",IC, CP, BOV, LPFP stage 3, Meth kit, MHD ST,PI,PTE 6466, 32psi ~ 750whp
Default 02-09-2016, 09:35 AM
You either run the JB4 OR the Stage1, not both at the same time, lol.
Default 02-09-2016, 07:43 PM
That's great to know.
I notice below you've dyno'd most of your cars--any plans to do the same here? I'm especially interested since we share the same car and I know what I'm putting down with Terry's stage 1...
Default 02-09-2016, 07:46 PM
Originally Posted by Powell
I am on day 3 on Map 2 with my JB4+BCM on 93oct. Going to put it on our dyno tomorrow or Wednesday.
If you read first post he talks about tuning on pump gas and they found Map 2 at 22psi was good on 93oct. The link to that thread is in the post as well.
Did you ever post back the dyno results--it's possible I missed something?
TheDoctor's Avatar
Car: BMW 335i
Default 02-09-2016, 08:40 PM
Ok so far I have installed the jb4 with the bcm, but FF keep rising and Im not getting any more boost.
Default 02-09-2016, 09:30 PM
Looks like a major boost leak, fault code stored, or some issue with your installation. Unrelated to your problem but boost safety should be set to 26psi.
TheDoctor's Avatar
Car: BMW 335i
Default 02-09-2016, 10:28 PM
I tried to set boost safety to 26 but nothing changed.
As you can see the throttle is closing at WOT and it never be in a range 70-100, do you think it could be installation issue.
What's your recommendation?
Default 02-10-2016, 09:26 AM
We don't do 1 on 1 tech support in the main forum. You could make a post in the support forum. I'd start by removing the BCM though and doing a log on map4 on the JB4 only to evaluate stock boost.
TheDoctor's Avatar
Car: BMW 335i
Default 02-10-2016, 09:31 AM
Okay I will do and attach the log to the support section.
TheDoctor's Avatar
Car: BMW 335i
Default 02-10-2016, 09:46 AM
But I have one question I upload the firmware through the bluetooth kit don't you think I should do it through the obd ??
Default 02-10-2016, 10:05 AM
The JB4 firmware is loaded via either a BMS DATA cable or the JB4 blue tooth kit.
garyf10m5 garyf10m5 is offline
Car: F10 M5 CP
Default 03-02-2016, 01:22 AM
Hi Terry,
Hope all is well with you. Just to ask, as i randomly read from "N54" section that FUD set to 0 means the various FutureUseD options are not enabled while FUD set to 95 means the duty bias adjustment is "activated" and hence requires the DB to be set manually by rpm. Does this applies to the S63tu 1.4c firmware as well? Thanks.
Default 03-02-2016, 08:14 AM
N54 stuff does not apply to the S63tu.
Car: F10 M5 CP
Default 03-02-2016, 09:39 AM
Ah ok. Thanks. So I'll just leave my FUD at 0.
scott135i scott135i is offline
Car: 135i / 335i / Z4 3.5
Default 03-03-2016, 11:55 AM
Anyone running the JB4 with BCM on an otherwise Stock (non-CP) M5 on 93 octane? How's it going for you? Running Map 1 or Map 2 most often?
